X11 Mining Optimisation Project
release 31 is here:
- improved groestl512 part2. faster x11,x13,x14,x15,nist5,quark etc.
- merged branch with klaus_t. Faster quark + other fixes.
- fixed crash on 960 cards. (default intensity)
1.5.31(sp-MOD) is available here: (18-jan-2015)
https://github.com/sp-hash/ccminer/releases/tag/1.5.31
The sourcecode is available here:
bitcointalk thread:
https://bitcointalk.org/index.php?topic=826901.0
x11 is now over 3MHASH on a OC(750ti) card with standard clocks. F.ex gigabyte windforce black.
Compiled for compute 50 and 52 only. The old cards will work, but you have to biuld your own binaries.
For more hash, please donate some beers to:
BTC: 1CTiNJyoUmbdMRACtteRWXhGqtSETYd6Vd
DRK: XdgfWywdxABwMdrGUd2xseb6CYy1UKi9jX
-Blakecoin 130% faster
-Fixed high reject rates and improved performance lyra2
-Corrected the stats with multiple gpu-threads -g x
-Added a 'disable extranounce subscription' swith '-e'
-Tiny speedups in most algos.
1.5.50(sp-MOD) is available here: (9-may-2015)
https://github.com/sp-hash/ccminer/releases/tag/1.5.50
Compiled for compute 50 and 52 only. The old cards might work, but you have to biuld your own binaries.
If you've done optimizations and you doubt a 40% improvement, you sir, do not only know how GCN works - you don't know your asshole from your elbow when it comes to GPUs in general. Over most relevant AMD cards, Pitcairn, Tahiti, and Hawaii, I have an average increase of 34.34% without even trying. Amatuer hour compared to what is possible.
Hey Wolf0, not cool!
Hello SP, thanks for the great work.
I´m trying to run the ccminer on two NVIDIA GRID K2, they word with regular ccminer, but your give the error:
Cuda error in func 'x11_simd512_cpu_init' at line 614: invalid texture reference
Can you help?
Thanks
Hi,
I'm with Ubuntu 14.04 and compilaton make me 2 errors.
compilation terminated.
make[2]: *** [ccminer-ccminer.o] Erreur 1
make[2]: quittant le r\Uffffffffrtoire \Uffffffff /home/...Uffffffff
make[1]: *** [all-recursive] Erreur 1
make[1]: quittant le r\Uffffffffrtoire \Uffffffff /home/...Uffffffff
make: *** [all] Erreur 2
Dependencies are installed.
Cuda 7 seems good.
I don't understand.
Some help will be welcome :-).
Hi,
Cuda 7 seems good.
I don't understand.
Hello,
I don't have any clue from your errors, how about try compile from this repo : https://github.com/tpruvot/ccminer
Look actively improving..
Good luck :)
The tpruvot version is my next try :-).
Thanks.
I've made the compilation of TPruvot : I've exactly the same 2 errors....
I've verified the dependencies : all seems good.
I've no idea...
I have :
nVidia GTX 750,
last proprietary driver 352.21,
last Cuda 7 driver.
I've no idea...
I have :
nVidia GTX 750,
last Cuda 7 driver.
are you compiling on linux or windows?
Hi,
Cuda 7 seems good.
I don't understand.
Sorry, the problem was with CUDA.
I've solved theses problems :-).
Now, the compilation work fine, just some warnings about X11 (pointers -> smaller intergers), and about SHA256.
But :
When I run my ccminer executable, he stop after 5 seconds and display this message : "Cuda error in func 'x11_simd512_cpu_init' at line 607 : out of memory."
My CUDA version is the last and recent 7.0.
What can I do ?
Any idea ?
Note : Ubuntu 14.04 + nVidia GTX 750 + CUDA 7.0
But :
What can I do ?
Any idea ?
You nVidia card may not be supported by current cuda config in your compiled ccminer, check your card's compute capability and make sure your cuda config support your card's compute capability.
I don't know where in Linux :D
