How can I check the balance of my Dash paper wallet using the public key?
Discussion in 'Miscellaneous Dash Support Questions' started by davidlkyoung360, Mar 14, 2017.
  1. davidlkyoung360
    davidlkyoung360 New Member
    Mar 12, 2017
    Hello All! I just sent some Dash from Poloniex to my Dash paperwallet address, and I am eager to double check that the balance is in there! Is there a blockchain.info equivalent for Dash where I can enter the public address into a field on a website, and then view the balance of that address? Or is there another way to check balance of a Dash paper wallet address?
    While I know how to sweep the paper wallet address with the Coinomi wallet app on my android phone, and transfer the balance back out onto my Coinomi wallet for use, I don't know how to check the balance of my paper wallet address using the public key. Can sombody please give me some help? Thank you so much for your kind attention!
    Davidlkyoung360
  2. Balych
    Balych Active Member
    Sep 12, 2015
    365
    211
    Dash Address:
    • Like Like x 3
  3. davidlkyoung360
    Mar 12, 2017
    Hi Balych! Thank you so very much! I just checked and it's there! I really appreciate your kind help! Thanks! All the best to you!
    Davidlkyoung360
    • Like Like x 2
  4. Jindivik
    Jindivik New Member
    Oct 11, 2017
    Baluch I transferred some Dash to a couple of paper wallets and wanted to check the balances.
    I opened the link you gave to davidlkyoung360 and entered the public keys into Dash Block Explorer.
    Each time the result is "address not seen on the network".
    Any suggestions?
  5. Balych
    Sep 12, 2015
    365
    211
    Dash Address:
    From where you transferred them? You have transactions IDs?
  6. Jindivik
    Jindivik New Member
    Oct 11, 2017
    Thanks for getting back to me, Balych. From what I can understand of the Dash Transaction details page:
    To
    19s5nX1zsQXncGcrBhEC1ZeqdbW2zg2qwE
    From
    XnrcAGKZi7opj5FQpe8x3N66itYz74Gwta
  7. Balych
    Sep 12, 2015
    365
    211
    Dash Address:
  8. Waccery
    Waccery New Member
    Oct 17, 2017
    10
    Nice , i will try it next time .
  9. shadownight80
    shadownight80 New Member
    Dec 8, 2017
    hello and thanks for you time i am trying to Check my balance on my paper wallet by going to explorer.dash.org Dash Block Explorer.
  10. strophy
    strophy Administrator
    Feb 13, 2016
    684
    385
    Have you sent any dash to the address? It will only appear on the network after it holds some funds.
  11. shadownight80
    Dec 8, 2017
    Thank you yes I sent find and received a confirmation email
  12. Klemen
    Klemen New Member
    Dec 20, 2017
    Doesn't Dash have strict privacy? If I send 1DSH to my friend. Can he check my balance or can I check his balance?
  13. strophy
    Feb 13, 2016
    684
    385
    #13 strophy, Dec 21, 2017
    • Agree Agree x 1
  14. sweet.candy1568
    sweet.candy1568 New Member
    Jun 15, 2018
    7
    you can not check by public key (only Address, transactionID can check on explorer.dash.org)
    • Disagree Disagree x 1
  15. rohanjcp
    rohanjcp New Member
    Jan 5, 2019
    If you can only see amount of each transactions only, is there a way to check the whole amount?
