Static IPs definitely not a requirement for Masternodes
Discussion in 'Development Tech Discussion' started by thelonecrouton, Jan 19, 2015.
  1. thelonecrouton
    thelonecrouton Well-known Member
    Apr 15, 2014
    1,135
    813
    Everyone except me probably already knows this, but I verified today that you don't need a static IP to run a Masternode.
    Been running a testnet MN today from home, where I have access to two different ISP connections.
    Started on one with externalip=x.x.x.x:9999 (was even that necessary?) in the conf file, saw it from 'masternode list' on my testnet remote VPS, changed ISP/IP at home, stayed listed as the original IP in masternode list on the VPS, got paid twice, changed back to original IP, got paid again, changed back, got paid again.
    debug.log periodically shows a message like
    '2015-01-18 19:57:27 receive version message: /Satoshi:0.10.17.16/: version 70051, blocks=94034, us=146.90.156.164:19999, them=108.61.203.206:19999, peer=107.191.48.59:4735' - the 'us' bit is always correct at the time.
    No problems at all it seems except only the original IP appearing in the masternode list.
    My laptop is on 24/7 and switches connection automatically if one goes down, so I might run a main net MN from home for a month and see how it goes.
    Anyway, just thought I'd share in case there's anyone else unaware of this.
    • Like Like x 1
  2. Miner237
    Miner237 Well-known Member
    May 28, 2014
    510
    223
    213
    Static or not it needs to make that first check to verify the pubkey and ports are open. It seems after that you can trick it to think just about anything, on testnet we still have 127.0.0.4 I thought there was some bugs fixed to prevent gaming the MN system. Maybe it wasn't related to this because no mater what IP you use you still have to have 1k coins held somewhere.The problem with non static is that at some point it will change and when the port is closed on the IP if you haven't updated the network with the new one it will fall off the list.
  3. thelonecrouton
    Apr 15, 2014
    1,135
    813
    If your ISP changes your IP it wont affect your routing setup in any way. Your MN will just keep on truckin' :)
  4. flare
    flare Administrator
    Dash Core Team Moderator
    May 18, 2014
    2,287
    2,406
    Yep, the old IP MN entry will be kept alive by the new IP masternode - which means in turn that this harms the network. This will be reworked if we switch to Proof of Service.
  5. thelonecrouton
    Apr 15, 2014
    1,135
    813
    The network is well aware of the new IP, the MN broadcasts it and everything keeps on working - it's just that the masternode list command only reports the initial IP. Are you saying that I am harming the network by using a dynamic IP? How?
  6. flare
    flare Administrator
    May 18, 2014
    2,287
    2,406
    How does Darksend determine the IP of the current masternode?
    $ darkcoind masternode current
    37.59.212.245:9999
    What if this IP is your old IP? Working like charm for sure :)
  7. thelonecrouton
    Apr 15, 2014
    1,135
    813
    Are you saying that a MN with a dynamic IP gets paid, but is not providing the service it should?
  8. flare
    flare Administrator
    May 18, 2014
    2,287
    2,406
    You got it...
  9. thelonecrouton
    Apr 15, 2014
    1,135
    813
    Well in that case I claim the bug hunting bounty, and donate it to the Foundation. :tongue:
    My debug.log looks like it's doing everything a Masternode should though... what exactly is it not able to do because it has a new IP every now and again? Why does the IP matter if the MN is doing its stuff and backed up by the right collateral vin?
    if:
    our IP has changed
    then:
    tell everyone about it!
    :confused:
  10. Miner237
    May 28, 2014
    510
    223
    213
    such as the example of 127.0.0.4 on test net, but its mysteriously gone today...no node could ever access it and whenever it was elected current MN it crashed the party so to speak.
  11. Miner237
    May 28, 2014
    510
    223
    213
    what about MN using a single static IP and multiple pubkeys does this have a similar effect?
  12. freynder
    freynder New Member
    Dec 5, 2014
    30
    63
    18
    I think so, the dsee registration does not do much with the IP besides registering it for that particular vin at the moment. As flare mentioned, this will be reworked.
  13. thelonecrouton
    Apr 15, 2014
    1,135
    813
    Reworked so that you can have a dynamic IP, or so that you wont get paid if you do?
  14. freynder
    freynder New Member
    Dec 5, 2014
    30
    63
    18
    I was referring to the proof of service. The explicit dynamic IP support is something that will need to be discussed further as it might have implications on the quality of the masternode network as eduffield stated in bitcointalk. It will be considered though during the rewrite.
    • Like Like x 1
  15. Miner237
    May 28, 2014
    510
    223
    213
    Curious about the unique IP requirement for Masternodes. There seems to be a rise in non unique IP addresses today. DRK.MN reports
    1964 actives + 0 inactives 1705 unique IPs how does this affect the network and is it supported to point multiple masternodes at the same IP address?
