May I ask why Onyx v2 MN is not backward compatible with Onyx? There should not be any technical issues preventing that? Right?
Same here. I think they've been up less than an hour. At least I got a payment in that timeOK, MN:s dropped about after one hour, not good if need restart every hour.
Give people/pools time to upgrade.What was the point to turn the enforcement off?
Weird because Evan wrote this on BTCtalkGive people/pools time to upgrade.
Masternode payments for version 16.6+ have begun! This means, there will be no more payments for the old network until they update.
Enjoy the extra payments![]()
Yes... is "darkcoind masternode list | grep xx.xx.xx.xx" does not bring back your IP with :1 - then it dropped.I'm running a hot/cold MN. "masternode debug" shows: "masternode started remotely"
MN list shows ~220MNs but I don't see my own IP
Have it running for ~18hours now on 16.6 and no payment so far (not that unusual)
Do I need to restart it because it's not in the MNlist or do I just have to wait?
I know, I'm not sure what he meant. I can only confirm that it is off (just checked).Weird because Evan wrote this on BTCtalk
Mine are still online since I restarted them at 3:30am.Any info how fast they drop off the list?
Fixed it with this: "shutdown all, delete peers.dat on local and remote, startup all, send masternode start twice a few seconds apart"I'm running a hot/cold MN. "masternode debug" shows: "masternode started remotely"
"masternode started remotely" is when your cold wallet thinks that your mn that you are trying to start was already started. So you need to resync that list to get rid of cached mn ip.Fixed it with this:...
Why is there a rush to upgrade for v16 when v15 had a long waiting period to the enforcement? There is no reason to suddenly force people to upgrade immediately when v15 took 21 builds to become stable. The protocol should also be backward compatible until the v16 becomes stable.Give people/pools time to upgrade.
Yes, you're on the global Darkcointalk Ingore List Dossier (short: "Dildo"), that means you can see your and everyone else' postings, but others can't see yours.EDIT: Am I on ignore list or smth?
Because a problem was discovered in the Darksend protocol that could lead to transactions being traced through fees.Why is there a rush to upgrade for v16 when v15 had a long waiting period to the enforcement? There is no reason to suddenly force people to upgrade immediately when v15 took 21 builds to become stable. The protocol should also be backward compatible until the v16 becomes stable.
That's a job for Propulsion!Can somebody update the forum notice : "MN Enforcement was a success! Latest version 10.15.21 is available."
Yes and No.Because a problem was discovered in the Darksend protocol that could lead to transactions being traced through fees.
I didn't have time to get into testnet because it is true that it was super fast, but I guess Evan felt confident about the code. Besides, not everything can be seen in testnet because the sizes and number of players are so different.Yes and No.
Yes, we should hurry as Darksend is core feature (now).
No, we should test more, just a few more hours of testing wouldn't hurt anyone but they would reveal:
1. Memory issues and crashes
2. Protocol issues and MNs delistings
and this would help us to avoid a lot of confusions
There is a HUGE amount of work Evan has done for these few days and there is a lot of changes
https://github.com/darkcoin/darkcoin/commit/8833d12a3af7d13b29079b6202ef2455971c8e34
I really respect it so why ruin it by pushing not properly tested code to mainnet?
That's true, testnet differs from mainnet in terms of size and number of players. 1200 MNs vs less then 100 tMN in last test for example. But that shouldn't be "contra", that should be "pro". You can simulate any kind of (inappropriate) behavior there (forks, different kind of enforcements and even 51% attack), you can force smaller time periods for pings and other events to speed up protocol checks - however that would require to clean most of hardcoded valuesI didn't have time to get into testnet because it is true that it was super fast, but I guess Evan felt confident about the code. Besides, not everything can be seen in testnet because the sizes and number of players are so different.
Same here.. "restarted" them again through local wallet only.Dropped off again after 2.5h.
Sure, important bugs first i agree, but this is just bump to remember.this issue with darksend fees was most important, and its not like those 34 bugs are very important - wallet works great most of the time. and evan already made it clear that he needs more developers. so lets just be happy he gets so much work done and not tell him what to do next
