Masternode Payments, Attention pool operators!
eduffield
Mar 9, 2014
1,084
5,323
Attention Pool Operators
** IF YOU HAVEN'T PATCHED YOUR STRATUM, NOMP OR P2POOL SOFTWARE IT WILL FAIL TO WORK AFTER THE 25TH **
Please copy your environment and connect to testnet to ensure compatability.
RC2 Compatible Source:
Stratum: https://github.com/darkcoinproject/darkcoin-stratum
NOMP: https://github.com/zone117x/node-open-mining-portal
P2Pool: https://bitbucket.org/dstorm/p2pool-drk
Blockchain explorer: http://23.23.186.131:1234/chain/DarkCoin
With a working setup you should be able to get a block on testnet and see masternode payments.
Thanks,
Darkcoin Team
mattmct
259
92
Very nice indeed! Cheers for this!
Can we update our live / production p2pools to this now (ahead of the fork) ? Or do we have to wait till the moment of the fork?
elbereth
Mar 25, 2014
464
488
Costa Rica
dashninja.pl
XkfkHqMnhvQovo7kXQjvnNiFnQhRNZYCsz
Can someone send 1000 DRK so I can test my MN setup?
mjbK1YsghLP4Qg8WiTyt7j3RPES1XM8ft6
I am mining on testnet but it will take for ever with the confirmations to get the 1000 DRK for the MN.
mattmct
259
92
You need to wait until 25 May , on 25 May you need to update your node :)
Cheers mate, thanks for clarifying this. I remembered from the last up date we had to wait to do it. I'm going to be on a flight from UK to US at that moment, going to have to find and modoft that auto scrypt that chaeplin made!
chaeplin
749
356
To switch https://bitbucket.org/dstorm/p2pool-drk ,
Use this : https://gist.github.com/chaeplin/e6157be59d5f9a94d580
when current_time is > 1401033600:
stop /opt/p2pool-drk , mv /opt/p2pool-drk-old
mv /opt/p2pool-drk2 to /opt/p2pool-drk
run /opt/p2pool-drk
quick and dirty ;D
mattmct
259
92
run /opt/p2pool-drk
quick and dirty ;D
Awesome awesome awesome! :D Thanks a lot chaeplin!
Looking through your script.
1) I looks like I have to download https://bitbucket.org/dstorm/p2pool-drk to -> p2pool-drk2
2) edit your script to my config / settings
3) add crontab with
# */1 * * * * /pathto_scripts/p2pool_hardfork.py
# mv /opt/p2pool-drk2 /p2pool-drk and run
And then let it work its magic? :)
Little confused what the "/opt/" is, is that my user name / home folder? If so, should I saw out the opt for my user?
Cheers!
chaeplin
749
356
3) add crontab with
4) chmod 755 /pathto_scripts/p2pool_hardfork.py
5) run /pathto_scripts/p2pool_hardfork.py for test
6) add cron
# mv /opt/p2pool-drk2 /p2pool-drk and run <--- done by cron, no need
Cheers!
3) chmod 755 /pathto_scripts/p2pool_hardfork.py
4) run /pathto_scripts/p2pool_hardfork.py for test
5) add cron
/opt is name of add-on package directory.
my p2pool directory is /opt/p2pool-drk, and new repos is downloaded to /opt/p2pool-drk2
I used the scripts for previous hard fork, for me move data was not enough. So I changed move_cmd.
- move_cmd = "cd " + p2pool_directory + " && mv data/darkcoin data/darkcoin.old"
--> changed
+ move_cmd = "cd /opt && mv p2pool-drk p2pool-drk-old && mv p2pool-drk2 p2pool-drk"
https://gist.github.com/chaeplin/e6157be59d5f9a94d580/revisions
move_cmd do move current to old, new to current.
change this 3 lines.
https://gist.github.com/chaeplin/e6157be59d5f9a94d580#file-p2pool_hardfork-py-L9-L11
p2pool_directory = "/opt/p2pool-drk"
p2pool_pid = "31327"
p2pool_runcmd = "screen -d -m -S P2P_DRK python ./run_p2pool.py --net darkcoin --give-author 0 --disable-upnp -f 1 -a XmgHzP9nWKJJgqn44dwQzqWAiEgJAw76JS"
change this line
(if your p2pool direc is /home/p2pool-drk and new is in /home/p2pool-drk-new,
will be
move_cmd = "cd /home && mv p2pool-drk p2pool-drk-old && mv p2pool-drk-new p2pool-drk"
or
move_cmd = "mv /home/p2pool-drk /home/p2pool-drk-old && mv /home/p2pool-drk-new /home/p2pool-drk"
https://gist.github.com/chaeplin/e6157be59d5f9a94d580#file-p2pool_hardfork-py-L42
chaeplin
749
356
Reactions: mattmct
