fabioganga
Hello dear fellow Darkcoiners!
I've set up my own MPOS DRK pool, with the latest darkcoind 10.11.5 and NOMP as stratum engine.
As I cannot (strangely enough!) find any guide for setting up a MPOS Darkcoin pool (all guides seem to refer to either LTC or other coins BUT DRK), I am left with a few doubts which I would kindly need your help for to resolve.
For instance, my main concern is about managing the unique DRK block reward and difficulty.
Please, could you take a look at my global_conf_inc.php file below and recommend any changes if needed (sensitive information has been ****)?
Thanks a million!!!
Thanks a million!!!
PHP:
<?php
$defflip = (!cfip()) ? exit(header('HTTP/1.1 401 Unauthorized')) : 1;
* Do not edit this unless you have confirmed that your config has been updated!
* Also the URL to check for the most recent upstream versions available
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-config-version
$config['version'] = '0.0.8';
$config['version_url'] = 'https://raw.githubusercontent.com/MPOS/php-mpos/master/include/version.inc.php';
* Unless you disable this, we'll do a quick check on your config first.
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-config-check
$config['skip_config_tests'] = false;
* Unless you disable this, we'll do a check for a valid coin address on registration.
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#check-for-valid-wallet-address
$config['check_valid_coinaddress'] = true;
* Defines
* Debug setting and salts for hashing passwords
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-defines--salts
$config['DEBUG'] = 0;
$config['SALT']='***********';
$config['SALTY'] ='************'';
* Coin Algorithm
* Algorithm used by this coin, sha256d or scrypt
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-algorithm
$config['algorithm'] = 'x11';
* Getbalance API Calls
* System used for getting actual Balance from Wallet
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#getbalance-api-calls
$config['getbalancewithunconfirmed'] = true;
* Database configuration
* MySQL database configuration
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-database-configuration
$config['db']['host'] = 'localhost';
$config['db']['user'] = 'mpos';
$config['db']['pass'] = '***************';
$config['db']['port'] = 3306;
$config['db']['name'] = 'mpos';
* Local wallet RPC
* RPC configuration for your daemon/wallet
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-local-wallet-rpc
$config['wallet']['type'] = 'http';
$config['wallet']['host'] = 'localhost:8998';
$config['wallet']['username'] = '***********';
$config['wallet']['password'] = '*****************';
* Swiftmailer configuration
* Configure your way to send mails
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-swiftmailer
$config['swiftmailer']['type'] = 'sendmail';
$config['swiftmailer']['sendmail']['path'] = '/usr/sbin/sendmail';
$config['swiftmailer']['sendmail']['options'] = '-bs';
$config['swiftmailer']['smtp']['host'] = 'your.mail-relay.com';
$config['swiftmailer']['smtp']['port'] = '587';
$config['swiftmailer']['smtp']['encryption'] = 'tls';
$config['swiftmailer']['smtp']['username'] = '';
$config['swiftmailer']['smtp']['password'] = '';
$config['swiftmailer']['smtp']['throttle'] = 100;
* Getting Started Config
* Shown to users in the 'Getting Started' section
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-getting-started
$config['gettingstarted']['coinname'] = 'Darkcoin';
$config['gettingstarted']['coinurl'] = 'http://www.darkcoin.io';
$config['gettingstarted']['stratumurl'] = '********';
$config['gettingstarted']['stratumport'] = '3333';
* Ticker API
* Fetch exchange rates via an API
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-ticker-api
$config['price']['enabled'] = false;
$config['price']['url'] = 'https://btc-e.com';
$config['price']['target'] = '/api/2/ltc_usd/ticker';
$config['price']['currency'] = 'USD';
* Automatic Payout Thresholds
* Minimum and Maximum auto payout amount
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-automatic-payout-thresholds
$config['ap_threshold']['min'] = 1;
$config['ap_threshold']['max'] = 250;
* Minimum manual Payout Threshold
* Minimum manual payout amount
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-manual-payout-threshold
$config['mp_threshold'] = 0.1;
* Donation thresholds
* Minimum donation amount in percent
