Hello, it is a few days that my masternode keep dropping off the list. The first time I had to restart it. The next ones the I could not understood what the problem was since it seemed to be running ok. It was synced, and sentinel did not show any problem. Eventually I discovered in the sentinel log this final message:
But when we install the masternode I don't remember that we are given any control over a DB (like when you install a wordpress, for example). So I am lost as to what I should do to make sure the masternode has all the permissions it need (to operate on the DB and in particular to drop tables).
What should I do? (Right now this masternode has been going on without a payment for 13 days. If we could fix the situation without going back to the beginning of the queue I would appreciate.)
Many thanks.
Actually When I run sentinel I get an error. Not sure why I did not notice before:
File "bin/sentinel.py", line 244, in <module>
main()
File "bin/sentinel.py", line 191, in main
perform_dashd_object_sync(dashd)
File "bin/sentinel.py", line 24, in perform_dashd_object_sync
GovernanceObject.sync(dashd)
File "lib/models.py", line 87, in sync
(go, subobj) = self.import_gobject_from_dashd(dashd, item)
File "lib/models.py", line 142, in import_gobject_from_dashd
subobj, created = subclass.get_or_create(object_hash=object_hash, defaults=subdikt)
File "/home/Pietro/.dashcore/sentinel/venv/lib/python2.7/site-packages/peewee.py", line 4800, in get_or_create
return query.get(), False
File "/home/Pietro/.dashcore/sentinel/venv/lib/python2.7/site-packages/peewee.py", line 3090, in get
return next(clone.execute())
File "/home/Pietro/.dashcore/sentinel/venv/lib/python2.7/site-packages/peewee.py", line 2267, in next
obj = self.iterate()
File "/home/Pietro/.dashcore/sentinel/venv/lib/python2.7/site-packages/peewee.py", line 2253, in iterate
return self.process_row(row)
File "/home/Pietro/.dashcore/sentinel/venv/lib/python2.7/site-packages/peewee.py", line 2331, in process_row
setattr(instance, column, func(row))
File "/home/Pietro/.dashcore/sentinel/venv/lib/python2.7/site-packages/peewee.py", line 1072, in python_value
return decimal.Decimal(str(value))
File "/usr/lib64/python2.7/decimal.py", line 548, in __new__
"Invalid literal for Decimal: %r" % value)
File "/usr/lib64/python2.7/decimal.py", line 3872, in _raise_error
raise error(explanation)
decimal.InvalidOperation: Invalid literal for Decimal: '47,5'
[error] Could not drop tables: database is locked
Many thanks.
[[email protected] sentinel]$ venv/bin/python bin/sentinel.pyTraceback (most recent call last):
main()
