Enhanced Darkcoin Wallet UI
dashboard
24
26
13
Latest DRK news tab, maybe?
And update auto / manual.
Edit: Maybe your own masternode info also would be nice.
The more stuff one pulls from the web the less private the s/w is.
It would be nice if it were possible to disable all external sources in Settings > Privacy.
pille
274
302
123
Are you open for new design proposals here? Or already professinals working on it or planned? I think there is much upside potential looking at the current one. We need someting real professinal, modern, serious, like a bank.
Should be done after new website is ready to eventually match it.
I thought about offering a preview and start a budget voting for it maybe.
And I read about multiple themes / theme editor. Please NO! Think about it. We want to sell a brand. The theme should be part of our brand. Every Photoshop kiddy will f*** it up. It's also about seriousness. Do you know a online-banking interface where you can customize the theme? We would look like a joke.
Reactions: TaoOfSatoshi
3,639
3,537
Udjin, when do we have v12.1? I guess we don't have to test it first?
https://github.com/dashpay/dash/compare/v0.12.0.x...dashpay:v0.12.1.x
Basically changes are:
1) new MN status "pre-enabled"
2) refactor budgets rpc commands (rely less on names and more on hashes) + slight budgets code refactor
3) bip69
4) DS MultiSession cmd-line option
5) changes to UI theming (crowning)
Would like to see testing for at least #1 and #2. Some testing for #3 should be nice too though it's just about sorting of inputs/outputs. #4 is experimental and is off by default. #5 seems to work ok so far :)
EDIT: no idea about "when" :D
Reactions: AjM and moli
tungfa
8,902
6,737
Hey crowning
I pinged you about something on all other chats already
I am looking for a picture of next version darkwing wallet (dark blue)
And tip where I can find that ??
AjM
1,341
575
Finland
Dont worry, every new theme will be approved by devs and community, and its in the code (source).
Reactions: tungfa
ALX3K
19
9
can i now control a mastered with the v12 core or what is this here? how can i setup a mastered with this
tungfa
8,902
6,737
Dummy question #461
My transactions are all gone ?
no idea what happened.
When i click (top left) 'today', shouldn't that switch to all ?
It does not ? Bug ? (Mac)
tungfa
8,902
6,737
Yo
I am not totally retarted ;)
It did NOT switch to anything else than "today"
tungfa
8,902
6,737
i swear i can not change from 'today'
i am stuck there !
spaceballs or not
crowning
1,414
1,997
Alpha Centauri Bc
Dummy question #461
I just tried this on my Mac, no problem at all, the normal select options show up there and I'm able to select "All".
Does "Reset Options" help?
Reactions: tungfa
tungfa
8,902
6,737
That totally worked
(before it was really stuck)
tx man
moli
3,255
1,830
Hello crowning !
For Repair Wallet Options, is it possible to have another button with both -zapwallettxes and -reindex? (So we don't have to do this in command-line or shortcut.)
And btw, what's the difference between "-zapwallettxes=1" and "-zapwallettxes=2" ? I've tried both buttons but I don't see any difference.
Thank you! :)
crowning
1,414
1,997
Alpha Centauri Bc
Hello crowning !
It's possible of course, but do you think this combination is used by enough people (and often enough) to justify another button? After all you can first do one and after the restart do the other one.
Thank you! :)
-zapwallettxes 1 tries to read the meta-data from the transaction (value, from, timestamp, account name, etc.), -zapwallettxes 2 not.
But it can only read what's already there, and right now that seems to be not very much. Maybe that'll change in the future...
moli
3,255
1,830
Well, I've used both in one restart but I don't know if other people do the same. If it's too much trouble, don't worry, I can always put them together in the shortcut and run the wallet. Thanks, crowning. :)
3,639
3,537
moli I think -zapwallettxes and -reindex are kind of... perpendicular so to say.
-zapwallettxes - clean any txes known by your wallet and rediscover them by rescanning blockchain (either filling back old data from a copy or not)
i.e. blockchain was ok, it's smth wrong with txes in your wallet
-reindex - recreate blockchain index
i.e. wallet is kind of ok but blockchain is broken
