Create a Mining Pool
Discussion in 'Mining Pools' started by Dean, Apr 6, 2017.
Thread Status:
  1. Dean
    Dean New Member
    Apr 6, 2017
    All,
    Can someone point me to the right place on setting up my own mining pool?
    Thanks
  2. flare
    flare Administrator
    Dash Core Team Moderator
    May 18, 2014
    2,304
    2,435
    • Like Like x 1
  3. Dean
    Dean New Member
    Apr 6, 2017
    Thanks!
  4. zer0day
    zer0day New Member
    May 16, 2017
    I'm curious, did you make it work?
  5. zer0day
    zer0day New Member
    May 16, 2017
    I have set a p2pool myself, I do not know if it's the best to use ?
  6. CharlesMagno
    CharlesMagno New Member
    Aug 23, 2017
    And about you, friend? Are you running in a own pool? What do kind of setup do you follow to create it?
  7. Coin Foundry
    Coin Foundry Member
    Sep 21, 2017
    43
    6
    Dash Address:
    Xogwp9KEDbhcintxfcamj7Cd1Gd93vtiZC
    Be advised though, just setting up a pool is the easy part. Keeping it running and your miners happy is the hard part.
  8. CharlesMagno
    Aug 23, 2017
    LOL
    I believe, but, exactly, why do you said this?
  9. Coin Foundry
    Coin Foundry Member
    Sep 21, 2017
    43
    6
    Dash Address:
    Because the majority of pools regardless of the Coin are gone after a couple weeks.
  10. cryptorra
    cryptorra New Member
    Oct 12, 2017
    So would you say that when evaluating a pool you'd pay a lot of attention to how long they've been running?
  11. Coin Foundry
    Coin Foundry Member
    Sep 21, 2017
    43
    6
    Dash Address:
    Well in a way yes.
  12. cryptorra
    Oct 12, 2017
    In some cases I guess it's like with cryptos - you select one based on your criteria and you take the risk. If it stays, you were in early (though I don't know how much that would matter in the case of a pool, fewer members to share the reward with possibly).
    And if you don't mind me asking - as a pool operator, what are your top 3 features you'd look at when choosing a mining pool?
  13. Coin Foundry
    Coin Foundry Member
    Sep 21, 2017
    43
    6
    Dash Address:
    That's a funny question. Let me tell you that administrating multiple mining pools, developing the stratum engine and doing support for the miners is so intense that I've hardly have to to mine myself. Except for doing smoke tests on new pool features. :)
  14. cryptorra
    Oct 12, 2017
    Oooh, does it mean you don't mine yourself? :) I was just curious if somebody with more 'inside knowledge' would approach choosing a mining pool differently than somebody who bases their decision on internet research only.
  15. Coin Foundry
    Coin Foundry Member
    Sep 21, 2017
    43
    6
    Dash Address:
    I used to be a miner before I got into crypto-currency development and had a lot of fun implementing a stratum-engine from scratch. And when you start developing such a piece of software, you better run a pool as well to validate that the software actually works as expected.
  16. soby1930
    soby1930 New Member
    Jun 23, 2018
    Going for walks your own cryptocurrency mining pool calls for a giant quantity of infrastructure and bootstrapping, because you have a hen and egg problem wherein no person desires to mine in a low hash strength pool because it has low consistency.
    So it’s difficult to get humans in at the start.
  17. merylgarner
    merylgarner New Member
    Oct 6, 2018
    How does the mining technology work?
  18. HeroMiners
    HeroMiners New Member
    Dec 27, 2018
    If you want to open a pool for the Ethash algo coins, find a sammy007 in github.
  19. Jeaneldredge
    Jeaneldredge New Member
    Mar 9, 2019
    I could not install it alone?
    I wrote that there is some kind of error.
  20. flare
    flare Administrator
    May 18, 2014
    2,304
    2,435
    What kind of error did you get?
  21. alesandrtr114
    alesandrtr114 New Member
    Jun 18, 2019
    7
    Did it worked out for you eventually? I'm having some kind of errors too.
  22. alesandrtr114
    Jun 18, 2019
    7
    Did it worked out eventually? And if yes, how did you solve it? I'm having some trouble with errors too.
Thread Status:
Share This Page