  16. Miner237
    May 28, 2014
    510
    223
    213
    There seems to be 3-5 public keys eachassigned to a single IP
    37.157.250.20:9999Open (38m34s)0.11.0.13XcrkmzZLWN9YzjaaUrfCHdVCQiGVa96eM5[1][2]1,006.8538s58m10s
    Active (100%)
    37.157.250.20:9999Open (38m34s)0.11.0.13XxLVtj1bpaZoma94WHCwdZshh5Zst76xjk[1][2]1,007.7018s58m10s
    Active (100%)
    37.157.250.20:9999Open (38m34s)0.11.0.13Xdj6dTMj8YPUwg6wiBrSKxsPm1z7eGf4bv[1][2]1,003.8508s58m10s
    Active (100%)
    37.157.250.20:9999Open (38m34s)0.11.0.13XihKaxqS6PHgQQFCPeEHVVYECfoW8Bw5se[1]1,008.4048s58m10s
    Active (100%)
    37.157.250.20:9999Open (38m34s)0.11.0.13XtNv1K3gwfU7XNqWkk2c9roSeHUVSJayAM[1][2]1,018.5898s58m10s
    Active (100%)
    37.157.250.23:9999Open (5m32s)0.11.0.13Xh9X2uSH5eZTysXhHqwBsFiE7eyCVdzjM3[1][2]1,001.7509s58m15s
    Active (100%)
    37.157.250.23:9999Open (5m32s)0.11.0.13XiqPGWknjhsU2CPuqb37c9BGe5qqs5um14[1][2]1,008.9889s58m15s
    Active (100%)
    37.157.250.24:9999Open (4m33s)0.11.0.13XmmzrufgmJ3PXtW6MhcDzHs3of5RyYojCK[1][2]1,000.0008s58m10s
    Active (100%)
    37.157.250.24:9999Open (4m33s)0.11.0.13XrJqPRox2v8Gj7J9a7A3ZTWdusXwUgrU64[1][2]1,008.7518s58m10s
    Active (100%)
    37.157.250.24:9999Open (4m33s)0.11.0.13XkpJLiGkSPKocxUF3HfsFwq68QDmcHgdy6[1][2]1,000.0008s58m10s
    Active (100%)
    37.157.250.25:9999Open (11m30s)0.11.0.13Xkzfab4sfbF4VJcnfxvk6A2YJYkgQEbxHY[1][2]1,000.0008s58m9s
    Active (100%)
    37.157.250.25:9999Open (11m30s)0.11.0.13Xmc8QFUapr56nhtMRFBGtg4DEnqRx1Jo6k[1][2]1,004.7558s58m9s
    Active (100%)
    37.157.250.26:9999Open (38m34s)0.11.0.13XbzbmEmUt87byLspDV46GLk3NUrFUXh3db[1][2]1,012.6368s58m11s
    Active (100%)
    37.157.250.26:9999Open (38m34s)0.11.0.13Xdx4h3hPKoJqkPTCvajQzVzYQgCb46vPXt[1][2]1,009.8738s58m11s
    Active (100%)
    37.157.250.26:9999Open (38m34s)0.11.0.13XqEb54LU46WfYoaUqwUPDg9rJab4EyUdRY[1][2]1,003.5008s58m11s
    Active (100%)
    37.157.250.26:9999Open (38m34s)0.11.0.13XwJzoiEjzXe9afR7DpKjdZDiMABzkxuqGh[1][2]1,000.0008s58m11s
    Active (100%)
    37.157.250.27:9999Open (7m36s)0.11.0.13XvC2r2TouTUPCQ2jib4gba1zaXJagY8AaZ[1][2]1,000.0008s58m10s
    Active (100%)
    37.157.250.27:9999Open (7m36s)0.11.0.13XamNVUcXPK8JXvPnKo9Tuss45zoPUshEgT[1][2]1,003.5028s58m10s
    Active (100%)
    37.157.250.27:9999Open (7m36s)0.11.0.13XcTQLKTjRvCyK4G7UinxgACUHx4rJfMU1H[1][2]1,000.0008s58m10s
    Active (100%)
    37.157.250.27:9999Open (7m36s)0.11.0.13Xmzoc4x4xrTtZMRf3LgzgyZLzH3w88CfsM[1][2]1,005.2538s58m10s
    Active (100%)
    37.157.250.27:9999Open (7m36s)0.11.0.13XswgjazYuMpZCiHwWMdMBQKDhe5sUB6XkU[1][1,000.0008s58m10s
  17. vertoe
    vertoe Three of Nine
    Mar 28, 2014
    2,573
    1,652
    static ip requirements will be dropped soon https://darkcointalk.org/threads/v0-11-1-instantx-release-development-update.3769/
    • Like Like x 2
