v0.10.11.x RC3 Prelaunch Testing
Discussion in 'Testing' started by eduffield, Jun 23, 2014.
Thread Status:
  1. AlexMomo
    AlexMomo New Member
    May 19, 2014
    33
    7
    Up and running, thank you!
    107.170.146.58:19999:1
  2. yidakee
    yidakee Well-known Member
    Apr 16, 2014
    1,812
    1,168
    All my nodes up and running fine!
    Is there a backup testnet explorer?
  3. chaeplin
    chaeplin Active Member
    Mar 29, 2014
    749
    356
  4. flare
    flare Administrator
    Dash Core Team Moderator
    May 18, 2014
    2,287
    2,406
    - Updated four masternodes and reindexed, all in chaeplin 's list
    - The blockchain has a changed block format, so abe-explorer is not able to parse it anymore - can someone address this (eduffield chaeplin )?
    - I finally have the first set of gitian-builds up and running - if someone likes to test, here are the Windows binaries for 0.9.11.2, built by CI-Server
    darkcoind: http://bamboo.darkcoin.qa/artifact/DWD-DRK/QTL/build-21/gitian-win-darkcoin/32/daemon/darkcoind.exe
    darkcoin-qt: http://bamboo.darkcoin.qa/artifact/DWD-DRK/QTL/build-21/gitian-win-darkcoin/32/darkcoin-qt.exe
    Feedback welcome.
    • Like Like x 3
  5. flare
    flare Administrator
    May 18, 2014
    2,287
    2,406
    The block format changed, explorer is currently not able to parse blockchain - that's why http://23.23.186.131:1234/chain/DarkCoin is stuck
    • Like Like x 1
  6. jimbit
    jimbit Well-known Member
    May 23, 2014
    228
    203
    downloaded: v0.9.11.2-ga950f31-beta from the bamboo server
    running.
    had to reindex... still it is stuck on 24616.. gona let it run, i have seen them clean themselves just running.
    solo mining against qt: OK.
    edit: wonder how this works since it is not up to date !
    [15:53:25] Found block for Pool 0!
    [15:53:25] Accepted 8424762f Diff 1.937/0.922 BLOCK! GPU 3
    really curious to know if this block will be valid:
    Transaction ID: aed638423353dc67c73040662ffe488c1d97a4a95b58948f6ebb580491d0ecdc
    • Like Like x 1
  7. flare
    flare Administrator
    May 18, 2014
    2,287
    2,406
    My windows client got "stuck" at 24616 after reindex too, whereas this was/is actually the recent block. Decided to wipe testnet3 folder and to restart again.
    Nevertheless the block you found should be valid - we will see ... :)
  8. yidakee
    Apr 16, 2014
    1,812
    1,168
    24618 here, now.
    I've noticed that it may seem stuck, but let it be and it will "jump" after a while. Happened simultaneously on local and remote.
    Only checking one local since we dont have abe, but I just got payed
    #98 yidakee, Jun 24, 2014
  9. jimbit
    May 23, 2014
    228
    203
    I am stuck on 24628 now... estimated at 24639
    4 immature solo blocks. will see what happens.....
    gona drive home now.. 1.5 hours.
  10. minersday
    minersday Member
    Apr 9, 2014
    77
    19
    Im setting up more testnet masternodes, please provide 1000 tDRKs to each.
    mtNqTbTj8bDXCPWE9ocBMwE9BhVNULi1yz
    n3kW9Ps15HaVD2KsCd2CuydiLh4uDhcR1a
    msTHofF9C2UoWk4BEs4X1MJ4ZLTTRS67Mg
    mjeLkyqoDXGrAD6JXGtKNkdaZu6T6WsnBp
  11. yidakee
    Apr 16, 2014
    1,812
    1,168
    Enjoy!
  12. daaarkcoins
    daaarkcoins Member
    May 21, 2014
    95
    40
    68
    just updated to 10.11.2
    darkcoind getblockhash 24644
    00000000595195f2b1d69ade26c69c39321daec7edb238f8748ac99b7e044aa8
    is that right?
  13. flare
    flare Administrator
    May 18, 2014
    2,287
    2,406
    Yep
    ./darkcoind getblockhash 24644
  14. flare
    flare Administrator
    May 18, 2014
    2,287
    2,406
    I think the estimation stat of the client got confused by the blockchain reversal Evan did. As soon as 24639 is reached the clients will "unstuck". So more cosmetic than a issue right now.
    Testnet seems stable so far :)
    • Like Like x 1
  15. HammerHedd
    HammerHedd Member
    Mar 10, 2014
    182
    34
    OK, got a p2pool set up and mining on testnet at 54.88.71.248:18998. Once I've got some testnet DRK, I'll try setting up a masternode as well.
    I'm curious to see how p2pool handles the change to MN payments....
    #105 HammerHedd, Jun 25, 2014
  16. jimbit
    May 23, 2014
    228
    203
    finally got home to check... all my blocks where good and I am at block 24771. I just let it run and it worked itself out.