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-donation-thresholds
$config['donate_threshold']['min'] = 0;
* Account Specific Settings
* Settings for each user account
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-account-specific-settings
$config['accounts']['invitations']['count'] = 5;
* Currency
* Shorthand name for the currency
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-currency
$config['currency'] = 'DRK';
* Coin Target
* Target time for coins to be generated
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-coin-target
$config['cointarget'] = '150';
* Coin Diff Change
* Amount of blocks between difficulty changes
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-coin-diff-change
$config['coindiffchangetarget'] = 2016;
* TX Fees
* Fees applied to transactions
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-tx-fees
$config['txfee_auto'] = 0.01;
$config['txfee_manual'] = 0.01;
* Block & Pool Bonus
* Bonus coins for blockfinder or a pool bonus for everyone
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-block-bonus
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-pool-bonus
$config['block_bonus'] = 0;
$config['pool_bonus'] = 0;
$config['pool_bonus_type'] = 'payout';
* Payout System
* Payout system chosen
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-payout-system
$config['payout_system'] = 'pplns';
* Sendmany Support
* Enable/Disable Sendmany RPC method
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-sendmany-support
$config['sendmany']['enabled'] = false;
* Transaction Limits
* Number of transactions per payout run
$config['payout']['txlimit_manual'] = 500;
$config['payout']['txlimit_auto'] = 500;
* Round Purging
* Round share purging configuration
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-round-purging
$config['purge']['sleep'] = 1;
$config['purge']['shares'] = 25000;
* Share Archiving
* Share archiving configuration details
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-archiving
$config['archive']['maxrounds'] = 10;
$config['archive']['maxage'] = 60 * 24;
* Pool Fees
* Fees applied to users
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-pool-fees
$config['fees'] = 0.25;
* PPLNS
* Pay Per Last N Shares
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-pplns-settings
$config['pplns']['shares']['default'] = 4000000;
$config['pplns']['shares']['type'] = 'blockavg';
$config['pplns']['blockavg']['blockcount'] = 10;
$config['pplns']['reverse_payout'] = true;
$config['pplns']['dynamic']['percent'] = 30;
* Difficulty
* Difficulty setting for stratum/pushpool
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-pool-target-difficulty
$config['difficulty'] = 20;
* Block Reward
* Block reward configuration details
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-reward-settings
$config['reward_type'] = 'block';
$config['reward'] = 5;
* Confirmations
* Credit and Network confirmation settings
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-confirmations
$config['confirmations'] = 120;
$config['network_confirmations'] = 120;
* PPS
* Pay Per Share configuration details
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-pps-settings
$config['pps']['reward']['default'] = 5;
$config['pps']['reward']['type'] = 'block';
$config['pps']['blockavg']['blockcount'] = 10;
* Memcache
* Memcache configuration details
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-memcache
$config['memcache']['enabled'] = true;
$config['memcache']['host'] = 'localhost';
$config['memcache']['port'] = 11211;
$config['memcache']['keyprefix'] = 'mpos_';
$config['memcache']['expiration'] = 90;
$config['memcache']['splay'] = 15;
$config['memcache']['force']['contrib_shares'] = false;
* Cookies
* Cookie configuration details
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-cookies
$config['cookie']['duration'] = '1440';
$config['cookie']['domain'] = '';
$config['cookie']['path'] = '/';
$config['cookie']['httponly'] = true;
$config['cookie']['secure'] = false;
* Smarty Cache
* Enable smarty cache and cache length
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-smarty-cache
$config['smarty']['cache'] = 0;
$config['smarty']['cache_lifetime'] = 30;
* System load
* Disable some calls when high system load
* https://github.com/MPOS/php-mpos/wiki/Config-Setup#wiki-system-load
$config['system']['load']['max'] = 10.0;
