How does one fix a corrupted wallet?
Ignition75
332
216
Australia
I was clearing out some old wallets by renaming them in and out of wallet.dat.
Was going fine until one corrupted. It's got about 30 DRK in there, so it's not the end of the world, however the client has renamed it to a BAK file and can't seem to fix it.
Any ideas how I can proceed?
Propulsion
The buck stops here.
Feb 26, 2014
1,008
468
It's not good when it renames it to .bak. That usually means it's past the point of repair and it already has failed an aggressive salvage operation.
If you have another copy of the wallet.dat file, email it to me. I'll try to get it for you. My username at this website.
Ignition75
332
216
Australia
Thanks dude, I'll see if I can grab an old copy from the recycle bin first and try a repair sequence someone suggested with Python 2.7 before I take up your time.
Ignition75
332
216
Australia
I don't know why I thought the recycle bin would help, I didn't delete it.
No luck I'm afraid, it's already been renamed to a .bak file by the wallet so I guess I'll just kiss those 30 DRK goodbye...
r-ando
411
250
233
Canada
I also have a similar issue. The wallet backup dates from 2015. It doesn't rename the wallet.dat to .bak but creates another file that is .bak. Curious to know if there is a fix for this issue, thanks!
strophy
Feb 13, 2016
793
518
163
Hi @r-ando can you start another thread for your issue? What is your other .bak file called? There are some Python or BerkeleyDB tools that might help you, or maybe -salvagewallet can do it too.
