Best VPN?
fernando
Powered by Dash
1,527
2,059
My prepaid time with TorGuard is about to finish and I've been having some problems to connect lately to some of their servers, so I'm on the look for a new guardian of my browsing.
My requisites are quite easy:
-No logs
-Exit servers in many countries
-Payment with crypto. DRK would be ideal, but I can compromise to BTC.
Any recommendations?
tungfa
8,898
6,746
I am on switchVPN and they work great
but free would definitely be the best !!...>>
Reactions: fernando
GrandMasterDash
3,391
1,439
Don't use free or cheap VPNs and think carefully about company jurisdiction (not just the server locations). Don't stand in one place too long, mix it up as you go. Double check for DNS leaks, especially for linux configurations. If you're on an old distro, upgrade to something more recent as they handle VPNs and dropped connections more reliably. Change your behavour, spellings, grammer, persona on the fly. Make good use of browser privacy modes and search out how to tweak browser settings for more privacy (disabling link referers etc).
Reactions: demo
Rafass
Shenzhen - Hong Kong
rafass.com
XwgyqKfT5CEXqK8jobMUaCP22wCUxvRsyp
I'm always with my VPN on (because my location)(CN)
Using ExpressVPN several months ago, quite expensive, but works pretty decent from here. they accept BTC.
sup3r
5
I'm using torguard and everything seems fine. It's faster than other VPN I used.
ankitasharma
Many company provide vpn service so you can search on Google select good company choose this company service
Guna
19
I use ProtonVPN. You can start for free then upgrade for higher speed and all server locations
dashes
I use ExpressVPN they accept bitcoin.
Are there any VPN service that accepts dash?
dashes
This guide recommends ExpressVPN for Bitcoin which I uses: Bitcoin Services
However, I have not used any other. I think it depends mostly on where you live. CyberGhost is my friend using and NordVPN is also popular. Have anyone compared those?
joseph onuoha
The snoopers and hackers spy our web browsing history through our viral IP location. But when we use ZenMate VPN, it changes our Virtual IP location and address, due to which, access of those hackers block and now you can continue your private browsing.
strophy
Feb 13, 2016
793
518
163
Commercial VPNs are great if you are just trying to change your location to a different country. For censorship avoidance, these commercial services get targetted pretty hard. Hands down the best solution is to build your own server and run Streisand, all your devices (including Wifi router) can connect and most importantly, stay connected. Only requirement is extremely basic Linux skills and around $5 a month for Vultr hosting.
dmamigo
14
ExpressVPN and NordVPN are the two I use the most. The price of ExpressVPN is high, but never felt a downtime or any issues.
michaeltim
17
NordVPN is best however if you wanna look into more cost effective options.
BTW, going with NordVPN is suited the most as per the most positive word of mouth.
Kevinbigg
Nordvpn has an excellent support and browser extensions, and it has good reviews, they where nominated on vpn of 2018 at vpnmentor. In another forum I found this good coupon so if u considering buying you can get 70% off two years deal by entering GET after choosing the payment type.
wendell
Well, Different peoples have different choices. Express and HMA VPNs are best you can also read reviews on ReviewsDir. I recommend ExpressVPN but choices is yours.
