Problem upgrading Masternodes to 12.3
Technologov
Active member
When I installed Dash Masternode on Linux with 12.2, I downloaded like this:
wget https://www.dash.org/binaries/dashcore-0.12.2.3-linux64.tar.gz
The problem is: This command with 12.3 fails:
wget https://www.dash.org/binaries/dashcore-0.12.3.1-linux64.tar.gz
Any links?
UPDATE: Nevermind. I solved it.
The new commands for 12.3 are:
wget https://github.com/dashpay/dash/rel...3.1/dashcore-0.12.3.1-x86_64-linux-gnu.tar.gz
tar xvf dashcore-0.12.3.1-x86_64-linux-gnu.tar.gz
~/dashcore-0.12.3/bin/dashd &
Another question: Is Sentinel needed for 12.3 ? Once article said it's not required anymore.
Is it required for 12.0, 12.1, 12.2, 12.3 ? (seems to be only for 12.1 and 12.2, but I'm not sure...)
My Sentinel Version = 1.1.0, according to Dash Ninjia. (I just upgraded to Daemon Version 0.12.3.2, Protocol=70210)...
How do I upgrade my Sentinel to Version 1.2.0? (I just wanna know how to do it, even if it's not 100% required...)
thanks!
thanks!
You need the updated version of sentinel, otherwise your MN will be not paid on the new protocol.
Use this, copy, paste :)
cd ~/.dashcore/sentinel/
git pull && git rev-parse HEAD && git checkout master
Hi, thanks for the command line tip!
I did it , and it looks like it's the right version already. What's the command line for check on the status of one's masternode? is there a list of commands somewhere you can share? thanks!
Also, I'm wondering why does DASH NINJIA show that I have 1.1.0 when my VPS shows 1.2.0 ? any insight would be appreciated.
thanks!
Give it time and it will change.
Use this command to see if you are ok with your MN on the protocol and version side:
dash-cli getinfo
dash-cli masternode status
dash-cli masternode list full | grep "your_dash_address"
But I'm already on master, it seems! Is this strictly necessary, or a "just in case somebody did something weird" thing? The masternodes show as successfully started, so I presume this is a "just in case" thing.
[dash@dash1 sentinel]$ git rev-parse HEAD
4f23b81f4d4a7ee2810dd49f1e4c1675501f553d
[dash@dash1 sentinel]$ git status
On branch master
Your branch is up to date with 'origin/master'.
All right @error then, if you want you can PM your addy and I can double check if all is fine or just monitor it on dashninja :)
My masternodes are showing as active (100%) on dashninja. My question was about the strange git commands, not the masternode status.
Ahhh those are just for double check nothing more.
Good for you ;)
