So during the summer a proposal was launched to add IX to Electrum DASH but I still dont see traces of it on the code. Is this featured on the client? where can i see the code for it?
Thanks.
Thanks.
Sending of IS transactions is possible to implement without the new DIPs; however, there's not a way to actually fully validate incoming IS (since you cannot SPV verify the masternodes).Any update on this? Can IS be implemented using the current Electrum / ElectrumX codebase or is it necessary to wait for deterministic masternode lists before we can have IS on SPV wallets? How do the Android/iOS wallets implement this?
can't it be send to a private MN and get a response? I know its something stupid to ask. Just trying to think out loud.Sending of IS transactions is possible to implement without the new DIPs; however, there's not a way to actually fully validate incoming IS (since you cannot SPV verify the masternodes).
I suppose if you had a private node that you trusted, you may be able to set something up to check for you. Fortunately DIP-4 will make it possible to do directly.can't it be send to a private MN and get a response? I know its something stupid to ask. Just trying to think out loud.
They didn't. There is already Dash Core code written implementing the logic for enabling this stuff.Why would Dash fund something that was impossible to implement?
Electrum is a good wallet. I have used it for years (both Bitcoin and Dash). In my opinion supporting ongoing development of it is well worth the value. Apparently masternode owners agree.Fortunately DIP-4 will make it possible to do directly.
I believe, not "all" transactions are IS, but only those which were made with 4 or less inputs with 6+ blockchain confirmations each. So what is the ETA on full InstantSend implementation?Right now all transactions are IS, though they aren't shown as such in the Dash Electrum UI
Hopefully this month. Right now it's now our top priority.I believe, not "all" transactions are IS, but only those which were made with 4 or less inputs with 6+ blockchain confirmations each. So what is the ETA on full InstantSend implementation?
