darkcoin-qt lockunspent and listlockunspent function
drkrooster
62
29
Malaysia
Hi,
I have tried help in darkcoin-qt console but failed to understand how to use lockunspent and listlockunspent
as I understand, I can use "lockunspent" to lock my unspent darkcoin, so that when I send out drk coins, these particular input would not be used to sent out coins.
after I lock it, i should be able to see those locked input by using listlockunspent.
and I can unlock using lockunspent.
But i do not see any example on this. Anyone can advise on this? Thanks
oblox
1,032
537
Any reason why you don't enable coin control and then go into it via the send tab (inputs), select list and select which inputs you want to use and/or lock (right click).
3,639
3,537
Reactions: vertoe
