Sentinel run test passed = No
revelations86
20
34
Just upgraded to 0.12.1.4, and when I check the status it shows Sentinel Run Test Passed as No. What does this mean and how do I go about fixing it?
Michael Q
16
please tell more how did you run the test and about output of test ?
ref; https://github.com/dashpay/sentinel#4-test-the-configuration
Getting the same thing from dashman status after upgrade just now. I tried running "./venv/bin/py.test ./test" from Chaeplin's suggestion link but don't have that directory anywhere.
also concerning:
"IsSynced": false,
full output:
hostname : (removed)
host uptime/load average : 9 days, 1.19 0.63 0.35
dashd bind ip address : (removed)
dashd version : 0.12.1.4
dashd up-to-date : YES
dashd running : YES
dashd uptime : 0 days, 0 hours, 03 mins, 08 secs
dashd responding (rpc) : YES
dashd listening (ip) : YES
dashd port open : YES
dashd connection count : 8
dashd blocks synced : YES
last block (local dashd) : 641194
(chainz) : 641194
(dash.org) : 641194
(dashwhale) : 641192
(masternode.me) : 641194 - no forks detected
dashd current difficulty : 144694.0211229256
masternode started : YES
masternode visible (local) : YES
masternode visible (ninja) : YES
masternode address : (removed)
masternode funding txn : (removed)
masternode queue/count : 3475/4149
masternode mnsync state : MASTERNODE_SYNC_MNW
masternode network state : ENABLED
masternode last payment : (removed)
masternode balance : (removed)
sentinel installed : YES
sentinel tests passed : YES
sentinel crontab enabled : YES
sentinel run test passed : NO
$ ~/.dashcore/dash-cli mnsync status
"AssetID": 3,
"AssetName": "MASTERNODE_SYNC_MNW",
"Attempt": 8,
"IsBlockchainSynced": true,
"IsMasternodeListSynced": true,
"IsWinnersListSynced": false,
"IsSynced": false,
"IsFailed": false
$ ~/.dashcore/dash-cli masternode status
"vin": "CTxIn(COutPoint(removed, 0), scriptSig=)",
"service": “removed:9999",
"payee": “removed”,
"status": "Masternode successfully started"
nmarley
Jun 28, 2014
366
424
Can someone explain where this output comes from?
I think someone might have written tooling around the developer tests, which wasn't really the intent of the tests.
This command should either work, or display an error if sentinel can't connect:
./venv/bin/python bin/sentinel.py
nmarley
Jun 28, 2014
366
424
I don't know anything about how dashman does things, but if you follow the install instructions here you should have the directory, as the virtualenv command will create the directory.
chaeplin
Mar 29, 2014
749
356
from dashman : https://github.com/moocowmoo/dashman
bhkien
465
287
Canada
vietriches.com
I tried this
and got the following results
============================= test session starts ==============================
platform linux2 -- Python 2.7.12+, pytest-3.0.1, py-1.4.31, pluggy-0.3.1
rootdir: /root/.dashcore/sentinel, inifile:
collected 20 items
test/integration/test_jsonrpc.py .
test/unit/test_dash_config.py .
test/unit/test_dashd_data_shims.py ..
test/unit/test_dashy_things.py .....
test/unit/test_models.py ..
test/unit/test_submit_command.py .
test/unit/models/test_proposals.py ...
test/unit/models/test_superblocks.py ...F.
=================================== FAILURES ===================================
____________________ test_deterministic_superblock_creation ____________________
go_list_proposals = [{'AbsoluteYesCount': 1000, 'AbstainCount': 7, 'CollateralHash': 'acb67ec3f3566c9b94a26b70b36c1f74a010a37c0950c22d683c...5223a20312c202275726c223a2022687474703a2f2f6461736863656e7472616c2e6f72672f6665726e616e64657a2d37363235227d5d5d', ...}]
def test_deterministic_superblock_creation(go_list_proposals):
import dashlib
import misc
from dashd import DashDaemon
dashd = DashDaemon.from_dash_conf(config.dash_conf)
for item in go_list_proposals:
(go, subobj) = GovernanceObject.import_gobject_from_dashd(dashd, item)
max_budget = 60
prop_list = Proposal.approved_and_ranked(proposal_quorum=1, next_superblock_max_budget=max_budget)
sb = dashlib.create_superblock(prop_list, 72000, budget_max=max_budget, sb_epoch_time=misc.now())
> assert sb.event_block_height == 72000
E AttributeError: 'NoneType' object has no attribute 'event_block_height'
:225: AttributeError
===================== 1 failed, 19 passed in 0.28 seconds ======================
moocowmoo
Bovine Bit-flipper
483
603
263
masternode.me
Do a `git pull`in the sentinel directory to get the tests working again.
If it prompts you for a commit message, cancel out and do `git remote update ; git reset --hard origin/master`
nnx3
22
moocowmoo your scipt are really good work :D ,
do: git pull and startus are ok:
dashman/dashman status | grep "sentinel tests passed"
but we must every few days do: git pull? this will be update in next dashman?
otherway good choice will be change crontab for auto command script every few days
In my opinon if sentinel tests passed : NO masternode still give payments :)
371
169
t.me
Hi!
have same error:
and cannot remove it by doing "git pull"
"git remote update ; git reset --hard origin/master" -- done
Result:
~/.dashcore/sentinel$ sudo git pull
Already up-to-date.
[email protected]:~/.dashcore/sentinel$ sudo git remote update ; sudo git reset --hard origin/master
Fetching origin
HEAD is now at b21bb6c Merge pull request #27 from dashpay/bump-version
Update/upgrade -- done
reboot -- done
still same error...
Any ideas why?
Result of check:
[email protected]:~/.dashcore/sentinel$ sudo venv/bin/python bin/sentinel.py
dashd not synced with network! Awaiting full sync before running Sentinel.
Update: this is solved now:
During sentinel installation on Ubuntu 14.04 got some errors:
No apport report written because MaxReports is reached already
Errors were encountered while processing:
dbus
systemd-services
libpam-systemd:amd64
accountsservice
E: Sub-process /usr/bin/dpkg returned an error code (1)
