Proposal ERROR :(
Discussion in 'Pre + Budget Proposal Discussions' started by rullikas, Oct 24, 2017.
  1. rullikas
    rullikas Member
    Jul 25, 2017
    42
    25
    Hello Community,
    I uploaded the proposal to system, here's what happened, see images below.
    Did I do something wrong? Can somebody please help? (Also lost 5 dash)
    [​IMG]
    [​IMG]
  2. chaeplin
    chaeplin Active Member
    Mar 29, 2014
    749
    356
    Could you please paste the message as text ?
    Also check your wallet is up to date and synced.
    https://explorer.dash.org/
    found related tx https://explorer.dash.org/tx/b86bcb379e368c527c8a653a3bd14aa81585179caec1d696c5d28876d252019b#i0
     dash-cli getrawtransaction b86bcb379e368c527c8a653a3bd14aa81585179caec1d696c5d28876d252019b  1
      "hex": "0100000001a1773fc996efb01fc53aba1fb5c3c61cdf90667907b9aa23fb235d350913e0f2010000006b483045022100e17e72fb803cd27431ab89ba72f19e0a67120560b43b35647ae49154c0908b3c02203836a5136adf15a0801639d2ac7e15a4b69001b94c06b66bb2ff87439fb551ff012103a1e9cea719712a11845aec4a78d766d5dfe9201d306d9692f9d2a0e2ca332c57feffffff02244fc10c000000001976a914133cbe85fda30537601b1d6f4673fc9b57fb983088ac0065cd1d00000000226a20198efbf432d90989c4dfd97e33fca9375c28067efb241035f6a5db9410b1268c8c940b00",
      "txid": "b86bcb379e368c527c8a653a3bd14aa81585179caec1d696c5d28876d252019b",
      "size": 235,
      "version": 1,
      "locktime": 758924,
      "vin": [
          "txid": "f2e01309355d23fb23aab907796690df1cc6c3b51fba3ac51fb0ef96c93f77a1",
          "vout": 1,
          "scriptSig": {
            "asm": "3045022100e17e72fb803cd27431ab89ba72f19e0a67120560b43b35647ae49154c0908b3c02203836a5136adf15a0801639d2ac7e15a4b69001b94c06b66bb2ff87439fb551ff[ALL] 03a1e9cea719712a11845aec4a78d766d5dfe9201d306d9692f9d2a0e2ca332c57",
            "hex": "483045022100e17e72fb803cd27431ab89ba72f19e0a67120560b43b35647ae49154c0908b3c02203836a5136adf15a0801639d2ac7e15a4b69001b94c06b66bb2ff87439fb551ff012103a1e9cea719712a11845aec4a78d766d5dfe9201d306d9692f9d2a0e2ca332c57"
          "value": 7.14000000,
          "valueSat": 714000000,
          "address": "XjoahKcpEnK3YTHs66aoQCZsGEqdZzFJAn",
          "sequence": 4294967294
      "vout": [
          "value": 2.13995300,
          "valueSat": 213995300,
          "n": 0,
          "scriptPubKey": {
            "asm": "OP_DUP OP_HASH160 133cbe85fda30537601b1d6f4673fc9b57fb9830 OP_EQUALVERIFY OP_CHECKSIG",
            "hex": "76a914133cbe85fda30537601b1d6f4673fc9b57fb983088ac",
            "reqSigs": 1,
            "type": "pubkeyhash",
            "addresses": [
              "XcSZSUsvn5uqmZ7goTkwsEKm1jGAHuR3UK"
          "value": 5.00000000,
          "valueSat": 500000000,
          "n": 1,
          "scriptPubKey": {
            "asm": "OP_RETURN 198efbf432d90989c4dfd97e33fca9375c28067efb241035f6a5db9410b1268c",
            "hex": "6a20198efbf432d90989c4dfd97e33fca9375c28067efb241035f6a5db9410b1268c",
            "type": "nulldata"
      "blockhash": "00000000000000f1b0710e1aa7be7e14e381f89c8add8d8f4e0df3e27385406c",
      "height": 758956,
      "confirmations": 157,
      "time": 1508834829,
      "blocktime": 1508834829
    #2 chaeplin, Oct 24, 2017
  3. rullikas
    rullikas Member
    Jul 25, 2017
    42
    25
    Thank you for you reply chaeplin. Wallet is up to date and synced.
