v0.10.12.x RC4 Testing
****** PLEASE UPDATE TO 9.12.6 OR 10.12.6 *******
- Fixed AutoDenominate. It seems to work pretty well now.
- Inputs that are large will be broken up automatically for denomination
- Masternodes should change every block now (missed a mod=10 last time)
- Mixing requires 5 clients to merge now, should improve anonymity.
- Mixing rounds are limited to 1000DRK, per block
Binaries (stable)
http://www.darkcoin.io/downloads/master-rc4/darkcoin-qt
http://www.darkcoin.io/downloads/master-rc4/darkcoind
RC4 Binaries ( masternodes )
Binaries (stable)
done:
"version" : 101206,
"protocolversion" : 70022,
"walletversion" : 60000,
"balance" : 14330.91276589,
"blocks" : 3692,
54.191.236.39 running 12.6 hot, local qt updated too. :)
Just curious - why the 1000DRK per block mixing limit? (If that doesn't give any secrets away.)
Ok I see a denomination.
2014-07-25 19:53:14 ProcessSyncCheckpoint: sync-checkpoint at 00000000403f7e00832c48438a3cb49f6ef38ba005e255de25e485d1bd76fe31
2014-07-25 19:53:14 !!! ENFORCING PAYMENTS 4085657524
2014-07-25 19:53:14 ProcessMessage(dmcv, 156 bytes) FAILED
2014-07-25 19:53:14 CDarkSendPool::UpdateState() == 2 | 2
2014-07-25 19:53:14 DarkSendStatusUpdate - state: 2 entriesCount: 0 accepted: -1 error:
2014-07-25 19:53:15 dmcv: rejecting masternode vote
2014-07-25 19:53:15 CDarkSendPool::UpdateState() == 2 | 2
2014-07-25 19:53:15 DarkSendStatusUpdate - state: 2 entriesCount: 0 accepted: -1 error:
2014-07-25 19:53:15 received block 00000007e54460a1f781cc9b350607c6d30cdeefd04ae21979047505ef457a32 peer=9
2014-07-25 19:53:15 CDarkSendPool::GetCurrentMasterNodeConsessus : No consessus information for block 3693
2014-07-25 19:53:15 Committing 1400 changed transactions to coin database...
2014-07-25 19:53:15 SetBestChain: new best=00000007e54460a1f781cc9b350607c6d30cdeefd04ae21979047505ef457a32  height=3693  log2_work=42,470784  tx=30335  date=2014-07-25 19:52:24 progress=0,999999
2014-07-25 19:53:15  --- strUseMasternode
2014-07-25 19:53:15 found coins 5
2014-07-25 19:53:15  vin nValue 2222200000000
2014-07-25 19:53:15 DoAutomaticDenominating Error: Found inputs too large to denominate. These must be broken up manually to use DarkSend.
