Help me setting up the masternode, bitcoind won't start.
pyc
24
Hello!
I'm using Debian 7 and I did downloaded pre-comiled http://www.darkcoin.io/downloads/rc/darkcoind because as far as I understand, that RC versions are needed to run masternode, and it's not opensourced yet. Correct me if I'm wrong.
When I try to run it, it outputs this:
./darkcoind: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.15' not found (required by ./darkcoind)
./darkcoind: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by ./darkcoind)
Already saw somwhere that it's a bit problematic to run on Debian 7... So what's the best system for it then?
Thanks in advance...
pyc
24
Ubuntu 12.04.4 LTC, fresh and completely updated, downloaded darkcoind from http://darkcoin.io/downloads/rc/darkcoind
[email protected]:~/darkcoin$ ./darkcoind
terminate called after throwing an instance of 'std::runtime_error'
  what():  locale::facet::_S_create_c_locale name not valid
Aborted (core dumped)
Since everything is so clean and there is not help around Googling about this problem, I must ask again...
Lzeppelin
57
w00t I finally know something to help someone! Run:
sudo locale-gen en_US en_US.UTF-8
assuming you want english.
Lzeppelin
57
thats the answer for which question?
this one:
The server just does not have a locale set up, exact same thing happened to me.
pyc
24
Tried setting locale, and I still have the same error :( Anyways, thanks...
yidakee
1,812
1,168
export LC_ALL=C helped!
I had all these problems when using OSx terminal to SSH into a VPS to setup a MN. After going bonkers trying to solve all the errors, I simply installed VM Ubuntu on my Mac, killed my server and redid everything without a hick-up.
OSx terminal screws up into linux via SHH somehow. Tried for days to compile on early RC masternode testnet and almost drove me nuts. Even with these fixes I never managed to get it going properly.
