Solo Mining DASH
Discussion in 'Questions and Help' started by pentahash, Sep 12, 2017.
  1. pentahash
    pentahash New Member
    Sep 12, 2017
    Good day,
    I have a question regarding the possible setup of a solo mining pool for a DASH mining farm.
    I am constructing a small mining farm, equipment should be delivered in a week or 2. I will be using the Antminer D3 (X11) miners, with a total capacity of 1,500Ghs (1.5Ths) - The idea is to increase the size of the farm 3-fold in the next few months if things work out.
    The setup would be simple, all machines on 1 network, connected by TCP/IP - there will be a DC and DHCP server setup to run the network (although the machines will have static IP's)
    I have done some research into the mining pools, and there are 2 or 3 which I like, and seem that they are running well. However, the concern i have is over slow and constantly changing latency. sometimes a stratum will have a good latency, then it changes to bad.
    I would like to get the most out of the miners, and the question I have is:
    1) Is it possible to setup a local server running a wallet, or other software, to which the D3 machines can be pointed to, to mine together (ie on same local network) to improve latency?
    2) If so, what should the setup look like? what programs etc? how could it be done?
    3) would a small farm of this size justify solo mining, or is it better to just mine in a pool?
    any help offered would be much appreciated
    E
  2. Theo Billon
    Theo Billon New Member
    Sep 14, 2017
    I also would like to know more concerning this topic since I'm going for the same project.
    Thanks.
