eduffield
Mar 9, 2014
1,084
5,320
****** PLEASE UPDATE TO 9.4.9 OR 10.9.9 *******
We're trying to recreate a similiar environment on testnet as we have on mainnet. That means we need a substantial amount of hashing power on many different pools.
So far we've setup 2 pools:
Mpos + Stratum: http://ec2-54-198-19-83.compute-1.amazonaws.com
-- connection string: sgminer.exe -o stratum+tcp://54.198.19.83:3333 -u eduffield.1 -p x
P2Pool: http://54.200.184.132/
-- connection string: sgminer.exe -o stratum+tcp://54.200.184.132:18998 -u mt2ScQSwpsohN8KC9CuFGCuCuvyJkCY8iEn1K5Y5JGe5svtfmrJ6J9McsZPJdWXPvuRq -p 1
NOMP: http://54.183.73.24/ (Thanks Chaeplin!)
-- connection string: sgminer.exe -o stratum+tcp://54.183.73.24:3333 -u
Block Explorer: http://23.23.186.131:1234/chain/DarkCoin
How can you help?
1.) Point some hashing power at once of the pools!
2.) Run the "forkfix" branch on testnet: https://github.com/darkcoinproject/darkcoin/commits/forkfix
Binaries (stable)
http://www.darkcoin.io/downloads/forkfix/darkcoin-qt
http://www.darkcoin.io/downloads/forkfix/darkcoind
RC3 Binaries ( masternodes )
http://www.darkcoin.io/downloads/rc3/darkcoin-qt
http://www.darkcoin.io/downloads/rc3/darkcoind
If you get on a different chain than the blockchain explorer or get stuck please send me your debug.log
Thanks everyone,
The Darkcoin Team
donho
96
20
failed to connect to stratum+tcp://54.198.19.83:3333
eduffield
Mar 9, 2014
1,084
5,320
the stratum pool should be working now. I'm getting an error on the p2pool and I asked dstorm to look at it.
chaeplin
Mar 29, 2014
749
356
-o stratum+tcp://54.200.165.131:18998 -u mt2ScQSwpsohN8KC9CuFGCuCuvyJkCY8iE -p x
is correct syntax
minersday
77
19
I setup P2Pool tDRK stratum+tcp://cryptowins.com:18998
and throwed some hashing power into it atleast for a while..
getting
self.type, self.value, self.tb)
2014-05-31 19:46:13.031676 > File "/var/tmp/p2pool/p2pool-drktest/p2pool/util/jsonrpc.py", line 133, in _http_do
2014-05-31 19:46:13.031703 > raise Error_for_code(resp['error']['code'])(resp['error']['message'], resp['error'].get('data', None))
2014-05-31 19:46:13.031730 > p2pool.util.jsonrpc.NarrowError: -22 Block decode failed
with the p2pool..
connected to 54.200.165.131
minersday
77
19
getting
with the p2pool..
darkcoind:
2014-05-31 16:48:47 ThreadRPCServer method=submitblock
2014-05-31 16:48:47 received: block (405 bytes)
2014-05-31 16:48:47 ProcessMessages(block, 405 bytes) : Exception 'CDataStream::read() : end of data' caught, normally caused by a message being shorter than its stated length
2014-05-31 16:48:47 ProcessMessage(block, 405 bytes) FAILED
2014-05-31 16:48:48 received: getheaders (37 bytes)
2014-05-31 16:48:48 getheaders 11807 to 00000000f1c42ba0862f8509fc7fec2442a9b41f79a3c029140bf9b5f166bb8f
2014-05-31 16:48:48 sending: headers (83 bytes)
Propulsion
The buck stops here.
Feb 26, 2014
1,008
468
darkcoind:
To fix:
cd p2pool-dark
git clone https://github.com/darkcoinproject/xcoin-hash.git
cd xcoin-hash
sudo python setup.py install
minersday
77
19
2014-05-31 16:59:32 ThreadRPCServer method=submitblock
2014-05-31 16:59:32 received: block (405 bytes)
2014-05-31 16:59:32 ProcessMessages(block, 405 bytes) : Exception 'CDataStream::read() : end of data' caught, normally caused by a message being shorter than its stated length
2014-05-31 16:59:32 ProcessMessage(block, 405 bytes) FAILED
2014-05-31 16:59:35 connection timeout
and my testnet wallet at block
"blocks" : 11809,
"currentblocksize" : 1000,
"currentblocktx" : 0,
"difficulty" : 0.89074796,
"errors" : "",
"generate" : false,
"genproclimit" : -1,
"hashespersec" : 0,
"networkhashps" : 1838283,
"pooledtx" : 0,
"testnet" : true
while block explorer at 11809
and p2pool at 11810 ?
