Official block explorer
Discussion in 'Official Announcements' started by eltito, Jul 4, 2014.
  1. eltito
    eltito Active Member
    Apr 21, 2014
    157
    185
    • Like Like x 9
  2. nmarley
    nmarley Active Member
    Jun 28, 2014
    366
    424
    Is the code for this on github? The "AGPL source" link, which points to [redacted because new user], just gives "A server error occurred. Please contact the administrator."
    It seems like it would be easier all-around to just point users to github.
    • Like Like x 1
  3. flare
    flare Administrator
    Dash Core Team Moderator
    May 18, 2014
    2,287
    2,406
    Yes, code is on github at https://github.com/darkcoinproject/darkcoin-abe - will change the link accordingly - thanks for the feedback.
    • Like Like x 1
  4. MangledBlue
    MangledBlue Well-known Member
    Jun 28, 2014
    1,246
    678
    Thank you :)
  5. elbereth
    elbereth Active Member
    Mar 25, 2014
    440
    466
    Dash Address:
    XkfkHqMnhvQovo7kXQjvnNiFnQhRNZYCsz
    Will set one up on my web too. :)
    • Like Like x 2
  6. elbereth
    Mar 25, 2014
    440
    466
    Dash Address:
    flare, thanks for the code.
    I think you should update the logo to the correct "new" one (you can get the one I created for my explorer): http://explorer.darkcoin.fr/static/darkcoin-logo.png
    Also I though the coin was named Darkcoin and not DarkCoin (no capital C).
    That's all. :) Small cosmetic remarks. :D
    The block indexing is done but the explorer keeps showing me Quarkcoin (don't know why as the conf file has no mention of Quark)... Any hint on what I need to do would be appreciated.
    Edit: I only see block 0, which is not the block 0 from Darkcoin... In the database I clearly see all the blocks indexed. No idea why it isn't showing it...
    Edit 2: Ok I found out that there are 2 Abe codes on the Github, the old one not ready for Darkcoin (which is installed by make install) and the correct one that is in the build sub-directory. Will try to rebuild with the correct one now.
    #6 elbereth, Jul 5, 2014
  7. flare
    flare Administrator
    May 18, 2014
    2,287
    2,406
    I never used 'make install' on this code, just followed the readme-mysql :-D
    For the changes: yes, there is some legacy stuff in this code (DarkCoin, logo, outdated abe codebase) and i already planned to update this, but was busy with other stuff :)
    Thanks for the heads up :)
  8. elbereth
    Mar 25, 2014
    440
    466
    Dash Address:
    • Like Like x 1
  9. elbereth
    Mar 25, 2014
    440
    466
    Dash Address:
    Hmm getting exceptions... :/ almost there :D
  10. elbereth
    Mar 25, 2014
    440
    466
    Dash Address:
    Even after a rescan it still fails:
    Exception at 106730706854732992
    Failed to catch up {'blkfile_offset': 78885005, 'blkfile_number': 100001, 'chain_id': 2, 'loader': 'blkfile', 'dirname': '/home/darkcoind/.darkcoin', 'id': Decimal('1')}
      File "/usr/local/lib/python2.7/dist-packages/Abe/DataStore.py", line 2620, in catch_up
        store.catch_up_dir(dircfg)
      File "/usr/local/lib/python2.7/dist-packages/Abe/DataStore.py", line 2884, in catch_up_dir
        store.import_blkdat(dircfg, ds, blkfile['name'])
      File "/usr/local/lib/python2.7/dist-packages/Abe/DataStore.py", line 3011, in import_blkdat
        b = store.parse_block(ds, chain_id, magic, length)
      File "/usr/local/lib/python2.7/dist-packages/Abe/DataStore.py", line 3044, in parse_block
        d['transactions'].append(deserialize.parse_Transaction(ds))
      File "/usr/local/lib/python2.7/dist-packages/Abe/deserialize.py", line 92, in parse_Transaction
        d['txOut'].append(parse_TxOut(vds))
      File "/usr/local/lib/python2.7/dist-packages/Abe/deserialize.py", line 67, in parse_TxOut
        d['value'] = vds.read_int64()
      File "/usr/local/lib/python2.7/dist-packages/Abe/BCDataStream.py", line 72, in read_int64
        def read_int64  (self): return self._read_num('<q')
      File "/usr/local/lib/python2.7/dist-packages/Abe/BCDataStream.py", line 110, in _read_num
        (i,) = struct.unpack_from(format, self.input, self.read_cursor)
    error: unpack_from requires a buffer of at least 8 bytes
  11. vertoe
    vertoe Three of Nine
    Mar 28, 2014
    2,573
    1,652
    Why are darkcoin addresses encoded with the wrong prefix? (Looks like testnet addresses.)
