looking for help, CPU pool-mining from drkpool
Discussion in 'Questions and Help' started by DcoinZ, Apr 27, 2014.
  1. DcoinZ
    DcoinZ Member
    Apr 27, 2014
    25
    68
    [​IMG]
    I created an account with dkpool, i downloaded the minerd. i opened and recieved HTTP request failed: nor can I type any command.
    a little help? do i have to disable windows firewall? at&t firewall? thoughts or comments? what am I doing wrong? or is everyone having this problem?
  2. DcoinZ
    DcoinZ Member
    Apr 27, 2014
    25
    68
    [​IMG]
    so i download minerd
    open the folder and click the application.
    Simple noob question, Whar does this mean?
    "HTTP request failed: Failed to connect to 127.0.0.1 port 9
    332: Connection refused"
  3. TanteStefana
    TanteStefana Grizzled Member
    Mar 9, 2014
    2,860
    1,854
    Ok, first, is your minerd the version for darkcoin? It's a different algorithm, so you need a special version (you can get here: https://github.com/ig0tik3d/darkcoin-cpuminer-1.2c or here: https://github.com/elmad/darkcoin-cpuminer-1.3-avx-aes (Faster if you have the AES-NI instruction set)) Or just go to the front page of the bitcointalk announcement thread here: https://bitcointalk.org/index.php?topic=421615.0 where you can find downloads for windows that are already compiled.
    Second, you need to be sure to have the correct information when starting the miner. You can start the miner with a .bat or .sh file, or just a command in a terminal, or via a config file. I think you can find tutorials, or "guides" in this forum right here: https://darkcointalk.org/forums/guides.32/
  4. admin
    admin Guest
    It means your mining against yourself with no configuration settings. If you are using 127.0.0.1 your mining solo.
    To get it working open up cmd and go to the miner location.
    Then type in the following replacing your [wallet address] with your actual wallet address.
    To see your progress just go to the website here.
    minerd.exe -a X11 -o stratum+tcp://p2pool.darkcointalk.org:7903 -u [wallet address] -p 123
  5. DcoinZ
    DcoinZ Member
    Apr 27, 2014
    25
    68
    lost me at "go to the miner location."
    the cmd from minderd does not allow paste or typing.
  6. Propulsion
    Propulsion The buck stops here.
    Feb 26, 2014
    1,008
    467
    Dash Address:
    How about trying this? Click on the start menu and in Search type in "cmd" and hit enter.
    You should now have cmd open. Type in the following.
    cd C:\Users\Axelrodde\Downloads\xcoin-miner\xcoin-miner
    And then what darkadmin said except changing your wallet address to what it actually is.
  7. scorpio18
    scorpio18 New Member
    Apr 27, 2014
    25
    right click on file a click edit and replace what is in the file with
    Save. And now you can start your minerd with that file by double click on it
  8. DcoinZ
    DcoinZ Member
    Apr 27, 2014
    25
    68
    [​IMG]
    Tried a few code combinations but no luck with any of it. I am not an advanced programer but i know my way around a computer. If i cant get a miner to work, i know many others cant.
    This learning curve is to steep. iv been reading this post https://darkcointalk.org/threads/windows-mining-walkthrough.54/ still don't get it. My darkcoin walletqt wont sync either.
  9. admin
    admin Guest
    You are not in the right directory. plus remove the "[]" around your address. in command go to the folder that you have the miner program in. Then do the above.
    So if you miner program is in a folder on your desktop, type in "cd" followed by the path to the folder. For example. If I was at the C:/ and my miner was on the desktop I would type in this.
    C:\
    C:\ cd Users\Darkadmin\Desktop\xccoin-miner
    C:\Users\Darkadmin\Desktop\xccoin-miner\
    C:\Users\Darkadmin\Desktop\xcoin-miner\minerd.exe -a X11 -o stratum+tcp://p2pool.darkcointalk.org:7903 -u my wallet address -p 123
  10. DcoinZ
    DcoinZ Member
    Apr 27, 2014
    25
    68
    [​IMG]
    what do i keep doing wrong? forgive me.
  11. scorpio18
    Apr 27, 2014
    25
    Type like this in the cmd
    C:\Users\Axelrodde\Desktop\xcoin-miner\minerd.exe -a X11 -o stratum+tcp://p2pool.darkcointalk.org:7903 -u my wallet address -p 123
    • Like Like x 1
  12. Propulsion
    Feb 26, 2014
    1,008
    467
    Dash Address:
    Looks like your missing a folder should be.