minersday
77
19
nope still in debug.log entries coming
14-05-31 17:11:18 ProcessMessages(block, 371 bytes) : Exception 'CDataStream::read() : end of data' caught, normally caused by a message being shorter than its stated length
2014-05-31 17:11:18 ProcessMessage(block, 371 bytes) FAILED
2014-05-31 17:11:18 received: block (371 bytes)
2014-05-31 17:11:18 ProcessMessages(block, 371 bytes) : Exception 'CDataStream::read() : end of data' caught, normally caused by a message being shorter than its stated length
2014-05-31 17:11:20 ThreadRPCServer method=submitblock
2014-05-31 17:11:20 received: block (371 bytes)
2014-05-31 17:11:20 ProcessMessages(block, 371 bytes) : Exception 'CDataStream::read() : end of data' caught, normally caused by a message being shorter than its stated length
2014-05-31 17:11:20 ProcessMessage(block, 371 bytes) FAILED
2014-05-31 17:11:22 connection timeout
2014-05-31 17:11:23 trying connection 98.165.130.67:19999 lastseen=1.0hrs
2014-05-31 17:11:24 received: ping (8 byt
Propulsion
Feb 26, 2014
1,008
468
Use forkfix branch off of github.
minersday
77
19
the forkfix daemon
2014-05-31 17:24:20 ThreadRPCServer method=submitblock
2014-05-31 17:24:21 ThreadRPCServer method=submitblock
2014-05-31 17:24:21 received: block (405 bytes)
2014-05-31 17:24:21 ProcessMessages(block, 405 bytes) : Exception 'CDataStream::read() : end of data' caught, normally caused by a message being shorter than its stated length
2014-05-31 17:24:21 ProcessMessage(block, 405 bytes) FAILED
2014-05-31 17:24:23 ThreadRPCServer method=submitblock
2014-05-31 17:24:23 connection timeout
Propulsion
Feb 26, 2014
1,008
468
the forkfix daemon
Alright so just to double check you followed these steps?
cd p2pool-drk
make
cd darkcoin-subsidy-function
cd ..
cd xcoin-hash
If so, then it should work.
minersday
77
19
2014-05-31 17:49:02 ThreadRPCServer method=submitblock
2014-05-31 17:49:02 ThreadRPCServer method=getblock
2014-05-31 17:49:02 received: block (405 bytes)
2014-05-31 17:49:02 ProcessMessages(block, 405 bytes) : Exception 'CDataStream::read() : end of data' caught, normally caused by a message being shorter than its stated length
2014-05-31 17:49:02 ProcessMessage(block, 405 bytes) FAILED
2014-05-31 17:49:03 connection timeout
2014-05-31 17:49:05 trying connection 188.226.189.235:19999 lastseen=195.9hrs
2014-05-31 17:49:05 received: ping (8 bytes)
2014-05-31 17:49:05 sending: pong (8 bytes)
2014-05-31 17:49:06 ThreadRPCServer method=submitblock
2014-05-31 17:49:06 received: block (405 bytes)
2014-05-31 17:49:06 ProcessMessages(block, 405 bytes) : Exception 'CDataStream::read() : end of data' caught, normally caused by a message being shorter than its stated length
2014-05-31 17:49:06 ProcessMessage(block, 405 bytes) FAILED
minersday
77
19
cd p2pool-drk
make
cd ..
cd xcoin-hash
I have the latest forkfix daemon, with the p2pool-drk on testnet, but still that error..
and throwing some hashing power to that p2pool.
Propulsion
Feb 26, 2014
1,008
468
Not sure then. The testpool p2pool was built using those instructions above. I was still receiving some errors occasionally, but not the CDdataStream one.
Does the daemon have active testnet connections?
minersday
77
19
darkcoind --datadir=/xxxx/darkcointest --conf=/xxxxx/darkcointest/darkcoin.conf --testnet getaccountaddress 0
testnetaddr: mtPDe3eMkhsDfFTJznm5kubrSpz1uKRqkz
and using that address as fee payment address on the p2pool.
and the address on miners is also that addr..
minersday
77
19
getinfo
"version" : 90411,
"protocolversion" : 70015,
"walletversion" : 60000,
"balance" : 0.00000000,
"blocks" : 11842,
"timeoffset" : 0,
"connections" : 10,
"proxy" : "",
"difficulty" : 1.95213130,
"testnet" : true,
"keypoololdest" : 1401551609,
"keypoolsize" : 101,
"paytxfee" : 0.00000000,
"mininput" : 0.00001000,
"errors" : ""