    gobject submit 0 1 1508840231 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 b86bcb379e368c527c8a653a3bd14aa81585179caec1d696c5d28876d252019b
    Governance object is not valid - 4d286fe8b04ceaef3afe4098b4aef65e8ad8068ada9c92671a162a3b622d0227 - Couldn't find opReturn 4d286fe8b04ceaef3afe4098b4aef65e8ad8068ada9c92671a162a3b622d0227 in CTransaction(hash=b86bcb379e, ver=1, vin.size=1, vout.size=2, nLockTime=758924)
    CTxIn(COutPoint(f2e01309355d23fb23aab907796690df1cc6c3b51fba3ac51fb0ef96c93f77a1, 1), scriptSig=483045022100e17e72fb803c, nSequence=4294967294)
    CTxOut(nValue=2.13995300, scriptPubKey=76a914133cbe85fda30537601b1d6f)
    CTxOut(nValue=5.00000000, scriptPubKey=6a20198efbf432d90989c4dfd97e33)
    (code -32603)
    #3 rullikas, Oct 24, 2017
  4. chaeplin
    Mar 29, 2014
    749
    356
    I think
    is not the one you did prepare.
  5. chaeplin
    Mar 29, 2014
    749
    356
    command is like this
    I think _hexdata is changed. do you have any copy of the _hexdata ?
  6. nmarley
    nmarley Active Member
    Jun 28, 2014
    366
    424
    Yep, have to agree. The same output for "gobject prepare" should be used in "gobject submit". Just change "prepare" to "submit" and add the TXID at the end is the easiest.
    Always save your commands in a text file nonetheless for history. Unfortunately not the first time this has happened. :(
    Do you have a history of the when you did "gobject prepare"? Or do you remember if/what you changed in the proposal screen (e.g. dates/amounts/addresses? We might be able to recover it if so, but it would probably be a stroke of luck, esp. if we had to start guessing the values.
  7. chaeplin
    Mar 29, 2014
    749
    356
    is this text you enter ?
  8. rullikas
    rullikas Member
    Jul 25, 2017
    42
    25
    Yes
    Thank you guys for helping! When I made proposal, after 2 hours nothing. Then Refresh and that was mistake maybe and then I was back at the beginning. And second time was ok but error at the end. Unfortunately I don't have the first information anymore.
    #8 rullikas, Oct 24, 2017
  9. rullikas
    rullikas Member
    Jul 25, 2017
    42
    25
    What you guys think. What are my options. Is it possible to get our proposal up? :) Thank you in advance!
  10. chaeplin
    Mar 29, 2014
    749
    356
    Could you remeber name of proposal and pay_amounts ?
    payment_amount : ?
  11. rullikas
    rullikas Member
    Jul 25, 2017
    42
    25
    Yep,
    Amount: 47,4 (as I check your code at previous post, maybe I made typo and it was 47,5)
    • Agree Agree x 1
    • Funny Funny x 1
  12. chaeplin
    Mar 29, 2014
    749
    356
    I will run a script to find/submit the proposal.
  13. rullikas
    rullikas Member
    Jul 25, 2017
    42
    25
    Thank you Chaeplin!
  14. chaeplin
    Mar 29, 2014
    749
    356
  15. chaeplin
    Mar 29, 2014
    749
    356
    @rullikas
    https://www.dashninja.pl/proposalde...024fb7e06285c37a9fc337ed9dfc48909d932f4fb8e19
    https://www.dashcentral.org/p/tallinn-blockchain-conf
    Found! with '47,5', proposal hash is '8c26b11094dba5f6351024fb7e06285c37a9fc337ed9dfc48909d932f4fb8e19'
    proposal start is 1508380937.
    prepared unixtime is 1508834000
    Payment_amount will be '47', if your proposal included in next budget.
