Reverting RC3 Masternode Payments Fork
eduffield
Mar 9, 2014
1,084
5,320
Since launching the masternode payments a few intermittent forks have popped up on the network. This is not as serious as last time, but is still a concern for the Darkcoin network, so we're reverting the changes for the time being while we discover the cause and do further testing.
Please update to either 10.10.2 or 9.10.2. Thanks!
https://www.github.com/darkcoinproject/darkcoin
https://www.darkcoin.io/downloads/darkcoin-qt.exe
https://www.darkcoin.io/downloads/darkcoind
https://www.darkcoin.io/downloads/rc/darkcoin-qt.exe
https://www.darkcoin.io/downloads/rc/darkcoind
hiddendark
65
39
Is this going to be a quick fix, or is it going to take a bit of work and testing on the testnet?
Bizmonger
28
I'm curious if the error was caused from people running different builds of the master node?
How would the network validate that a master node is up-to-date with the latest build, in addition to config file specifications?
gigabitfx
9
Do we need to also revert this change in p2pool?
"In the file p2pool/data.py, on line 171 change "masternode_payout =
worker_payout / 10" to "masternode_payout = worker_payout / 5"
mrSprinkles
This is a very noob question, but I followed chaeplin's guide for setting up an ec2 instance.
I ran the following command when it was still 10.10.1:
git clone https://github.com/darkcoinproject/darkcoin.git
into /usr/local/src/
how do I revert/update to 10.10.2?
I've tried running the same command but I get the following error:
"fatal: destination path 'darkcoin' already exists and is not an empty directory."
Raico
May 28, 2014
138
142
193
Time will tells. It's never a easy way to get the big success.
gigabitfx
9
I just downloaded the pre-compiled binaries in this post over the binaries on my system worked like a charm. But if you must recompile from git, I would assume you need to delete the existing git clone directory, try "sudo rm -R /usr/local/src/darkcoin" and then rerun your git clone command.
3,638
3,536
I guess you need this https://www.darkcointalk.org/threads/how-to-set-up-ec2-t1-micro-ubuntu-for-masternode-part-3-3.262/
Reactions: gigabitfx
flare
May 18, 2014
2,286
2,404
Germany
The protocolversion is increased for newer masternode versions, which makes the protocol incompatible. The only versions capable of joining the network were 0.10.10.0 and 0.10.10.1 - all other versions were ignored.
Bizmonger
28
The protocolversion is increased for newer masternode versions, which makes the protocol incompatible. Only versions capable of joining the network were 0.10.10.0 and 0.10.10.1 - all other versions were ignored.
When can I tryout to be on the dev team or test team?
flare
May 18, 2014
2,286
2,404
Germany
Whenever you want: Setupsome masternodes, join testnet, solomine and try to reproduce the problem we encountered in mainnet. I have some older, oudated RC versions at hand, so if someone needs one:
darkcoind-v0.10.7.3-beta
darkcoind-v0.10.8.0-3-g30e06b8-beta
darkcoind-v0.10.8.10-1-g7da5afc-beta
darkcoind-v0.10.8.2-beta
darkcoind-v0.10.8.4-beta
darkcoind-v0.10.8.5-2-g8e508af-beta
darkcoind-v0.10.8.5-beta
darkcoind-v0.10.8.8-beta
1000 tDRK available on demand :)
Reactions: hard_forker
hard_forker
41
14
sounds great, how does that work? Should I put it on my server, generate address, get the test coins and off I go? :)
Propulsion
The buck stops here.
Feb 26, 2014
1,008
468
Make sure your port is open (9999)
And add nodes. Darkcoin.io, p2pool.darkcointalk.org, and so on.
ayruel
32
9
./darkcoind --reindex
Why revert ? ... just ignore, if another pool/exchanger not follow dev instruction .. its only need time .. they are following soon
hard_forker
41
14
Sorry for newbie stuff: How do I start with testing the MN? Have 1k darkcoins to set up the MN but prefer to start with test coins before running it for real
aadje93
37
added
addnode=23.23.186.131
addnode=50.16.206.102
addnode=50.19.116.123
addnode=98.165.130.67
addnode=54.242.50.205
addnode=50.17.98.53
addnode=54.225.43.37
and downloaded it very fast and all working now. Never thought about adding p2pool.darkcointalk.org and darkcoin.io lol
Maybe make some piece of code that automaticly connects to darkcoin.io. Then forking problems should be lot less as everyone is kind of forced to connect to the right wallet.
DeathRay1977
13
11
The problem with that, as I see it, is that it would break one of the fundamental paradigms of Darkcoin and Cryptocurrencies in general. That is that they are decentralised. If you make a connection to darkcoin.io a necessity, then you introduce a single point of failure. If the Fed's wanted to come after Darkcoin, then all they would need to do is come after darkcoin.io and shut it down. :cool:
aadje93
37
i dont mean continuous connecting to that node. but just as first connect, get the version number/blockchain header or so and then p2p download the rest. Same as torrents are downloading with magnet links. 1 (or more) places to find the correct adress of the actual files.
flare
May 18, 2014
2,286
2,404
Germany
Yeah, that's a start. Post your testnet address in the forum to get some coins for masternodes, get them up and running and try to reproduce the issue we had yesterday - seems setting up some solominers and pointing some MHs at them is a good start as well.
DeathRay1977
13
11
Just like DNS, that info should be available from any node.
ScioMind
73
I've noticed many questions regarding how to set up a server for Darkcoin, Masternodes, and so on, on these forums. I've even asked a few myself! So, in the process of learning this for myself, and ultimately running a Masternode, I learned a lot and kept very detailed notes which I believe would valuable to others.
I've put together complete step-by-step guides for setting up a secure "hardened" server, installing Darkcoin (with optional Masternode instructions), and upgrading to newer versions as needed. I will be putting up instructions for P2Pool-drk as soon as I have the time.
Here are links to the instructions:
Setting up a secure "hardened" Linux server
Installing Darkcoin (with optional Masternode setup)
Upgrading Darkcoin to a newer version.
I hope this helps someone!
3,638
3,536
This ^^^ really should be in FAQ
ScioMind
73
I didn't even realize there WAS a FAQ. After your post I looked around here on DarkcoinTalk and couldn't find one. Then I searched on Darkcoin.io, and found it...and found a "Coming Soon" page; I guess that is what you are referring to.
I think it's important to have an informative and up-to-date FAQ. I am a bit busy now, both with work and with working on setting up a P2Pool (and writing a tutorial for P2Pool-drk as well), but would be happy, as soon as I have the time, to work on a comprehensive FAQ. I could submit it to whomever is in charge of posting such things, and he/she could take it from there...or however you guys would want to work out the details. I feel that Darkcoin truly represents the not-too-distant future of crypto-currency, and also feel very fortunate to be involved with it at such an early stage. I would be both happy and proud to help in any way I can.
3,638
3,536
http://wiki.darkcoin.eu/wiki/FAQ
I'm not sure but I think it was AlexGR who is running it
Reactions: vertoe
vertoe
Three of Nine
Mar 28, 2014
2,573
1,652
Unimatrix Zero One
The FAQ is hidden on darkcointalk, the link on top, called "DarkWiki" http://wiki.darkcoin.eu/wiki/FAQ