    I've been wondering about that since the beginning...
    • Like Like x 1
  12. elbereth
    Mar 25, 2014
    440
    466
    Dash Address:
    Vertoe, the software apparently stores the pubkey hash and convert it for display only. Maybe that parts needs to be adapted to display the one with the "X".
    • Like Like x 1
  13. flare
    flare Administrator
    May 18, 2014
    2,287
    2,406
    Me too - nevertheless the "m...." adresses are obviously identical to their "X..." counterparts. Have to dig deeper in the explorer code to understand how the different encodings work - and how to change the explorer display :)
  14. elbereth
    Mar 25, 2014
    440
    466
    Dash Address:
    flare, does the explorer on io/qa runs by indexing the datadir directly or via RPC call?
  15. flare
    flare Administrator
    May 18, 2014
    2,287
    2,406
    Indexing datadir yet, but planning to migrate to rpc call. Had the error you encountered too, i think that's because the block format was changed (votes moved from "body" to "header" and the code of explorer does not know how to handle the new data structure. Resolved it by restarting the indexing several times, don't know why it finally picked up again :D
    But as stated: Planning to refurbish the explorer anyway...
  16. elbereth
    Mar 25, 2014
    440
    466
    Dash Address:
    I think it fails when the block on the disk is not complete or something (writing by darkcoind while reading?)...
    I don't think the RPC calls can work with my setup without changing the code. Will try that.
  17. iceker
    iceker New Member
    Jun 26, 2014
    9
    赶紧更新把
    • Like Like x 1
  18. acidburn
    acidburn Active Member
    May 26, 2014
    467
    175
    Any chance of an API on this?
  19. flare
    flare Administrator
    May 18, 2014
    2,287
    2,406
  20. flare
    flare Administrator
    May 18, 2014
    2,287
    2,406
    大概下周 :)
  21. elbereth
    Mar 25, 2014
    440
    466
    Dash Address:
    Ok, if anyone is interested, here is my version (that runs on http://explorer.darkcoin.fr):
    https://github.com/elbereth/darkcoin-abe/
    I fixed RPC catch up (wasn't working), fixed branding and address version, removed junk folders (with obsolete code).
    A pull request was sent towards the original fork.
    To fix the addresses prefix not being "X", if you already have it running (flare ):
    Change in chain table for DRK, the field address_version to "L" (hex 4c).
    • Like Like x 4
  22. vertoe
    Mar 28, 2014
    2,573
    1,652
    It's using the Bitcoin testnet pubkey hash prefix (111 or 0x6f), it must be hidden somewhere in the code...
    https://en.bitcoin.it/wiki/List_of_address_prefixes
    Edit, didn't see elbereth s post, good work!
  23. flare
    flare Administrator
    May 18, 2014
    2,287
    2,406
  24. guo
    guo New Member
    Jun 21, 2014
    还以为要跑路了呢
  25. drakee
    drakee New Member
    Aug 3, 2014
    25
    13
  26. chaeplin
    chaeplin Active Member
    Mar 29, 2014
    749
    356
    • Like Like x 1
  27. drakee
    drakee New Member
    Aug 3, 2014
    25
    13
    Ah, Thanks!
  28. vertoe
    Mar 28, 2014
    2,573
    1,652
  29. iHeartSmartArt
    May 2, 2014
    151
    59
    A new Block Explorer came out for multiple coins called Blockr http://btc.blockr.io/ It is maintained by coinbase. No darkcoin yet, I'm afraid.
  30. vertoe
    Mar 28, 2014
    2,573
    1,652
    Lol they have megacoin and digitalcoin...