    • Like Like x 1
  17. jimbit
    May 23, 2014
    228
    203
    give me an address to send some drk to for testnet
  18. HammerHedd
    HammerHedd Member
    Mar 10, 2014
    182
    34
    my testnet wallet is
    mghAuBWNMdeqm5TzvevY5i91nqd6Kyj17A
    thanks!
  19. jimbit
    May 23, 2014
    228
    203
    darkcoind sendtoaddress mghAuBWNMdeqm5TzvevY5i91nqd6Kyj17A 3333
    8d93ea34ef4f4b3cdea66231a2d736a1fc9ad9fe119ebdd03b5d0b628af31b9c
  20. HammerHedd
    HammerHedd Member
    Mar 10, 2014
    182
    34
    Thanks a bunch... one masternode up, and I"m trying to remote the other.. not as easy as I thought it would be lol
  21. minersday
    minersday Member
    Apr 9, 2014
    77
    19
    not a big deal but tdrk,poolhash,org
    show the ip _._.45.36 listed twice, with two different wallet addresses.
    mvTxKB6Akb2rk9jC1JAZLyw2Lu9PwpwUDF was originally correct, but I added new address alongside that address (mjeLkyqoDXGrAD6JXGtKNkdaZu6T6WsnBp) with 1000 tDRKs.
    There were the case that two different machines had the same wallet / same masternodekey but with different IPs..
    EDIT: and 5 masternodes are up, setting up 5 more later..
    #111 minersday, Jun 25, 2014
  22. chaeplin
    Mar 29, 2014
    749
    356
    mvTxKB6Akb2rk9jC1JAZLyw2Lu9PwpwUDF is inactive.
    ip is not a key. vin(aka pubkey/vin) is primary key.
    (maybe part of multiple 1k holding to 1 ip)
    mjeLkyqoDXGrAD6JXGtKNkdaZu6T6WsnBpDNA OyFinland [​IMG]_._.45.36[​IMG][​IMG][​IMG]
    mvTxKB6Akb2rk9jC1JAZLyw2Lu9PwpwUDFDNA OyFinland [​IMG]_._.45.36[​IMG]nl[​IMG]
  23. minersday
    minersday Member
    Apr 9, 2014
    77
    19
    from ...45.36 machine...
    darkcoind listaddressgroupings
    "mvTxKB6Akb2rk9jC1JAZLyw2Lu9PwpwUDF",
    15.00000000,
    "0"
    "mjeLkyqoDXGrAD6JXGtKNkdaZu6T6WsnBp",
    1000.00000000
  24. moocowmoo
    moocowmoo Bovine Bit-flipper
    Jun 15, 2014
    483
    603
    263
    Dash Address:
    http://tdrk.poolhash.org/blocks/masterlist.txt (thanks guys!)
    is showing duplicate actives after 30 minutes.
    Node caching bad entry? or web page?
    update: node finally went inactive, but proper *FFm address still missing
    page shows:
    mfpSMCgkVjrtkSVhfswSWUsdbRUxU6gFFm     034e7d69106de61044ba46079b3c4c893cd73802     64.32.6.185:19999     1     1403677737417273     1563     34646
    mpgNHgxhtGHhYX98wam8X9DWzpNMNaNuEA     6480e797bbf4ef1838d8ac4a9aa1d7f2e6b2f538     64.32.6.185:19999     1     1403677935575317     1365     10762
    mzCKvrXb42KekMJcFGhneNVnJRcuRPc5Mt     cce48bd2c49675e73d49d45c0f633de72367430d     208.98.43.109:19999     1     1403677708108963     1592     22779
    nodes show:
    $ for x in 1 2 3 ; do echo $x ; ssh drk-$x darkcoind masternode list | grep 9999 | grep "\ 1" | sort -u | egrep "64.32.6.172|208.98.43.109|64.32.6.185" ; done
        "208.98.43.109:19999" : 1,
        "64.32.6.172:19999" : 1
        "64.32.6.185:19999" : 1,
    $ for x in 1 2 3 ; do echo $x ; ssh drk-$x darkcoind masternode list pubkey | grep 9999 | sort -u | egrep "64.32.6.172|208.98.43.109|64.32.6.185" ; done
        "208.98.43.109:19999" : "mzCKvrXb42KekMJcFGhneNVnJRcuRPc5Mt",
        "64.32.6.172:19999" : "mfpSMCgkVjrtkSVhfswSWUsdbRUxU6gFFm"
        "64.32.6.185:19999" : "mpgNHgxhtGHhYX98wam8X9DWzpNMNaNuEA",
    #114 moocowmoo, Jun 25, 2014
    • Like Like x 2
  25. chaeplin
    Mar 29, 2014
    749
    356
    page : http://tdrk.poolhash.org/blocks/masterlist.txt
    address hash160 ip status lastseen sec(ago) activeseconds
    mzCKvrXb42KekMJcFGhneNVnJRcuRPc5Mt cce48bd2c49675e73d49d45c0f633de72367430d 208.98.43.109:19999 1 1403679508364428 692 24579
