Official block explorer
Discussion in 'Official Announcements' started by eltito, Jul 4, 2014.
  1. iHeartSmartArt
    May 2, 2014
    151
    59
    Maybe its a sign of things to come. If they will add alts that low, seems probable they will add more.
    Coinbase is making cryptos more mainstream with the name Blockr, Tumblr for cryptos.
    Blockr could become well-known for listing all blockchains.
  2. coingun
    coingun Active Member
    Jul 8, 2014
    489
    402
    I have brought a node online with another backup copy of the official block explorer. At this point I'm still trying to work out the kinks with fastcgi to display it over port 80. Here is the link till I get that sorted out:
    http://explorer.masternode.io:8888/chain/Darkcoin
    Once I get the fastcgi stuff worked out (any pointers would be helpful) it will drop the :8888 and just be:
    http://explorer.masternode.io/chain/Darkcoin
    I have also finished a dnsseed for mainnet as well but I'm not sure where to post about it:
    dig dnsseed.masternode.io @8.8.8.8
  3. flare
    flare Administrator
    Dash Core Team Moderator
    May 18, 2014
    2,287
    2,406
    Nice! Did you update the seeders to the latest RC5 changes on github? commit ae0ce59
  4. coingun
    Jul 8, 2014
    489
    402
    Nope I will go a head and update that. Also I'm attempting to experiment with an ipv6 dnsseed. Do you have any idea if the dnsseed will support an ipv6 seed?
  5. flare
    flare Administrator
    May 18, 2014
    2,287
    2,406
    I don't know if the original dnsseeder was programmed with ipv6 support, but your experiment will show that :)
  6. coingun
    Jul 8, 2014
    489
    402
    Ok those are updated. I'm not really sure how to query the dnsseed in ipv6 have you ever messed with it?
  7. flare
    flare Administrator
    May 18, 2014
    2,287
    2,406
    Theoretically
    dig dnsseed.masternode.io AAAA @ladar.masternode.io
    should do the trick IF the dnsseeder is capable of delivering AAAA records.
  8. coingun
    Jul 8, 2014
    489
    402
    I do see some references under the darkcoin-dnsseed inside dns.h that seems to say it supports querying of AAAA records. Perhaps there just isn't any yet for it to pickup?
    [email protected]:~/> dig dnsseed.masternode.io AAAA @ladar.masternode.io
    ;; QUESTION SECTION:
    ;dnsseed.masternode.io. IN AAAA
    ;; AUTHORITY SECTION:
    dnsseed.masternode.io. 40000 IN NS ladar.masternode.io.
    [email protected]:~/> dig ladar.masternode.io AAAA
    ;; OPT PSEUDOSECTION:
    ; EDNS: version: 0, flags:; udp: 512
    ;ladar.masternode.io. IN AAAA
    ;; ANSWER SECTION:
    ladar.masternode.io. 299 IN AAAA 2001:19f0:ac00:1c1::64
    dnsseed -h dnsseed.masternode.io -n ladar.masternode.io
    Loading dnsseed.dat...done
    Starting 4 DNS threads for dnsseed.masternode.io on ladar.masternode.io (port 53).......done
    Starting seeder...done
    Starting 96 crawler threads...done
    [14-09-23 20:46:50] 36/8240 available (8231 tried in 994s, 5 new, 4 active), 233 banned; 65549 DNS requests, 15 db queries
    Not sure what else perhaps I need some client's up with wallets using ipv6?
  9. flare
    flare Administrator
    May 18, 2014
    2,287
    2,406
    Sure :) Dnsseeder is just crawling the Darkcoin network and building a DB, which can be queried via DNS.
    So as long there is no ipv6 peer available and crawlable, dnsseeder will not have one in its DB. Check dnsseed.dump and dnsseed.dat for nodes available.
  10. flare
    flare Administrator
    May 18, 2014
    2,287
    2,406
    You are right, dnsseeder supports ipv6 --> https://github.com/nightlydarkcoin/darkcoin-seeder/commit/309d8ee0ae77e617e8cd6cf2c30b0378b66498d3
    Let me know if it works out for you.
    BTW: Propulsion would like to run a ipv6 masternode/peer - maybe you both can try it in a joint effort ;)
