"Failed to Load masternode cache from nmcache.dat"
Agorist
So after downloading the new wallet I am not able to open up Dash Core because I get this error notification and now I cannot open my old wallet as well. I am afraid that I have lost my Dash and also my old wallet is linked to a masternode via a share a bought. Did I lose everything? How do I fix this? Thanks!
Have you followed the upgrade procedure?
No, I honestly thought that is was just a straight forward download and it would sync on its own. There were no prompts on the site telling me that there was anything special that I needed to do, so I didn't. :/
1. Make sure you have your wallet.dat copy in a safe place
2. Follow the upgrade procedure. There was a folder change, that's why your new version might not see your keys.
Where would the wallet.dat be? I have looked in both dash and dash core and it is not there.
You should have an original one too.
If there is not one there then should I try some sort of system reboot or something like that? Because I can only find the one wallet.dat and that is the one in dashcore. I have searched my whole PC and that is the only one that shows up.