2014-07-25 19:53:15 keypool reserve 6
2014-07-25 19:53:15 keypool added key 1007, size=1001
2014-07-25 19:53:15 keypool reserve 7
2014-07-25 19:53:15 CommitTransaction:
CTransaction(hash=04f5fe7c9a67512265e1a1d4f9ae23d09186198e2d43844e508dbd2a798e5e66, ver=1, vin.size=1, vout.size=2, nLockTime=0)
    CTxIn(COutPoint(94f57a1004fc534fb232f05fc41e487b6db02f7d82fb516f8898ac387a07e3d7, 0), scriptSig=304402205b55ed1053cfa0a0)
    CTxOut(nValue=8167.00000000, scriptPubKey=OP_DUP OP_HASH160 525a56addc3f)
    CTxOut(nValue=721.00000000, scriptPubKey=OP_DUP OP_HASH160 e597315d5c90)
keypool keep 7
2014-07-25 19:53:15 AddToWallet 04f5fe7c9a67512265e1a1d4f9ae23d09186198e2d43844e508dbd2a798e5e66  new
2014-07-25 19:53:15 WalletUpdateSpent found spent coin 8888.00bc 94f57a1004fc534fb232f05fc41e487b6db02f7d82fb516f8898ac387a07e3d7
2014-07-25 19:53:15 NotifyTransactionChanged 94f57a1004fc534fb232f05fc41e487b6db02f7d82fb516f8898ac387a07e3d7 status=1
2014-07-25 19:53:15 NotifyTransactionChanged 04f5fe7c9a67512265e1a1d4f9ae23d09186198e2d43844e508dbd2a798e5e66 status=0
2014-07-25 19:53:15 NotifyTransactionChanged 04f5fe7c9a67512265e1a1d4f9ae23d09186198e2d43844e508dbd2a798e5e66 status=1
2014-07-25 19:53:15 Relaying wtx 04f5fe7c9a67512265e1a1d4f9ae23d09186198e2d43844e508dbd2a798e5e66
2014-07-25 19:53:15 DoAutomaticDenominating: Split up large input, tx: 04f5fe7c9a67512265e1a1d4f9ae23d09186198e2d43844e508dbd2a798e5e66keypool return 6
2014-07-25 19:53:15 ProcessBlock: ACCEPTED
2014-07-25 19:53:15 ProcessMessage(dmcv, 156 bytes) FAILED
2014-07-25 19:53:15 updateWallet 94f57a1004fc534fb232f05fc41e487b6db02f7d82fb516f8898ac387a07e3d7 1
2014-07-25 19:53:15    inWallet=1 inModel=1 Index=3-4 showTransaction=1 derivedStatus=1
2014-07-25 19:53:15 updateWallet 04f5fe7c9a67512265e1a1d4f9ae23d09186198e2d43844e508dbd2a798e5e66 0
2014-07-25 19:53:15    inWallet=1 inModel=0 Index=0-0 showTransaction=1 derivedStatus=0
2014-07-25 19:53:15    inWallet=1 inModel=1 Index=4-5 showTransaction=1 derivedStatus=1
2014-07-25 19:53:15 updateWallet 04f5fe7c9a67512265e1a1d4f9ae23d09186198e2d43844e508dbd2a798e5e66 1
2014-07-25 19:53:15 send last getblocks for 00000007e54460a1f781cc9b350607c6d30cdeefd04ae21979047505ef457a32 peer=12
2014-07-25 19:53:15    inWallet=1 inModel=1 Index=0-1 showTransaction=1 derivedStatus=1
2014-07-25 19:53:15 send last getblocks for 00000007e54460a1f781cc9b350607c6d30cdeefd04ae21979047505ef457a32 peer=2
2014-07-25 19:53:15 send last getblocks for 00000007e54460a1f781cc9b350607c6d30cdeefd04ae21979047505ef457a32 peer=5
2014-07-25 19:53:15 send last getblocks for 00000007e54460a1f781cc9b350607c6d30cdeefd04ae21979047505ef457a32 peer=8
2014-07-25 19:53:15 send last getblocks for 00000007e54460a1f781cc9b350607c6d30cdeefd04ae21979047505ef457a32 peer=11
2014-07-25 19:53:15 send last getblocks for 00000007e54460a1f781cc9b350607c6d30cdeefd04ae21979047505ef457a32 peer=10
2014-07-25 19:53:15 getblocks -1 to 0 limit 500 peer=2
2014-07-25 19:53:15 getblocks -1 to 0 limit 500 peer=5
2014-07-25 19:53:15 getblocks -1 to 0 limit 500 peer=8
2014-07-25 19:53:15 received getdata for: tx 04f5fe7c9a67512265e1a1d4f9ae23d09186198e2d43844e508dbd2a798e5e66 peer=9
