Acedian
243
71
XeMABbcebB5yeZH2HxsV7yLNJA9hbzMgpz
Thank you for the update. I know you are a busy guy, I appreciate you taking the time to update this.
NewDashUser
6
@NewDashUser, I am wondering that the message "Masternode successfully started" you see on the putty screen. Starting masternode should be done from your local Dash Core wallet, that controls the private key holding your 1000 Dash collateral (Step 7 of Tao's manual). So either you keep your Dash collateral on the remote server's wallet (which is not safe) or you have done this step on the wrong machine (remote instead of local).
Dear Bertrand256,
I did exactly as mentioned by Tao's guide, which means I did start the masternode using step 7 from Tao's manual. In that case I am assuming my Dash Collateral remains in my local wallet ?? Is my assumption correct ? Sorry, my computers skills are not that great to fully understand this. Now when i open my local wallet I can see all my Dash including collateral.
And yes "Masternode successfully started" shows up in Putty screen. According to step 10 of Tao's guide.
And yesterday while going through my steps again one by one. I was able to restart my Masternode and it seems to be Active and running since. But I did something different as mentioned below:
Initially when I created "dashcore" folder on my server. I did not use "." in front of "dashcore". Infact my server did not allow me to create ".dashcore" folder, so I had to remove dot "." from the front and just name it "dashcore" instead of ".dashcore". And there after I kept using "dashcore" everywhere through the guide. But one place i forgot in step 9:
* * * * * cd /home/YOURUSERNAME/.dashcore/sentinel && ./venv/bin/python bin/sentinel.py 2>&1 >> sentinel-cron.log
So once I removed that dot "." in front of "dashcore", and restarted my masternode from local wallet things seems to be working.
Now the questions are:
What does step 9 do ?
Why my server did not allow me to use dot "." in front of "dashcore" folder name ?
Does, not using dot "." in folder name make any difference ?
Is there anything I might be missing or ignoring which might have impacted ?
Thanks a lot for your support on this...
Regards
Bertrand256
264
328
123
XwZzf7yqYoUBnDFqE7r3zuNmpwKo1CYLMC
@NewDashUser, Step 9 is used to execute additional program (sentinel) cyclically, which is required for the masternode to be perceived by the network as active. If you do not do so, your masternode will soon receive WATCHDOG_EXPIRED status and will be removed from the payment queue.
The leading dot in the directory name on linux systems causes the directory to be hidden - it will not be shown when using the ls command without additional argument. To see it use: ls -a
The leading dot is very important - you must treat it as part of the name. At startup, dashd checks to see if the .dashcore directory exists. If not, it is created with the default configuration files.
It is very possible that the .dashcore directory existed when you tried to create it, so that's why linux returned an error.
NewDashUser
6
Dear Bertrand256,
Oh yes...i can see the hidden folder .dashcore directory now, now what shall I do ? should i do everything again with .dashcore i mean go back to the original guide and do everything again ? If yes, how shall I stop everything and clean it to do all over again ?
Bertrand256
264
328
123
@NewDashUser, if you indeed succesfully started your masternode and dashninja reports its status as active then you probably has correct configuration in the .dashcore directory, so repeating steps related to starting masternode will not be necessary.
Instead I suggest you to:
  1. make sure, that your .dashcore/dash.conf file contains the correct values; in fact it should, because otherwise your masternode wouldn't be active (lack of private key in the config)
  2. if you don't have sentinel installed inside the .dashcore directory (ls ~/.dashcore/sentinel) I suggest you to repeat the steps: 2-6 and 8-9;
  3. delete the old dashcore (without leading dot) directory, just to avoid confusion in the future
NewDashUser
6
Dear Bertrand256,
- As you said I went in and updated .dashcore/dash.conf, in fact it was already correct (i remember originally saving dash.conf in .dashcore, but wondered how that happened since i couldnt see .dashcore. Later I created dashcore/conf assuming I was supposed to used dashcore instead of .dashcore), may be thats why my node started at in the first place. But i guess did not continue since i did not have sentinel in the correct folder.
- Now I installed sentinel in .dashcore director as you said and everything seem to be working as expected.
- I also deleted old dashcore directory as you suggested.
I really really appreciate your support on this. Without your help it was never possible. You are a champ.
Now feel the need of learning more of Unix/Linux.
Also I think Tao's guide need to be updated to clear the ".dashcore" confusion. I wonder how that directory got created without me creating it ? Or may be I made some mistake in following the steps.
Regards..
Bertrand256
264
328
123
Dashd, at startup, creates a .dashcore directory if it does not exist, then it creates a dash.conf file with the default content (in fact it is empty) and downloads the Dash blockchain into it.
