Tien Nguyen
5
Yes, I followed all the guide in this thread to set up masternode. I hired Linux server on Vultr.com and did setting up steps on it to link masternode with the QT wallet. Bhkien, are you successful in setting up masternode? If yes, please guide me step by step to finish it. Thanks !
bhkien
465
287
Canada
vietriches.com
If you are setting up Dash masternode you can use Dashman for much easier.
But I don't know about setting up masternode for other coins.
europound
123
72
horrible tutorial, so many bells and whistles and gimmicks, 90% of water :(
impossible to follow
TaoOfSatoshi
2,841
2,650
Dash Nation
www.dashnation.com
I’m sorry my guide was unable to meet your needs. It has, however, helped countless individuals with setting up their node, so someone is able to follow it! :) Do you have any specific critiques I could use to improve it?
everywherebrand
I think I manage to solve my issue by relaunching the masternode once I fixed the sentinel folder in my crontab.
I'll see in a few hour if it's still alive.
Have a nice day.
HI there - interested in setting up a masternode here and have a Gigabyte P55W V6-CF1 GTX 1060 6GB GDDR5, 15.6" IPS LED, i7 6700HQ Gaming Laptop - will that be enough? Thanks
Stuart Rolinson
12
6
Thanks for the great guide. One question, as the value of Dash increases, has there been any thought to reducing the number of coins that need to be held from 1000?
europound
123
72
Do Youtube Tutorial
theatab
14
it is getting harder and harder to keep running the MNs continuously for 8-10 days! even in vultr's vps!
is there a plan to make the payments more often? like every 3-4 days?
thanks
strophy
Feb 13, 2016
791
517
163
Unfortunately that is impossible, since only one masternode can be paid in each block, and each block takes 2.5 minutes. The payment interval is simply a function of the number of masternodes on the network.
theatab
14
then we just have to pay 2 or more MNs in each block ;)
nothing is impossible for genius programmers ;)
Sven
71
38
Or you could just upgrade to better hardware.
And if you can't afford better hardware with your earnings, then you'll have to drop out and fewer Masternodes means faster payments for the rest of us. Problem solved! :)
theatab
14
By better hardware you mean better vps? even the best vps out there has not 100% uptime!
by waiting 10 days to receive the payment is not the best policy!
Sven
71
38
Yes. Or dedicated servers. Whatever it takes.
The payment is meant to compensate for your expenses, nobody is guaranteeing you a certain level of profit beyond that. In fact, reward payments will decrease over time as the block reward gets reduced every year.
And you can expect that, as long as there's good money to be made, more and more people will launch masternodes to get a slice of the pie. Right now, we still have the 1000-Dash hurdle to prevent an outright rush, but fractional ownership of masternodes is already in development. Then you can pay in whatever you can afford and get your share of the reward. Expect the number of nodes to skyrocket and times between payouts to get longer and longer.
That process will only stop once an equilibrium is reached where it roughly costs as much to run a masternode as you can generate income from it. At that point, only those with better, more stable and more cost-efficient hardware will still be profitable. In fact, the roadmap is already talking about "masternode-specific hardware with custom requirements". Low-end VPSs and Raspberry Pies will be squeezed out. So invest to upgrade or throw in the towel.
Rajak
6
Hello, thank you for material i used it and it worked brilliant.
I have 2 questions:
1) How an i set up 2 MN for 1 wallet?
in masternode.conf (for dash qt) i made settings like this
MN900 MN-ServerIP:9999 PrivateKey1 TransactionNumber1 0
MN901 MN-ServerIP:9999 PrivateKey2 TransactionNumber2 0
and dash.conf in remote server (MN server) looks like
rpcuser=randomname
rpcpassword=randompassword
rpcallowip=127.0.0.1
listen=1
server=1
daemon=1
maxconnections=24
masternode=1
masternodeprivkey=PrivateKey1
externalip=MN-ServerIP
rpcuser=randomname
listen=1
server=1
daemon=1
maxconnections=24
masternode=1
masternodeprivkey=PrivateKey2
but it doesnt worked. can someone help me?
and second question is:
what is status : Not capable masternode: Masternode in POSE_BAN state
thank you
phillipe
Hello,
Is it possible to setup a masternode in "regtest" mode?
I generated a masternode key and obtained the Tx Id (1000 dash). I get the following message when after the command "masternode start-alias <alias>"
"alias": "mn1",
"result": "failed",
"errorMessage": "Sync in progress. Must wait until sync is complete to start Masternode"
I think the issue may be with the server IP address in the dash.conf and masternode.conf. Since I'm running regtest, I just my localhost address and a random port. I've tried 127.0.0.1 and just plain removing it; still get the same message. Any help would be appreciated.
Thanks,
Phillipe
TaoOfSatoshi
2,841
2,650
Dash Nation
www.dashnation.com
Hello,
"alias": "mn1",
"result": "failed",
Thanks,
Phillipe
That’s a common message you get when your local wallet has not fully updated before you issue the start command. Simply wait for the local wallet to fully sync and reissue the command.
qwizzie
2,019
1,199
I have 2 questions:
rpcuser=randomname
listen=1
server=1
daemon=1
maxconnections=24
masternode=1
rpcuser=randomname
listen=1
server=1
daemon=1
maxconnections=24
masternode=1
thank you
Regarding question 1 : Do they have seperate IP Addresses ?
Regarding question 2 : Looks like something in your setup causes the network to ban your masternode(s).
Edit : never mind, i see you got your answers here : https://www.dash.org/forum/threads/2-masternodes-for-1-wallet.30437/
phillipe
The synchronization is not progressing (stuck at 25% at the bottom of dash-qt). It may have to do with the fact there are no peers in -regtest. I'm thinking may just have to -testnet to for my testing. Thank you though!