2014-07-25 19:53:15 received getdata for: tx 04f5fe7c9a67512265e1a1d4f9ae23d09186198e2d43844e508dbd2a798e5e66 peer=5
2014-07-25 19:53:15 received getdata for: tx 04f5fe7c9a67512265e1a1d4f9ae23d09186198e2d43844e508dbd2a798e5e66 peer=8
2014-07-25 19:53:15 getblocks -1 to 0 limit 500 peer=11
2014-07-25 19:53:15 getblocks -1 to 0 limit 500 peer=12
2014-07-25 19:53:15 received getdata for: tx 04f5fe7c9a67512265e1a1d4f9ae23d09186198e2d43844e508dbd2a798e5e66 peer=2
2014-07-25 19:53:15 received getdata for: tx 04f5fe7c9a67512265e1a1d4f9ae23d09186198e2d43844e508dbd2a798e5e66 peer=12
2014-07-25 19:53:15 getblocks -1 to 0 limit 500 peer=10
2014-07-25 19:53:15 received getdata for: tx 04f5fe7c9a67512265e1a1d4f9ae23d09186198e2d43844e508dbd2a798e5e66 peer=11
2014-07-25 19:53:16 AcceptToMemoryPool: 23.23.186.131:19999 /Satoshi:0.10.12.5/ : accepted 963cb76d9979832950d973e4dc93744d852da51239074a47427cb680c95cf187 (poolsz 2)
2014-07-25 19:53:16 dmcv: rejecting masternode vote
2014-07-25 19:53:16 ProcessMessage(dmcv, 156 bytes) FAILED
2014-07-25 19:53:17 Flushing wallet.dat
2014-07-25 19:53:17 Flushed wallet.dat 47ms
2014-07-25 19:53:17 ProcessSyncCheckpoint: sync-checkpoint at 00000003a083a840dc5810dc5859a78601bd4d7f242f69f399af663d9be2646b
2014-07-25 19:53:17 !!! ENFORCING PAYMENTS 4085657524
2014-07-25 19:53:17 dmcv: rejecting masternode vote
2014-07-25 19:53:17 CDarkSendPool::UpdateState() == 2 | 2
2014-07-25 19:53:17 DarkSendStatusUpdate - state: 2 entriesCount: 0 accepted: -1 error:
2014-07-25 19:53:17 ProcessMessage(dmcv, 156 bytes) FAILED
2014-07-25 19:53:17 received block 00000003ba50fcdc51bc2031eb557cd3a88423872ce2b56a0986e3418c4f15f5 peer=1
2014-07-25 19:53:17 Committing 25 changed transactions to coin database...
2014-07-25 19:53:17 SetBestChain: new best=00000003ba50fcdc51bc2031eb557cd3a88423872ce2b56a0986e3418c4f15f5  height=3694  log2_work=42,470899  tx=30336  date=2014-07-25 19:53:14 progress=1,000000
2014-07-25 19:53:17  --- strUseMasternode
2014-07-25 19:53:17 found coins 6
2014-07-25 19:53:17  vin nValue 72100000000
2014-07-25 19:53:17 DoAutomaticDenominating : Running darksend denominate for 721 coins.
2014-07-25 19:53:17 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
2014-07-25 19:53:17 ProcessBlock: ACCEPTED
2014-07-25 19:53:17 send last getblocks for 00000003ba50fcdc51bc2031eb557cd3a88423872ce2b56a0986e3418c4f15f5 peer=10
2014-07-25 19:53:18 getblocks -1 to 0 limit 500 peer=10
http://test.explorer.darkcoin.qa/tx/04f5fe7c9a67512265e1a1d4f9ae23d09186198e2d43844e508dbd2a798e5e66
qt wallet autodenominating like a good 'un, actually getting a positive value for the denominated change under darksend rounds column.
Still cant send anything using 'use darksend inputs only' or by specifying denominated change.
2014-07-25 20:42:40 DoAutomaticDenominating : Running darksend denominate for 832 coins.
2014-07-25 20:42:40 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
No joy...
No joy...
That's pretty impressive. Can you send me your wallet.dat so I can replicate?
system 1
2014-07-25 20:47:01 DoAutomaticDenominating Error: Found inputs too large to denominate. These must be broken up manually to use DarkSend.