    C:\Users\Axelrodde\Desktop\xcoin-miner\xcoin-miner\minerd.exe -a X11 -o stratum+tcp://p2pool.darkcointalk.org:7903 -u my wallet address -p 123
    Your original screenshot shows the folder xcoin-miner IN another folder called xcoin-miner.
    So do the above instructions but make sure your launching minerd from the second folder.
  13. scorpio18
    Apr 27, 2014
    25
    yes you are right , my bad
    • Like Like x 1
  14. DcoinZ
    DcoinZ Member
    Apr 27, 2014
    25
    68
    #14 DcoinZ, Apr 28, 2014
  15. Propulsion
    Feb 26, 2014
    1,008
    467
    Dash Address:
    Looks to be working. There is a faster miner HERE. Go to that page and hit CTRL S or file download.
    Make a new text file and save it as Quick.bat
    Then copy and paste this code in it and save it.
    Make sure your old miner is off, then double click Quick.bat
    If all goes well you'll be mining much faster.
    Also note: That code is for your specific address, you won't have to change anything.:)
    @echo off
    start /d "C:\Users\Axelrodde\Downloads\drk-v1.2c"
    minerd.exe -a X11 -o stratum+tcp://p2pool.darkcointalk.org:7903 -u XwBa1FN9tcfYautcZ3vr178VfZiH2JzXK9+0.001 -p 123
    You can check everything is working by going here.
    p2pool.darkcointalk.org You will see your address and your mining speed. It will take a while to receive a payout with the hash speed you have.
  16. DcoinZ
    DcoinZ Member
    Apr 27, 2014
    25
    68
    [​IMG]
    I tried to use your Code exactly, Propulsion. This is the message I got. Should I leave it in the download folder? Should not make any difference.
  17. Propulsion
    Feb 26, 2014
    1,008
    467
    Dash Address:
    Yeah that code was assuming you left the folder in your Download folder not your Desktop.
    Heres the code for the desktop.
    @echo off
    dir "C:\Users\Axelrodde\Desktop\drk-v1.2c"
    EDIT: Leave the +0.001 attached at the end of your address. That automatically lowers the difficulty for your miner since your using a CPU.
    #17 Propulsion, Apr 29, 2014
  18. DcoinZ
    DcoinZ Member
    Apr 27, 2014
    25
    68
    Huh?
    [​IMG]
    help me here, is there something i am missing?
    C:\Users\Dan\Desktop\xcoin-miner\xcoin-miner\minerd.exe -a X11 -o stratum+tcp://p2pool.darkcointalk.org:7903 -u XwBa1FN9tcfYautcZ3vr178VfZiH2JzXK9+0.001 -p 123
  19. Propulsion
    Feb 26, 2014
    1,008
    467
    Dash Address:
    You tried to start it in the wrong folder. That command has to be in this folder C:\Users\Dan\Desktop\xcoin-miner\xcoin-miner\
    Step 1.) Make a text file
    Step 2.) call it p2pool.bat
    Step 3.)Inside it put this:
    @echo off
    dir C:\Users\Dan\Desktop\xcoin-miner\xcoin-miner\minerd
    Step 4.) Save it
    Step 5.) Run it
    #19 Propulsion, May 6, 2014
  20. DcoinZ
    DcoinZ Member
    Apr 27, 2014
    25
    68
    Thank you Propulsion, I got it working by removing an xcoin-miner from the line.
    C:\Users\Dan\Desktop\xcoin-miner\xcoin-miner\minerd.exe -a X11 -o stratum+tcp://p2pool.darkcointalk.org:7903 -u XwBa1FN9tcfYautcZ3vr178VfZiH2JzXK9+0.001 -p 123 I am getting better at this! Now I have a desktop at 28 and laptop mining at 11-12 khash. Cheers! :D
  21. darkout
    darkout New Member
    May 25, 2014
    [​IMG] Hi guys, having troubles much like the OP, but i thought i followed the directions in this thread. Still having trouble after two days. If someone can walk me through like im 5 as i've never mined before and i'm not a programmer, just a average computer user. much appreciated. also want to set up nvidia mining. I should mention im on an alienware laptop. willing to send some darkcoin or doge for tutoring me
    #21 darkout, May 25, 2014
