P2Pool P2Pool repository and python modules
vertoe
Three of Nine
Mar 28, 2014
2,573
1,652
Unimatrix Zero One
Reactions: xgtele and fydel
Propulsion
The buck stops here.
Feb 26, 2014
1,008
468
All of it seems to work fine.
mr.slaveg
140
45
78
Hi!
I have an error when you run ...
Version of Dstorm works.
2015-01-16 12:13:41.293859 P2Pool: 8696 shares in chain (4338 verified/8696 total) Peers: 2 (0 incoming)
2015-01-16 12:13:41.294054 Local: 0H/s in last 0.0 seconds Local dead on arrival: ??? Expected time to share: ???
2015-01-16 12:13:41.294142 Shares: 0 (0 orphan, 0 dead) Stale rate: ??? Efficiency: ??? Current payout: 0.0000 DRK
2015-01-16 12:13:41.294232 Pool: 2455MH/s Stale rate: 13.9% Expected time to block: 1.4 hours
2015-01-16 12:13:41.598595 Outgoing connection to peer 107.191.44.236:8999 established. p2pool version: 1300 '81fc6c5-dirty'
2015-01-16 12:13:41.768085 Peer sent entire transaction 7ef014c1d1cc34e7faa2d2e1a4c4206f2dad109dc6961f7abd3f7742a194f9fe that was already received
2015-01-16 12:13:42.863757 > Unhandled Error
2015-01-16 12:13:42.863940 > Traceback (most recent call last):
2015-01-16 12:13:42.864049 > File "/root/p2pool-drk/p2pool/main.py", line 578, in run
2015-01-16 12:13:42.864145 > reactor.run()
2015-01-16 12:13:42.864233 > File "/usr/lib/python2.7/dist-packages/twisted/internet/base.py", line 1192, in run
2015-01-16 12:13:42.864320 > self.mainLoop()
2015-01-16 12:13:42.864402 > File "/usr/lib/python2.7/dist-packages/twisted/internet/base.py", line 1201, in mainLoop
2015-01-16 12:13:42.864490 > self.runUntilCurrent()
2015-01-16 12:13:42.864576 > File "/usr/lib/python2.7/dist-packages/twisted/internet/base.py", line 824, in runUntilCurrent
2015-01-16 12:13:42.864661 > call.func(*call.args, **call.kw)
2015-01-16 12:13:42.864746 > --- <exception caught here> ---
2015-01-16 12:13:42.864830 > File "/root/p2pool-drk/p2pool/bitcoin/stratum.py", line 39, in _send_work
2015-01-16 12:13:42.864917 > x, got_response = self.wb.get_work(*self.wb.preprocess_request('' if self.username is None else self.username))
2015-01-16 12:13:42.865005 > File "/root/p2pool-drk/p2pool/bitcoin/worker_interface.py", line 129, in get_work
2015-01-16 12:13:42.865109 > x, handler = self._inner.get_work(*args)
2015-01-16 12:13:42.865193 > File "/root/p2pool-drk/p2pool/work.py", line 326, in get_work
2015-01-16 12:13:42.865280 > len(self.current_work.value['transactions']),
2015-01-16 12:13:42.865366 > exceptions.TypeError: %d format: a number is required, not str
2015-01-16 12:13:45.018451 P2Pool: 8649 shares in chain (4339 verified/8649 total) Peers: 3 (0 incoming)
2015-01-16 12:13:45.018614 Local: 0H/s in last 0.0 seconds Local dead on arrival: ??? Expected time to share: ???
2015-01-16 12:13:45.018661 Shares: 0 (0 orphan, 0 dead) Stale rate: ??? Efficiency: ??? Current payout: 0.0000 DRK
2015-01-16 12:13:45.018711 Pool: 2426MH/s Stale rate: 13.9% Expected time to block: 1.4 hours
Crahl
11
11
dstorm is working for me on 11.0.6. You need to update line 22 in the p2pool-drk/p2pool/bitcoin/p2p.py file with the new protocol version (70052).
Reactions: mr.slaveg
Crahl
11
11
Statistics shows strange numbers.
Current Block Value: 3.26124500 DRK
Already day.
I believe the new p2pool displays the current block value as: actual block value - masternode payout. So what it's displaying is the drk funds that are available to the miners.
3,639
3,537
:what: This is an allusion to the premature protocol version 70053?
I'm not really familiar with p2pool code :oops: but you said it's updated to 70053 and I found 70052 instead. Just wanted to point it out in case it could cause problems :rolleyes:
mr.slaveg
140
45
78
Repository xcoin-hash is not updated since inception (10 months). And belongs darkcoinproject development. I thought that doing a common cause and combine sources in a single repository would be nice. If it's a bad idea, then I will remove them.
3,639
3,537
darkcoinproject on github is Evan's original account there and I hope he still maintains it too. So if there are some changes to xcoin-hash you can push them there.
mr.slaveg
140
45
78
I decided to leave the repository on bitbucket. Let this be a continuation of the line from dstorm)
I will support this version.
Top Bottom