2014-07-25 20:47:02 DoAutomaticDenominating: Split up large input, tx: e44c28bd69d8d13db284d2aa4c161413faefbe4c1643a98980d06b32f1b8db72keypool return 3
2014-07-25 20:48:11 DoAutomaticDenominating : Running darksend denominate for 831 coins.
2014-07-25 20:48:11 DoAutomaticDenominating : Error running denominate, Insufficient funds 2
system 2
2014-07-25 20:37:48 DoAutomaticDenominating : Running darksend denominate for 573 coins
2014-07-25 20:43:37 DoAutomaticDenominating : Running darksend denominate for 4 coins.
2014-07-25 20:43:56 DoAutomaticDenominating : Running darksend denominate for 4 coins.
Seeing a few of these...?
2014-07-25 20:48:24 DoAutomaticDenominating : Running darksend denominate for 0 coins.
tdrkmn01 to 08 updated to darkcoind 0.10.12.6.
tp2pool updated to darkcoind 0.9.12.6 (compiled from master-rc4)
port checker faking 0.9.12.6.
system 1
Maybe my system has the same problem, as it only has a 10,000DRK input which wallet fails to split :)
EDIT: All my three nodes fail to denominate their 10,000DRK input with "Insufficient funds 2" error.
In progress ?
http://test.explorer.darkcoin.qa/tx...aa4c161413faefbe4c1643a98980d06b32f1b8db72#i0
3717
darkcointestnet@e-H87-HD3:~/.darkcoin/testnet3$ darkcoind listtransactions
        "account" : "",
        "address" : "n3juyzSKGdr8jLXcaVX8xNWbfjFSomqcJo",
        "category" : "receive",
        "amount" : 5000.00000000,
        "confirmations" : 543,
        "blockhash" : "00000005579b24d89439f6d0621c82562a01ded7f4a3f0ae826e469ba59d6ab5",
        "blockindex" : 1,
        "blocktime" : 1406237299,
        "txid" : "fd645cfce3f94a0edecbec657708870c7c19ed783b79a8ff5047063b6040adc6",
        "time" : 1406237299,
        "timereceived" : 1406321444
darkcointestnet@e-H87-HD3:~/.darkcoin/testnet3$ darkcoind listaddressgroupings
            0.00000000
            "mopKjL5eiV3QkpD4NY47hoh4R44tJmn2EQ",
            831.00000000
            "muqpZKAiUgvNhuwfzVH1fJgB1jmKUV3QBc",
            4169.00000000
In progress ?
3717
        "account" : "",
        "blockindex" : 1,
            0.00000000
            831.00000000
            4169.00000000
Maybe :)
darksendtest@ip-10-65-166-48:~/bin$ ./darkcoind listtransactions
        "account" : "0",
        "address" : "mqPzEFrDcKjVdbFqPe34Ejc7qNXEWUQUFy",
        "amount" : 10000.00000000,
        "confirmations" : 14,
        "blockhash" : "00000000bc4488ced812a7e2cf031b8637857c1352a669cab43ea9eb8a6cdd2e",
        "blockindex" : 1,
        "blocktime" : 1406320458,
        "txid" : "5319552294bf9532ad6d95d6fb892693bda7f24dfac8a95c7b1e53c45c6c9cc6",
        "time" : 1406320421,
        "timereceived" : 1406320421
darksendtest@ip-10-65-166-48:~/bin$ ./darkcoind listaddressgroupings
            "mkbDJzLrjzDZYZBjSLFeect1WPcK9We8De",
            623.00000000
            0.00000000,
            "0"
            "mrS7aeAye2zDsxJsbuCLtk2J6HEVrqa7ZK",
            9376.99900000
EDIT: http://test.explorer.darkcoin.qa/tx...b2ece441274910c038e91558ed73c4010fb0a02eae#o0
But Block 3711 passed long ago...
