Introducing Dashmate node installer
strophy
Feb 13, 2016
755
441
Hello Dash Forum!
A few days ago a blog post went up introducing Dashmate, a masternode installer based on Docker and Node: https://blog.dash.org/introducing-dashmate-the-masternode-setup-tool-for-dash-platform-d58fc37d3d9
It is designed to support a range of use cases, including supporting developers in testing code, so it can be quite a complex product to use. Luckily the `dashmate setup` wizard can walk most users through the steps needed to configure and start a node. Check out the blog post and video, and I look forward to questions and discussions below!
Links:
Dashmate: https://github.com/dashevo/dashmate/
Testnet masternode install docs using dashmate: https://docs.dash.org/en/stable/masternodes/setup-testnet.html
TaoOfSatoshi
2,834
2,635
Dash Nation
www.dashnation.com
Hello Dash Forum!
Links:
If you are a dummy like me and really (I mean really) liked Dashman, this is a worthy replacement for it that is completely up-to-date with the latest Dash tech. Running a masternode in the new more demanding technical environment will be a lot easier with this tool. Thanks to @strophy and everyone else who worked on this project.
Reactions: AgnewPickens
