Sending my Dash to another wallet says I exceeded balance? ??
Discussion in 'Miscellaneous Dash Support Questions' started by artixtn, Feb 27, 2020.
  1. artixtn
    artixtn New Member
    Feb 26, 2020
    I have like 10.4 Dash i want to send out and it is clearly visible that I have 10.4 Dash.
    When i go try sending 10 Dash out to another address it says I EXCEEDED the amount? Help?
  2. qwizzie
    qwizzie Well-known Member
    Aug 6, 2014
    1,512
    717
    If you are trying to send out a privatesend transaction, you have two options :
    Option 1 : lower your number of rounds to mix (which will give you lower privacy, but could give some of your input amounts enough rounds now to get your 10.4 Dash out)
    Option 2 : Raise your number of rounds to mix with one extra round (hopefully this will now include all necessary input amounts, so you can get your 10.4 Dash out)
    When sending out privatesend transactions, i normally check if my input amounts have been mixed enough times by just creating a privatesend transaction and see if i can get
    to the part where it summarize the transaction and the transaction fees.
    If it does not get there and instead shows that 'exceeded amount', i then know i either need to lower the number of rounds or raise it.
    You may even need to raise number of rounds to mix with 1 extra round and then in the end (after mixing finished) set number of rounds to mix back with 1 round to get a privatesend transaction through.
    Through coin control you can check the number of rounds for each input amount, that should give you a clue which input amount possibly needs more mixing.
    #2 qwizzie, Feb 27, 2020
  3. artixtn
    artixtn New Member
    Feb 26, 2020
    I am lost at what you are trying to explain. Is there a tutorial on this?
  4. strophy
    strophy Administrator
    Feb 13, 2016
    684
    385
    @artixtn Can you confirm if you are trying to do this using PrivateSend or just normal sending?
