Paper wallet reclaim problem, but it doesn't show anything
Discussion in 'Android Dash Wallet Support' started by LordNargacua, Sep 15, 2018.
  1. LordNargacua
    LordNargacua New Member
    Sep 15, 2018
    Hi, I'm trying to scan a qr code of a paper wallet and redeem it by the dash Android app, but it doesn't do anything, neither let me sweep the dash or showing a error message.
    At first it showed a error message about not being able to connect to a certain direction after 5000ms, but now it doesn't do it more, anyone have and idea of what is happening?
  2. strophy
    strophy Administrator
    Feb 13, 2016
    684
    385
    Hi @LordNargacua it sounds like you are having connection problems. Are you in a country with internet restrictions? Maybe you could try restarting your phone and using a VPN before trying to use the wallet. Note that these connection problems should be a lot less frequent in the latest version of the app (5.18.3) so please check to make sure you have that version installed.
  3. HashEngineering
    HashEngineering Active Member
    May 3, 2014
    319
    374
    We have verified that the Paper Wallet Sweep function is broken. A ticket has been created to fix this.
  4. HashEngineering
    May 3, 2014
    319
    374
    We have issued an update for this issue, v5.18.5. Please update and give us feedback regarding it working.
  5. HashEngineering
    May 3, 2014
    319
    374
    After further review and discussion with others who had the same problem, we found that there was a program in Venezuela that was giving Dash to purchasers of a Krip K5 phone. The first set of paper wallets were empty. Contact the place where you purchased the phone to get a new paper wallet if this situation applies to you.
