Sent 10k just in casethe dash org faucet is down, the dashninja faucet is dry and the masternode one only spits out 10-20 at a time. Can I get a donation of 3k testdash?
yZSyKwRd4m71bEWaErSFM5j3ETzVKNxjt4
Thanks!
I too looking for some testnet dash and all the faucets seem to be dry or not working. If anyone has a few tDASH to spare, please send to : yf8aG2USbLrvsuBJT1ZutDzqjwudP54PJFthe dash org faucet is down, the dashninja faucet is dry and the masternode one only spits out 10-20 at a time. Can I get a donation of 3k testdash?
Thanks!
Sent 500 tDash.I too looking for some testnet dash and all the faucets seem to be dry or not working. If anyone has a few tDASH to spare, please send to : yf8aG2USbLrvsuBJT1ZutDzqjwudP54PJF
Hello, can someone please send me some testnet dash? I'm facing a blocking in my development Thanks! yVPoXKhEe63t4jHgVeckpBv9Cni2BJqUtn
https://test.faucet.dash.org should work again, please test and let me know if you were able to get your tDash there.I'm looking for some testnet dash and all the faucets seem to be dry or not working. If anyone has a few tDASH to give away, please send to : yMsn9hFJq6cnT3LDxRcXtPwHNRyJzhALJH
Sorry, bamboo is down atm, @flare is working on recovering it, will take some time.Hi guys, the binaries links from bamboo-dash-org are showing 502-Bad Gateway from my end. Tried VPN & from mobile phone just in case my network is doing silly thing, but its still doing 502. Can someone help? Is there mirror? Thanks.
Ok thanks for letting me know. No mirror? Its probably good idea to set mirrors.. Lmk if you need resource, maybe I can donate space for mirror.Sorry, bamboo is down atm, @flare is working on recovering it, will take some time.
Resources are not the issue, Amazon just deprecated the AWS instance and i take the opportunity to clean up and update some backend stuff.Ok thanks for letting me know. No mirror? Its probably good idea to set mirrors.. Lmk if you need resource, maybe I can donate space for mirror.
u are a bit lateHi,
Is the 12.2.3 testnet still functioning? All faucets and explorers appear to be down. I found a single post that suggested using 12.3 was now required. If that's the case is it just the develop branch that needs to be pulled and are there any explorer/faucets active for it yet?
Thanks,
Guy
I've got 12.2.3 running for main network as well as a testnet node. For the work I'm doing I don't wish to test using real dash so need a testnet. Rather than running it as a private network I'd much rather have a public network to reduce the effort in what I'm doing. Both nodes (main and testnet) are synchronised with 12.2.3 nodes (878020 / 132450 block heights as of 10:52 UTC 29/05/2018) - so I am good with getting 12.2.3 up and am aware it's current stable.u are a bit late
12.2.3 is ready to download
What I'm unable to do is find anywhere I can obtain a third-party view of the network via an explorer or faucet. All the faucets / explorers are down.
It is a case of the testnet for 12.2.3 is now unsupported? If that's the case is there an alternate testnet for current develop branch and are there explorer/faucets for that?
Thanks,
Guy
899 on the way...I managed to get a hold of 250 tDASH by posting on the discord channel. I still need around 1751 tDASH. If any of you has some lying around that you can spare, I would appreciate it.
yXzShwmveriFcne1mpSobtdw5neZGMaSMQ
