v0.10.15.x Testing
illodin
122
71
78
Actually we are in search for a group of people who will compile darkcoin independently from us - and confirm the official build result. If you are interested and like to contribute PM me :)
Does it compile with Visual Studio? If it would, you'd easily get many people to confirm the result.
illodin
122
71
78
I can run testnet masternodes on my regular masternode servers simultaneously with main net masternodes, right? All I just need to do is open the additional port and use the -datadir param?
flare
2,286
2,404
Germany
Right, you need to open port 19999/TCP and use different datadir - or better: create another user for exclusive use for testnet on the server, that way you have better separation of concerns.
moli
3,255
1,830
Can Visual Studio 6 Professional Edition be used to compile darkcoin?
TanteStefana
2,871
1,863
Sorry for being a thick brunette but I thought it could only be compiled in QT? Or are you talking about the daemon?
And what are gitian cross compiles? Is that a compiler? I wanna learn (sorry for all the Qs)
flare
2,286
2,404
Germany
QT a cross platform library for C++ GUI development. So it all boils down to compile C++ source codes - regardless of darkcoin-qt or darkcoind :)
g8F98FF3gjafogj4
151
84
188
Getting a need 6 confirmations on vin error which i know is false. Started with new wallet.dat and will report back.
Edit: weirdest thing about it is, i forgot to update darkcoind before running on testnest, and MN started proper. Then I updated darkcoind and even though I had 3 x 1000 vins, couldn't get past error message regardless of time/effort.
3,639
3,537
Could be because of https://darkcointalk.org/threads/v0-15-testing.2611/page-2#post-24416
Waited till 200 and it started as it should. I didn't try to start somewhere in between though, I was sleeping :)
Reactions: g8F98FF3gjafogj4
kryptofoo
114
36
78
Germany
after starting darkcoin daemon, my testnet masternode is printing messages in the console like this "nBlockHeight2 44492 44679" it never used to do this. Is this expected behavior?
Walter
234
220
Looking good so far, more masternodes!
[email protected]:~$ ./darkcoind masternode list
"23.23.186.131:19999" : 1,
"108.61.198.220:19999" : 1
[email protected]:~$ ./darkcoind masternode winners
"44514" : "n2DKaeDaCftqSszV8bURcmSsQhyryGU37B",
"44515" : "n2DKaeDaCftqSszV8bURcmSsQhyryGU37B",
"44516" : "n3477ZfbKrovCAZ8WgBHHk1f9YwzWgjJ3o",
"44517" : "n3477ZfbKrovCAZ8WgBHHk1f9YwzWgjJ3o",
"44518" : "n2DKaeDaCftqSszV8bURcmSsQhyryGU37B",
"44519" : "n3477ZfbKrovCAZ8WgBHHk1f9YwzWgjJ3o",
"44520" : "n2DKaeDaCftqSszV8bURcmSsQhyryGU37B",
"44521" : "n2DKaeDaCftqSszV8bURcmSsQhyryGU37B",
"44522" : "n3477ZfbKrovCAZ8WgBHHk1f9YwzWgjJ3o",
"44523" : "n2DKaeDaCftqSszV8bURcmSsQhyryGU37B",
"44524" : "n3477ZfbKrovCAZ8WgBHHk1f9YwzWgjJ3o",
"44525" : "n3477ZfbKrovCAZ8WgBHHk1f9YwzWgjJ3o",
"44526" : "n2DKaeDaCftqSszV8bURcmSsQhyryGU37B",
"44527" : "n3477ZfbKrovCAZ8WgBHHk1f9YwzWgjJ3o",
"44528" : "n2DKaeDaCftqSszV8bURcmSsQhyryGU37B",
"44529" : "n2DKaeDaCftqSszV8bURcmSsQhyryGU37B",
"44530" : "n2DKaeDaCftqSszV8bURcmSsQhyryGU37B",
"44531" : "n3477ZfbKrovCAZ8WgBHHk1f9YwzWgjJ3o",
"44532" : "n2DKaeDaCftqSszV8bURcmSsQhyryGU37B",
"44533" : "n3477ZfbKrovCAZ8WgBHHk1f9YwzWgjJ3o",
"44534" : "n2DKaeDaCftqSszV8bURcmSsQhyryGU37B",
"44535" : "n3477ZfbKrovCAZ8WgBHHk1f9YwzWgjJ3o",
"44536" : "n2DKaeDaCftqSszV8bURcmSsQhyryGU37B",
"44537" : "n3477ZfbKrovCAZ8WgBHHk1f9YwzWgjJ3o",
"44538" : "n2DKaeDaCftqSszV8bURcmSsQhyryGU37B",
"44539" : "n2DKaeDaCftqSszV8bURcmSsQhyryGU37B",
"44540" : "n3477ZfbKrovCAZ8WgBHHk1f9YwzWgjJ3o",
"44541" : "n2DKaeDaCftqSszV8bURcmSsQhyryGU37B",
"44542" : "n3477ZfbKrovCAZ8WgBHHk1f9YwzWgjJ3o",
"44543" : "n3477ZfbKrovCAZ8WgBHHk1f9YwzWgjJ3o"
I'll bolt on a tMN to my VPS this morning. Quick question guys, can I run a tMN on the same server as my live MN? I'd be using a different user profile obviously, but would I need an additional IP? I'd have thought I'd be ok as testnet runs on a different port?
