Mixing hanging
Discussion in 'PrivateSend Questions and Help' started by flailingjunk, Mar 7, 2016.
  1. flailingjunk
    flailingjunk New Member
    Apr 25, 2015
    25
    20
    I assume its a known issue, but my client gets suck almost every time I try to mix so i figured i should make a post about it. It happens because a denominate transaction hours old is showing as 0 unconfirmed or as conflicted. Restarting client does not fix it, recover transactions 1 from the wallet repair tab does resolve the issue.
  2. dark_wanderer
    dark_wanderer Member
    Nov 12, 2014
    82
    35
    Yes, I can only confirm from my experience that it happens quite often that Darksend mixing transactions (by the way, transactions with a zero fee) just get stuck, and it can take hours until they get confirmed (if at all).
    I wrote a simple bash script (requires Linux/Unix) that can help to propagate such a stalled transaction:
    #!/bin/sh
    dash-cli getrawtransaction $1 | xargs dash-cli sendrawtransaction
    Save the code above into file named resendtx and make it executable:
    $ chmod +x resendtx
    For a stalled transaction with an ID of XXX (look up the ID from the wallet GUI), call the script on a computer which is not the computer you are mixing from:
    $ resendtx XXX
    It should help to propagate the stalled transaction thereby letting DarkSend to move on (no guarantee of course).
    Of course, it is not a permanent solution. I did not yet figure out, whether it is a network issue or something else. Any feedback from the devs or DASH power users is appreciated.
    #2 dark_wanderer, Mar 7, 2016
  3. flailingjunk
    Apr 25, 2015
    25
    20
    When I do the recovery it shows hundreds of confirmations so it is making it to the network.
Share This Page
