Better would be to group transactions windows explorer style, +/- symbol woukd expand/collapseWould be nice to have a filter for Darksend Denominate and Collateral Fees on Transactions tab (now they are only shown on "All" not even on "Other")
Well, filter is much easier to implement imo and it's quite common to use alreadyBetter would be to group transactions windows explorer style, +/- symbol woukd expand/collapse
I have not seen this discussed here - and I do try to keep up on things but....
How will us/the MN owners be able to keep the 1000DRK locked away and keep from it being "manipulated"?
I see no way to "lock away" coins.
Kinda scares me a bit.
If there is a solution already - what is it? or point me to it - thx in advance.
- Added code to randomly use the top 20 masternodes, this can dynamically be increased as more transaction traffic starts to happen (although it's not implemented but it could be done later)
I think MangledBlue is referring to "fund splitting": currently there is no way to keep the wallet from splitting your funds (especially the 1000DRK vin).Masternodes are protected by the code. We actually haven't had any problems with that.
Not the 20 "best"I am probably just confused, but does this mean that regardless of the current number of available masternodes only the best 20 are used for anonymization?
$ darkcoind masternode current
50.191.199.127:19999
$ darkcoind masternode list rank | grep : | awk '{ print $3, $1}' | sort -V
1, "50.191.199.127:19999"
2, "54.208.138.69:19999"
3, "188.226.248.36:19999"
4, "54.191.87.83:19999"
5, "54.191.236.39:19999"
6, "54.92.19.72:19999"
7, "54.183.79.141:19999"
8, "184.73.179.235:19999"
9, "149.255.109.167:19999"
10, "188.226.223.5:19999"
11, "184.73.179.187:19999"
12, "184.73.179.196:19999"
13 "211.99.224.173:19999"
14, "92.222.10.179:19999"
15, "209.222.30.51:19999"
16, "54.179.187.196:19999"
17, "184.73.179.148:19999"
FundSplit() even ignores the "lock unspent" settings atm.
Which isMasternode operators: If you own 198.50.148.87, can you send me your debug.log pls? Your node charged a collateral transaction that it shouldn't have. evan@darkcoin.io
Thanks
10509.txt:mzWRw88FSQXBAfCNF9hqLHMkuCtEfCXQBW d0510bc11a217e4230154fd760086d68518eea24 198.50.148.87:19999 1 1407396349981699 130 9015
10510.txt:mzWRw88FSQXBAfCNF9hqLHMkuCtEfCXQBW d0510bc11a217e4230154fd760086d68518eea24 198.50.148.87:19999 1 1407396349981699 618 9015
10511.txt:mzWRw88FSQXBAfCNF9hqLHMkuCtEfCXQBW d0510bc11a217e4230154fd760086d68518eea24 198.50.148.87:19999 0 0 1407397775 -1407387334
10512.txt:mzWRw88FSQXBAfCNF9hqLHMkuCtEfCXQBW d0510bc11a217e4230154fd760086d68518eea24 198.50.148.87:19999 0 0 1407398056 -1407387334
Got it. Thanks. :smile:Not the 20 "best"
There is a rank list for masternode selection, which changes each block as the first entry is removed. From this rank list the top 20 are used to do the mixing. The more masternodes in the network, the longer the rank list
Code:$ darkcoind masternode current 50.191.199.127:19999 $ darkcoind masternode list rank | grep : | awk '{ print $3, $1}' | sort -V 1, "50.191.199.127:19999" 2, "54.208.138.69:19999" 3, "188.226.248.36:19999" 4, "54.191.87.83:19999" 5, "54.191.236.39:19999" 6, "54.92.19.72:19999" 7, "54.183.79.141:19999" 8, "184.73.179.235:19999" 9, "149.255.109.167:19999" 10, "188.226.223.5:19999" 11, "184.73.179.187:19999" 12, "184.73.179.196:19999" 13 "211.99.224.173:19999" 14, "92.222.10.179:19999" 15, "209.222.30.51:19999" 16, "54.179.187.196:19999" 17, "184.73.179.148:19999"
eduffield : correct me if i am wrong.
I've been working on setting a target amount for Darksend to denominate and it turns out to be a giant problem. What if the wallet just disables darksend by default for more than say 5000DRK, which you could override if you wanted to.
I've been working on setting a target amount for Darksend to denominate and it turns out to be a giant problem. What if the wallet just disables darksend by default for more than say 5000DRK, which you could override if you wanted to. It would also give a popup error saying "Darksend is not designed to run with more than 5000DRK in a wallet, to use darksend please make a new wallet with less than that amount" or something
Not many people will have more than 5000DRK. Shouldn't be an issue.
Money gets stuck. I have a wallet with 300k tDRK fully denominated through 9 rounds and I'm not able to move even 10% out of it due to a "Transaction too large" issue.I guess if it can be disabled by the user than any limit is OK, but ... whats' the problem with letting it run for any amount( i.e without the troublesome target setting as is the case now)?
Fees? Time required? Bloat?