    mfpSMCgkVjrtkSVhfswSWUsdbRUxU6gFFm 034e7d69106de61044ba46079b3c4c893cd73802 64.32.6.185:19999 0 1403677737417273 2463 34646
    mpgNHgxhtGHhYX98wam8X9DWzpNMNaNuEA 6480e797bbf4ef1838d8ac4a9aa1d7f2e6b2f538 64.32.6.185:19999 1 1403679735695332 465 12562
    server side
    [email protected]:~/scripts>  darkcoind masternode list | grep 6.185
        "64.32.6.185:19999" : 0,
    [email protected]:~/scripts> darkcoind masternode list pubkey | grep 6.185
        "64.32.6.185:19999" : "mfpSMCgkVjrtkSVhfswSWUsdbRUxU6gFFm",
    [email protected]:~/scripts> darkcoind masternode list pubkey | grep 6.172
    [email protected]:~/scripts> darkcoind masternode list  | grep 6.172
    stat page http://tdrk.poolhash.org/
    mfpSMCgkVjrtkSVhfswSWUsdbRUxU6gFFmSharktechUnited States [​IMG]_._.6.185[​IMG][​IMG][​IMG]
    mpgNHgxhtGHhYX98wam8X9DWzpNMNaNuEASharktechUnited States [​IMG]_._.6.185[​IMG][​IMG][​IMG]
    I think key mfpSMCgkVjrtkSVhfswSWUsdbRUxU6gFFm has problem.
    • Like Like x 1
  26. moocowmoo
    Jun 15, 2014
    483
    603
    263
    Dash Address:
    This bothers me the most:
    I think the cache has a problem still. Restarting daemon repopulates cache with valid addresses/ip's, but we can't expect the entire network to restart in sync.
  27. chaeplin
    Mar 29, 2014
    749
    356
    Check other node's debug.log.
    mfpSMCgkVjrtkSVhfswSWUsdbRUxU6gFFm has issue.
    https://www.darkcointalk.org/threads/help-test-rc2-forking-issues.1009/page-44#post-8910
    New ip, New Address, New Genkey.
    edit:
    https://www.darkcointalk.org/threads/new-version-9-4-0-and-10-8-0.690/
    Masternodes now sign their 1000DRK vin for the first message to the network,
    then they specific a second pubkey that they will sign all further messages with.
    This second signing key must be specified for all masternodes in the configuration with the option "masternodeprivkey"
    "masternode genkey" : generates a completely random key that is never used in the wallet and has no funds associated with it.
    1000DRK vin ==> Pubkey ==> Specific Genkey.
    If vin/pubkey is changed, Genkey should be changed also.
    Otherwise network will not be noticed.
    #117 chaeplin, Jun 25, 2014
  28. minersday
    minersday Member
    Apr 9, 2014
    77
    19
    5 more masternodes need 1000 tDRKs each
    msYutqQEWZffG1Suabe68NSbdeBtq2DFnQ
    mxXzjr3E1AtMGwauVbZ5NNHsaecnXhXdA8
    mhYnT3kUwuZr68ECQMvaVywCwZNVWmmpcT
    mkwhKitKC8g44QUwb68okX4Ac8m6GqDWQx
    mjPo4a6zS3L8GvWZCjDNVG3GeYwc9vQYmA
    • Like Like x 1
  29. yidakee
    Apr 16, 2014
    1,812
    1,168
    Fire in the hole!!
    • Like Like x 1
  30. chaeplin
    Mar 29, 2014
    749
    356
    done ;D
    edit:
    oh ~~ doubled.
    [email protected]:~> darkcoind sendtoaddress msYutqQEWZffG1Suabe68NSbdeBtq2DFnQ 1000
    3ba2f373dbbc355a0e5b262e280df27f6a385634f060fb8217e002cad2a8477f
    [email protected]:~> darkcoind sendtoaddress mxXzjr3E1AtMGwauVbZ5NNHsaecnXhXdA8 1000
    ebf1870ce7279849d96bc0350d83c02599b8fa62a5ce708dff48cda50863b309
    [email protected]:~> darkcoind sendtoaddress mhYnT3kUwuZr68ECQMvaVywCwZNVWmmpcT 1000
    4acc22b882cdbaf6f5e50cb64442c38d767e0bad936d2edc83027e3832a560c4
    [email protected]:~> darkcoind sendtoaddress mkwhKitKC8g44QUwb68okX4Ac8m6GqDWQx 1000
    bc1a187bcc6c979d04e2d0ed69d4c518efed53bcff0bb7853f9f1995029565ab
    [email protected]:~> darkcoind sendtoaddress mjPo4a6zS3L8GvWZCjDNVG3GeYwc9vQYmA 1000
    70fc00ebe63529261041973ea28ada0f8f0c93b04b35fb257409ebc9fa772cea
    • Like Like x 1
Thread Status:
