X11 Possible Nonce Vulnerability...
darrenturn90
verters com slash blockcheck
tl;dr - it seems that 90% or more of blocks have a nonce value divisible by 256. Can this be confirmed? If so, it essentially means that only mining nonce values divisible by 256 will yield a far greater chance of finding blocks.
Reactions: GilAlexander
crowning
1,414
1,997
Alpha Centauri Bc
No idea if that's true, however I've a script running right now which checks this.
Will probably run the complete night to parse the complete blockchain, but I'll report back tomorrow.
Gotta catch some sleep now :)
darrenturn90
No probs.
Remember, to account for blocks that have a very low difficulty - as they throw the equation off.
3,639
3,537
did a check for the last 50K blocks
http://pastebin.com/zeUSNLN6
~2% for Darkcoin
EDIT: for anyone interested, here is fixed code (using correct port/library)
PHP:
<?php
// this code uses EasyBitcoin a PHP Wrapper API for the JSON RPC interface
require_once('easybitcoin.php');
$coin = new Bitcoin('darkcoind','password','localhost','9998');
$blockCount = $coin->getblockcount();
$blockHistory = array();
$i = 0;
for($blockID=$blockCount; $blockID>$blockCount-50000; $blockID--) {
    // get block hash
    $blockHash = $coin->getblockhash($blockID);
    // get block
    $block = $coin->getblock($blockHash);
    $blockHistory[$blockID] = $block["nonce"];
file_put_contents(dirname(__FILE__) . "/nonce2.json",json_encode($blockHistory));
PHP:
<?php
$nonceDB = json_decode(file_get_contents(dirname(__FILE__) . "/nonce2.json"),true);
$groups3 = array();
foreach($nonceDB as $height => $nonce) {
    $val = $nonce % 256;
    if (!isset($groups3[$val])) $groups3[$val] = 0;
    $groups3[$val]++;
asort($groups3);
print_r($groups3);
you'll need this also
wget https://raw.githubusercontent.com/aceat64/EasyBitcoin-PHP/master/easybitcoin.php
and curl lib for php
sudo apt-get install php5-curl
darrenturn90
So the nonces are more divisible by 256... but not by much relative to the entire batch. However, there is still a slight pattern there.
crowning
1,414
1,997
Alpha Centauri Bc
I did the same test for the last 10000 Bitcoin blocks, and here nonces divisible by 256 are also leading, but with 0.47% way closer to the theoretically expected value. Darkcoin has 2.748%.
maky
71
32
How it can be a problem? We all will be using nonce divisible by 256 and chances for all will be equall again. ;)
Reactions: vertoe
crowning
1,414
1,997
Alpha Centauri Bc
Yeah, but only if someone notices the community about that pattern.... oh wait! *recompiles his miners*
Also thought about this...but you'd have to solo-mine.
The pools just count the number of your shares, not their quality, so most of the (already small) advantage will go away.
3,639
3,537
I agree with this but it would be interesting to see mh/s comparison of two versions though - will be there any boost in share calculation?
//Still thinking of CPU/GPU internal hardware optimizations nonce like this could hit...//
crowning
1,414
1,997
Alpha Centauri Bc
For the shits and giggles I just build a miner which only uses "nonce mod 256 = 0" nonces, the pool seems to accept them, but I can't see a change in the hash-rate at the pool (and that's what counts).
I'll let it run over night and see what happens...
Reactions: UdjinM6
moocowmoo
Bovine Bit-flipper
483
603
263
masternode.me
ran the numbers. not seeing it.
Low diff or high diff, the numbers don't show an exploitable skew.
for all 186118 blocks, if nonce mod 'power of 2' == 0, increment value below:
2: 102581,
4: 60053,
8: 39145,
16: 27066,
32: 20272,
64: 13299,
128: 8389,
256: 5120,
512: 2616,
1024: 1382,
2048: 767,
4096: 450,
8192: 294,
16384: 237,
32768: 221,
65536: 214,
131072: 99,
262144: 57,
524288: 25,
1048576: 13,
2097152: 6,
4194304: 4,
8388608: 3,
16777216: 2,
33554432: 2
the code I used: (qnd)
(echo "[" ; for blocks in `seq 1 \`darkcoind getblockcount\`` ; do echo -n '{' ; darkcoind getblock $(darkcoind getblockhash $blocks) | egrep 'height|difficulty|nonce' | tr "\n" " " | sed -e 's/, $//g' ;  echo '},' ; done ; echo "]" ) | tee nonce_values.json
then I edited nonce_values.json to remove the last trailing comma, then ran this.
#!/usr/bin/python
import json
from pprint import pprint
modulii = dict()
mod_values = list(map((lambda x: 2**x), range(1,32)))
def parse_nonce(nonce):
    results = []
    for mod in mod_values:
        if nonce < mod:
            continue
        remainder = nonce % mod
        if remainder == 0:
            modulii[mod] = modulii.get(mod, 0) + 1
        results.append((mod,remainder))
    return results
with open('nonce_values.json') as f:
    j= json.load(f)
results=[]
count = 0
for nonce in j:
    count += 1
    results.append(parse_nonce(nonce['nonce']))
pprint(count)
pprint(modulii)
quit()
(results array has the full mod/remainder breakdown if anybody's interested in further analysis.)
Happy hacking! :)
EDIT: updated the source extraction for easier adding of difficulty exclusions
