A bit of help for a mate, if you've a moment?
Discussion in 'Questions and Help' started by Xem-Rose, Oct 24, 2014.
  1. Xem-Rose
    Xem-Rose New Member
    Oct 23, 2014
    12
    I'm fairly new to DRK coin, just looking into it today. Found one faucet, which was amazing to see, and now I've set myself to mine DRK coin in this pool. However, I've a bit of an issue that would likely be considered a 'newb' question. For CPUminer, does weblogin mean your username for this site, your email, your password, or a combination? I'd like to invest in this CC as I see it going places, anyway, so please, a bit of help for a new mate on the block.
  2. thelonecrouton
    thelonecrouton Well-known Member
    Apr 15, 2014
    1,135
    813
    What software exactly are you using? Are you mining at a pool, if so which one?
    'weblogin' suggests whatever your username is at a pool, but pool users can have different workers at that pool too... basically, what is asking you for a weblogin?
  3. Xem-Rose
    Xem-Rose New Member
    Oct 23, 2014
    12
    Ah, I'm using CPUminer, or trying rather, due to Norton deleting it's files before I can exclude them. I'm reading the guide on here on how to start mining, but I intend to mine for this site's pool.
  4. Xem-Rose
    Xem-Rose New Member
    Oct 23, 2014
    12
    Due to norton, I cannot download the file in the guide or keep the text file on which version I should use for CPUminer, so there's that issue, plus it continually says something about retrying in 30 seconds, which I'm not sure is normal.
  5. Xem-Rose
    Xem-Rose New Member
    Oct 23, 2014
    12
    Also, the format is 'weblogin.username' so I'd assume it's some login.[username here]
  6. coingun
    coingun Active Member
    Jul 8, 2014
    489
    402
    Might need to turn off dat norton.
    When you are mining on pools the most common thing is to get a username to login to the site (weblogin) plus then you have to create workers. Workers help separate your mining systems logically. In the cases where you have more then one system it helps in your case it's just causing confusion. So if my weblogin I signed up with was coingun and my first worker name was 1 then I'd use coingun.1 in my mining config. I haven't actually tried to setup a miner on the dct pool so I should probably do that so it will be easier to help.
    Edit: Did some testing. Hope this helps.
    1) Create your account. (need username,password,wallet address,pin number)
    2) Login.
    3) Find My Account.
    4) Find My Workers.
    5) Create a worker (workname: 1 worker password: dct-rocks)
    Setup account and tested on a gpu miner here is the connection string:
    ./sgminer.exe -k darkcoin -o stratum+tcp://mining.darkcointalk.org:3333 -u coingun.1 -p dct-rocks
    #6 coingun, Oct 24, 2014
  7. Xem-Rose
    Xem-Rose New Member
    Oct 23, 2014
    12
    This itself is quite a bit of help. I was hesitant to ask, because since they didn't specify, I'd assume it's considered common knowledge, so thanks for helping me ^.^
  8. Xem-Rose
    Xem-Rose New Member
    Oct 23, 2014
    12
    Thanks mate, I'm trying now. It should work, so I'll assume it does, so do you have any suggestions what I should look at next around here to get more involved? Like I said, I really see think CC going places.
    Edit: Actually, it didn't work quite too well. Did you save that info as a batch file? I did, and ever after filing out the info in the miner (I downloaded the same one you used), it didn't come up.
    #8 Xem-Rose, Oct 24, 2014
  9. tungfa
    tungfa Administrator
    Apr 9, 2014
    8,961
    6,735
    remember
    there are no "stupid" questions here !!! fire away and the community (as you can see) is happy to help ...>>
    • Like Like x 1
  10. coingun
    Jul 8, 2014
    489
    402
    Example contents of a file named miner-dctpool.bat that was saved on the desktop. This also assumes you have extracted your sgminer folder to your desktop as well and it is named simply sgminer. This is a very very basic config not specifying any parameters to help speed up your GPU. I like to start with the basic's and then build from there.
    Create file named miner-dctpool.bat and put in it the following. Start copying after the --- and stop before the next ---
    set GPU_MAX_ALLOC_PERCENT=100
    set GPU_USE_SYNC_OBJECTS=1
    cd c:\users\miner01\desktop\sgminer\
    Save this file and try and run it.
  11. Xem-Rose
    Xem-Rose New Member
    Oct 23, 2014
    12
    So I got SGMiner, and it works up to this point. Does anyone know what this means and how I can fix it? http://prntscr.com/4zvlsd
  12. pbleak
    pbleak Active Member
    May 15, 2014
    399
    172
    Are you still running Norton? I suggest turning it off. Replace with the Windows antivirus which is far less touchy.
    • Like Like x 1
  13. thelonecrouton
    Apr 15, 2014
    1,135
    813
    • Like Like x 1
  14. Xem-Rose
    Xem-Rose New Member
    Oct 23, 2014
    12
    This helped a lot, however I'm now getting a HW of 11 with a H/s of 0. It also /just/ crashed, so any suggestions? http://prntscr.com/4zyjjy Just figured out how to find my graphic card, so this is it-- it's not listed on that site though, so should I just go with the config for a different device, maybe?
    #14 Xem-Rose, Oct 26, 2014
  15. Xem-Rose
    Xem-Rose New Member
    Oct 23, 2014
    12
    Trust me mate, I've noticed how touchy it is. It's deleted all my mining files three or four tymes now, and it's really unfun having it block SGMinger.
  16. pbleak
    May 15, 2014
    399
    172
    Personally I'd uninstall Norton. It does nothing the default Windows antivirus does...and that's free.
  17. Xem-Rose
    Xem-Rose New Member
    Oct 23, 2014
    12
    Aside from that, can you offer any advice for how to get my hash up from 0.0 so I can start mining?
  18. thelonecrouton
    Apr 15, 2014
    1,135
    813
    Find out what GPU you have in your box... ;)
    edit, sorry, didn't see your edit. What GPU is it then?
  19. Xem-Rose
    Xem-Rose New Member
    Oct 23, 2014
    12
    AMD Radeon HD 7340.
  20. Xem-Rose
    Xem-Rose New Member
    Oct 23, 2014
    12
    So does anyone know some settings to get my hash rate up from 0 for an AMD Radeon HD 7340?
  21. Ignition75
    Ignition75 Active Member
    May 25, 2014
    332
    214
    Just to begin with, run -g 2, --thread-concurrency 8192, -w 256. -I 16 and leave everything else standard.
    That will get you going...
  22. ProudCLown
    ProudCLown New Member
    Feb 20, 2015
    I'm new to DRK COIN entirely. Can someone point me to a thread that can help me understand how to determine approximate hash rate of a GPU before purchase?
  23. tungfa
    Apr 9, 2014
    8,961
    6,735
    mining section !
  24. ProudCLown
    Feb 20, 2015
    Thanks
    • Like Like x 1