Walter
thelonecrouton
1,135
813
I PM'd Evan about the number of confirmations, as I couldn't figure out what else I was doing wrong, and he confirmed that yes, you now need 200 confirms, due to tx malleability. (Forthcoming InstanTX?) Crouton testnet MN 176.126.247.191 now started, after 6 hours sleep waiting for the blockchain to roll by...
successfully started masternode
[email protected]:~/.darkcoin# ./darkcoind masternode list
  "108.61.198.220:19999" : 1,
  "198.50.148.87:19999" : 1,
  "92.222.10.179:19999" : 1,
  "50.248.181.2:19999" : 1,
  "54.68.81.45:19999" : 1,
  "54.68.84.193:19999" : 1,
  "54.68.88.75:19999" : 1,
  "54.68.83.84:19999" : 1,
  "188.226.223.5:19999" : 1,
  "188.226.248.36:19999" : 1,
  "178.62.203.249:19999" : 1,
  "188.226.225.170:19999" : 1,
  "176.126.247.191:19999" : 1
flare
2,286
2,404
Germany
For reference, this is where the number of confirmations was changed from 6 to 200 - which means the error message is misleading and WRONG.
https://github.com/darkcoin/darkcoi...eff6#diff-e8db9b851adc2422aadfffca88f14c91L44
Filed it as bug in JIRA :)
http://jira.darkcoin.qa/browse/DRK-97
flare
2,286
2,404
Germany
Walter
Yes, you can run a tMN on the same machine as your mainnet nodes. Testnet Masternodes use port 19999.
So just
- create a new user
- switch to this user
- create ~/.darkcoin/darkcoin.conf with testnet=1
- start darkcoind
Additionally you'll have to open port 19999/TCP to 0.0.0.0 on your firewall/AWS security group.
Reactions: Walter
Walter
234
220
So just
- create a new user
- start darkcoind
Thanks Flare, so just follow the same procedure as for live MN just put testnet=1 in the config. Cool. I've got two IPs on my vps so I'll set up two tMN's :)
Walter
Reactions: flare
3,639
3,537
progress bar is strange
2.00000002 / 3 * 100% != 100% imho :)
TanteStefana
2,871
1,863
Ok, so I was in bed trying to sleep when I last posted, so I'm just trying to set up my masternodes now. I read we now need to wait 200 confirmations before we can start them, however, my wallet says 6 confirmations are needed, and I have 15 so... since I expected the error, no problem, but the notification in the qt wallet is incorrect :D
HinnomTX
166
196
This bug is being tracked here:
g8F98FF3gjafogj4
151
84
188
Hey guys, have what seems to be a pretty serious issue to report. Last night I took a couple masternodes from mainnet to testnet, was confused about 200 confirmations, and left the not-activated tmasternodes running to support the network anyway. I noticed on poolhash today that they were both showing as active on mainnet, which I thought was odd. Checked them on drk.mn and they showed as active but with port closed. Sort of shrugged it off, until I just received a payment to one on mainnet, just a few minutes ago.
Walter
234
220
I *think* i now have two test masternodes running on my VPS. Set them up the same as my mainnet ones (cold windows wallet). How do I check that they are now active? I've got 'masternode successfully started' on my windows wallet when activating for both but when I do a 'masternode list' my IP's don't appear in the list count... Sorry for the dumb question!
Walter