    #15 chaeplin, Oct 26, 2017
    • Winner Winner x 3
  16. rullikas
    rullikas Member
    Jul 25, 2017
    42
    25
    @chaeplin
    Thank you for putting your hours into this project! Proposal is up and running now! And seems like everything is Okay also, I had one setback claiming ownership but second time it went great.
  17. rullikas
    rullikas Member
    Jul 25, 2017
    42
    25
    Sorry to take this thread up again, looks like our team has to struggle :)
    Seems like our proposal is down from dashcentral.org can anyone please help?
  18. alex9
    alex9 Member
    Feb 4, 2017
    57
    7
    You guys seem to be unlucky... If I understood correctly, then this is your proposal revealed a bug in governance objects handler (a comma instead of a dot in payment_amount) and for almost an hour disabled additional functionality of most of masternodes.
  19. Obusco
    Obusco Member
    Sep 23, 2016
    41
    53
    @rullikas Alex9 has right, this comma had an impact that we didn't anticipate later this morning on the Masternode network (more information here : https://www.dash.org/forum/threads/masternode-operators-sentinel-hotfix-action-required.17568/).
    The team has released a fix, but as a drawback, fixed masternodes now consider the proposal as invalid and therefore are voting it down.
    Fix have been applied in both Sentinel and in the proposal tool.
    Can I suggest you to re-propose again ? voting deadline being in 4 days, you might be able to get it funded again, you will probably want to ask for 5 extra Dash in order to handle the previous loss.
  20. Beru
    Beru Member
    Oct 5, 2017
    43
    24
    Give a adress where we can contribute to a new proposal. I will send you .2 and ask people on discord to do the same
    • Friendly Friendly x 2
  21. Beru
    Beru Member
    Oct 5, 2017
    43
    24
    I'm gonna use the adress under your avatar. Hope its valid
  22. Beru
    Beru Member
    Oct 5, 2017
    43
    24
    So you should have the 5 dash right now. Good luck
  23. rullikas
    rullikas Member
    Jul 25, 2017
    42
    25
    Hi Beru, yes the address is valid. System has returned 2.4 dash I can make also screen shot to prove it. But the time all dash will return I'll start new proposal. I hope we manage this 3 day timeframe!
  24. rullikas
    rullikas Member
    Jul 25, 2017
    42
    25
    Grazy.. Thank you all the support. I'll start new one :)
  25. Beru
    Beru Member
    Oct 5, 2017
    43
    24
    I'm gonna see if I can send you the rest tonight, but if you have enough to post a new proposal, go on with it. Clock is ticking.
  26. rullikas
    rullikas Member
    Jul 25, 2017
    42
    25
    Yes, thank you. I started the process. Two confirms left, should be up soon!
    #26 rullikas, Oct 27, 2017
  27. rullikas
    rullikas Member
    Jul 25, 2017
    42
    25
    Hi, I managed to get the proposal up, but now I'm not make a final edit, It keep saying:
    Sorry, this proposal does not yet exist!
    If the proposal has been submitted recently, it takes about 15 minutes to show up on DashCentral. Please refresh your browser or check the budget overview page until your proposal appears.
    This page isn’t working
    www.dashcentral.org is currently unable to handle this request.
    HTTP ERROR 500
  28. Beru
    Beru Member
    Oct 5, 2017
    43
    24
    If I understand correctly, theres a problem with sentinel dealing with commas or points. I can vote so seems everything is ok. I'm not a reference in technical stuff but if something go wrong keep us updated and I will transfer the information to competent ears.
  29. rullikas
    rullikas Member
    Jul 25, 2017
    42
    25
    Thanks! Will do that!
    *post edited, now all done, and our nice proposal up & running*
    Thank you for fixing it!
    [​IMG]
    #29 rullikas, Oct 27, 2017
