****** PLEASE UPDATE TO 9.11.0 OR 10.11.0 *******
Hello everyone!
We're going to be testing the changes outlined in the this post: https://darkcointalk.org/posts/9557/
As mentioned before 9.11.x and 10.11.x permanently turn on masternode payments in a way that is completely 100% safe for the network. We're also going to be using an innovative strategy utilizing a modified version of Hiro's checkpointing code that gives it the ability to remotely tell the network to activate and deactivate enforcement in the future. This way if enforcement causes any issues the code can retroactively turn it off for the whole blockchain, then I can manually set a checkpoint to bring all clients back on the same chain.
New features included are:
Mpos + Stratum: http://ec2-54-198-19-83.compute-1.amazonaws.com
-- connection string: sgminer.exe -o stratum+tcp://54.198.19.83:3333 -u eduffield.1 -p x
P2Pool: http://54.213.244.5:18998/static/
-- connection string: sgminer.exe -o stratum+tcp://54.213.244.5:18998 -u mt2ScQSwpsohN8KC9CuFGCuCuvyJkCY8iEn1K5Y5JGe5svtfmrJ6J9McsZPJdWXPvuRq -p 1
NOMP: http://54.183.73.24/ (Thanks Chaeplin!)
-- connection string: sgminer.exe -o stratum+tcp://54.183.73.24:3333 -u
Block Explorer: http://23.23.186.131:1234/chain/DarkCoin
How can you help?
1.) Point some hashing power at once of the pools!
2.) Run the "forkfix" branch on testnet: https://github.com/darkcoinproject/darkcoin/commits/forkfix
Binaries (stable)
http://www.darkcoin.io/downloads/forkfix/darkcoin-qt
http://www.darkcoin.io/downloads/forkfix/darkcoind
RC3 Binaries ( masternodes )
http://www.darkcoin.io/downloads/rc3/darkcoin-qt
http://www.darkcoin.io/downloads/rc3/darkcoind
Thanks everyone,
The Darkcoin Team
Hello everyone!
- Modified checkpointing (able to remotely turn on/off enforcement)
- Hashing algorithm for including the voting information into the block hash in a tamper proof way
- Confirmations required fix for masternode inputs (was one off)
- Masternode pruning (inactive masternodes fall off the lists after a period of time)
- Min protocol version (clients will now only talk to recent client versions)
How can you help?
Binaries (stable)
Thanks everyone,
The Darkcoin Team
