Before I release the New Version of the Android App on Google Play and sort of "force" 1600 users to upgrade, I would like to get feedback on how it works and looks.
https://github.com/HashEngineering/darkcoin-wallet/releases/tag/v4.18r3
Let me know your feedback. If it's positive, then I will update Google Play.
Changes include:
Dash Rebranding
InstantX support (sending only). Can't yet spend received InstantX transactions until 6 confirms.
Donation feature will be removed.
If you care to participate, let me know about these items:
1. Icon and color scheme
2. Can you send coins?
3. Can you receive coins?
4. Can you sweep a paper wallet?
5. Can you send with InstantX?
6. Can you see the value of your Dash in local currency?
7. Can you upgrade from a previous version of Darkcoin Wallet.
Receiving InstantX transactions may still be problematic. They can be received, but not spent until 6 confirms.
Good Luck. Use the software at your own risk using a minimal amount of DASH. Backup your wallet/keys before installing this or install it on a device that doesn't have the Darkcoin Wallet for android.
Once we get enough feedback and fix the bugs, we will update Google Play.
Changes include:
Dash Rebranding