Acedian
243
71
Remember, Linux is only free if your time is worthless.
Only joking, I suck at linux too, that is why I have @splawik21 host my masternode for me :D
Sorry for the irrelevant post. Bump for answers?!
Bertrand256
264
328
123
cd .dashcore
./dashd
Igot an error:
-bash: ./dashd: No such file or directory
Can you paste the results of the following command?
ls -al ~/.dashcore/dashd
Bertrand256
264
328
123
@ac0 It looks as if you were trying to execute a binary version for another hardware architecture, for example binary for Intel x86 on Raspberry Pi or 64-bit version on a 32-bit machine.
Please submit the results of the following two commands:
uname -a
readelf -a ~/.dashcore/dashd | grep interpreter
Bertrand256
264
328
123
and another two commands:
ldd /home/pi/.dashcore/dashd
file /home/pi/.dashcore/dashd
Bertrand256
264
328
123
I got some kind of Python error: [code said:
The path python2 (from --python=python2) does not exist
[/code]
Make sure you have installed python by issuing the following command: which python
If there is (the command will return a path), then there is no symbolic link named python2 indicating the location of Python. Please post the result.
Bertrand256
264
328
123
So you need to install python first:
sudo apt-get install python
Bertrand256
264
328
123
I got a security question: I think it will be interesting to only allow ssh from my IP, is it a bad idea? The problem is that if my IP changed there will be no way to reset my connection with my vult account...
Is there a way to be aware of other connection attempt from other IP?
Yes, its a good idea. I am not a vultr customer, but with most similar vendors it is possible to login using the web console, that you can use to change firewall rules to your new IP.
Bertrand256
264
328
123
@ac0
If you'd like to block incoming SSH connections for everyone except your IP address:
ufw allow from YOUR_IP proto tcp to any port 22
ufw delete limit 22/tcp
BTW, currently 1000 Dash is worth quite a lot of money, so for security reasons you might want to consider holding your masternode collateral on a hardware wallet like Trezor, instead of on a software wallet.
Reactions: UdjinM6
Bertrand256
264
328
123
Andmy node indicate "watchdog_expired"
I do not have much time now, so I would just like to point out that WATCHDOG_EXPIRED after so long time would mean that you have a problem with the peridic execution of the "sentinel". Look at the definition of a sentinel's crontab. If you cannot handle it, I will try to help you within a few hours.
Bertrand256
264
328
123
@ac0, you do not need restart your dashd; if that was the only problem you should see your masternode active in about an hour or less.
johnwhitestar
On vultr they do not allow to have multiple VPS accounts, what account should be used if someone wants to set up more than one masternode?
boats
No it has never worked. I just got to the step in the guide where Im suposed to launch it for the first time.
You are now ready to start the beating heart....
Run your dashd daemon:
cd .dashcore
./dashd
You will see the message "Dash Server Starting". Let it sync while you move on to the next step.
NewDashUser
6
Dear Bertrand256,
You help me setup my masternode earlier. After 5 weeks i transferred extra dash from my masternode account to other address. But now it seems my masternode stopped. In Dash Ninja, It says: Status: Inactive(0%), and Port check status: Closed (Connection refused), why is that ?
Masternode port got closed a day after extra dash were transfered... so not sure if it was due to transferring of dash. I have coin control on in my wallet and 1000 dash locked.
Please suggest...
Acedian
243
71
1000 Dash ... huh, I wish I have them
This limit was probably set when Dash was still very low ..
Yes and no. It scales well with increase usage to prevent attacks on the network.
ribbit
7
Hello,
Thanks for the guide!
Is it possble to have payments go to a different wallet versus the collateral wallet?
i.e I would like to have one wallet holding the 1000 DASH collateral (deposit address) and a different wallet that receives the payments (receiving address).
TIA
Tien Nguyen
5
Hello,
I reached to the last step to restart QT wallet to activate masternode, but I received the error message: Invalid port in the masternode.conf, port must be 9399 for mainnet, and the wallet cannot be opened. I changed the port to 9399 as requirement, but the result when I restarted the wallet still like that. I do not know how to fix this error because everything seems to be all right. Please help me ! Thanks.
3,639
3,537
Hello,
9999, not 9399
Tien Nguyen
5
Yes, I know 9999 for DASH, but I followed the guide to set up masternode for new same kind DAS, and the suggested port is 9399. But although I set 9399 in masternode.conf as system requirement, the error announcement still happened when I restarted the wallet. I was stucked in the last step, and did not know the reason why.
