Darksend completion stuck at 82%
Discussion in 'PrivateSend Questions and Help' started by spatula, Oct 31, 2014.
  1. spatula
    spatula Well-known Member
    Oct 31, 2014
    49
    39
    158
    So last Friday I enabled "darksend mixing" for the first time on my wallet with a balance of 828drk. Since then it has been stuck at 82% and it doesn't matter if i start or stop darksend mixing. Since that time I have got enough additional coins to create another masternode, but don't know how to get my 828 coins back. Any help would be appreciated.
  2. moli
    moli Grizzled Member
    Aug 5, 2014
    3,263
    1,837
    What do you mean you don't know how to get your 828 coins back?
  3. spatula
    Oct 31, 2014
    49
    39
    158
    I need to be able to send them in 1 normal non-anonymous 1000drk transaction to create a masternode. Do i just send them to another wallet first then send them all to the masternode 0 address? Can i do that when darksend "completion" is not at 100%? Sorry for being such a noob.
  4. moli
    Aug 5, 2014
    3,263
    1,837
    Ah.. If you send the 828 DRK to yourself, using the "No Preference" option, the coins will be back in your wallet with no anonymity, and then you can add more DRK to it to make 1000 DRK, then follow the instruction how to set up a MN. Or you can send them to another address, using "No Preference" as well.
    (They are actually anonymized to the rounds up to 82%, if you look in the Coin Control, you'll see it, but for less confusion, just use "No preference" you'll get the coins "unstuck")
  5. spatula
    Oct 31, 2014
    49
    39
    158
    That's exactly what I needed. Thanks for the help!
  6. moli
    Aug 5, 2014
    3,263
    1,837
    No problem. :)
    Hope you can set up 10 or more MNs soon! :)
Share This Page
