Masternode voting with dash-cli
Amazing
39
6
I recently set up a MN, and I have been trying to vote with command line before getting an account at DashWhale. Regardless of whether I vote 'yes' or 'no' I always get the same response in the terminal:
    "overall" : "Voted successfully 0 time(s) and failed 0 time(s).",
    "detail" : {
Does anybody know what could be wrong?
splawik21
Apr 8, 2014
1,923
1,280
Where do you cast the vote from?
Local machine or remote?
Amazing
39
6
I had tried both ways. On local machine I was getting an error message, and couldn't even vote. then I tried remote from the VPS and was getting the message I posted above.
splawik21
Apr 8, 2014
1,923
1,280
So to confirm you use masternode.conf on your local right?
Please delete all budget.dat mnpayments.dat mncache.dat in your appdata folder and start the client again. Let it synchro all data and cast the vote.
What does the wallet reports?
Amazing
39
6
What does it report when I delete these files and restart the client? And then I should try voting locally? When I try to vote locally like this '
dash-cli mnbudget vote-many e3536048673a9077c30d84b142dc9b9c0eb55eb9b60f0200c27636fd3aa67ce8 yes
I get a 'Method not found (code -32601) error
splawik21
Apr 8, 2014
1,923
1,280
mnbudget vote-many e3536048673a9077c30d84b142dc9b9c yes
Use same line without dash-cli
What system do you use?
Reactions: UdjinM6
Amazing
39
6
Thanks Splawik21! That gets it! I'm on Ubuntu 15.10 When I remove the dash-cli I can succesfully vote!
Should I be able to vote remotely over VPS also? Because sometime soon I am going to put the wallet in cold storage.
splawik21
Apr 8, 2014
1,923
1,280
Move your wallet to cold storage and leave the masternode.conf
When you start the client the wallet.dat will be created - empty one.
You can cast the votes with your empty wallet and with your mastetnode.conf file having your coins secured :)
Hope it explains and calm you now ;)
stan.distortion
848
497
There's also a timer to prevent spamming votes but I'm fairly sure that gives a clear message and the time remaining, 10 minuets between re-casing a vote iirc.
