Complete, Step-By-Step-Guides, Suitable for Noobs and Experienced Users Alike!
ScioMind
73
Hi there! As the title says, I have created a number of complete, step-by-step guides to many aspects of Darkcoin (and I will be adding more all the time). I have written these guides with noobs in mind, taking you through each step in a crystal clear manner...but I also know that even more experienced users can often benefit from these guides, as they really help avoid missing critical steps.
I have guides for setting up a secure, "hardened" linux server, installing and updating darkcoin on the server (including optional instructions for running a Masternode using the secure external "cold" wallet method) and installing p2pool and a CPU miner on the server.
Whenever I see a way to improve the techniques or whenever newer versions of Darkcoin are released, I update the guides for maximum security and accuracy.
The list of guides is at http://PlanetCrypton.com/crypto-coin-computer-setups
If you use these guides and want to ask me any questions about them, simply post a reply in this thread, here at darkcointalk.org, and I will be more than happy to help in any way that I can! Also please be SURE to click "Watch Thread" so that you will be up to date with any changes or mandatory updates. You will be glad you did!
Reactions: Miner237
David
618
628
163
I want to say that I used Scio's MN guides and they are absolutely perfect. Most other guides leave out steps or expect you to know how to use the linux text editor etc., but his guides leave nothing out. Complete Linux newb here btw =)
ScioMind
73
Just curious...have you gotten any Masternode payments yet? So far just one for me...but I was so happy to see it!
ScioMind
73
I still just have the one payment myself.
I don't know if this is a factor, but after waiting for a while without a payment I added a line to my remote darkcoin configuration file...and an hour or two later I got my first payment. I'm not even sure if the line was necessary, or if it was a coincidence or whatever. In any event, here's what I did:
I logged into my REMOTE server. (You should know how to do that by now, so I won't get into that.)
Then I switched to my <general-user> (because your login-user should just be used for logging in).
su <general-user>
Open the darkcoin configuration file for editing
sudo nano ~/.darkcoin/darkcoin.conf
Then make sure you have all of the following lines (in any order, it doesn't matter). In particular, make sure you have the server, daemon, masternodeaddr, and externalip settings:
rpcuser=<some_reallY_long_really_random_username>
rpcpassword=<some_really_long_really_random_password>
alertnotify=echo %s | mail -s "DarkCoin Alert" <[email protected]>
server=1
daemon=1
masternodeaddr=<ip.add.re.ss>:9999
addnode=23.23.186.131
listen=1
daemon=1
logtimestamps=1
maxconnections=256
masternode=0
externalip=<ip.add.re.ss>
Make the changes, then close and save the file.
Then just stop and restart darkcoind:
darkcoind stop
darkcoind -daemon
Then on the LOCAL machine, restart your LOCAL Darkcoin wallet:
darkcoind -daemon
Unlock your LOCALwallet. (60 to 120 seconds should work fine.)
darkcoind walletpassphrase <wallet-passphrase> <seconds-to-remain-unlocked>
Start the masternode on the local machine
darkcoind masternode start
You can then check the masternode list.
darkcoind masternode list
If your REMOTE IP address is on the list, all should be well. Once you are beyond the 60 or 120 second unlocked period you can shut down your LOCAL darkcoin:
darkcoind stop
Again, I dont know if this is necessary at all. You may just want to wait a bit more and see what happens, Either way, please keep me posted so I can adjust my instructions or advise you as needed.
Good Luck!
Reactions: vertoe
karmicdark
Thanks for the guides, they are well done. How do you manage multiple masternodes with this setup? In other words, how do you manage multiple LOCAL servers on the same machine?
ScioMind
73
I haven't had that problem yet (since I only have a bit over 1000DRK, not enough for a second Masternode) but I have thought about this.
The absolute easiest way would probably be to wait for a later release candidate which natively supports multiple nodes, so that if you had some multiple of 1000DRK you could simply set up one instance which would ACT like multiple instances. It is my understanding that this is something which is being worked on. But...that doesn't solve your problem for now, and would have you missing out, for the time being, on those juicy Masternode payments!
So...one solution that comes to mind is to set up a different linux user for each instance of a LOCAL Darkcoin daemon you want to run. Also, instead of copying the extra darkcoind binaries over to /usr/bin/darkcoind (which would just keep over-writing the new darkcoind over the existing one) it might be possible to put each darkcoind into its own directory, perhaps either like /usr/bin/darkcoin-1/darkcoind, /usr/bin/darkcoin-2/darkcoind, etc.,.... (So darkcoind would be in /usr/bin/darkcoin-1/, etc.,...)
I am not sure if this would work, because I really never see any directories in /usr/bin, just files and the occasional symlink. If it did not work, then I would suggest creating a directory for the daemon in each user's home directory, like: home/user-1/darkcoin-binary/darkcoind, home/user-2/darkcoin-binary/darkcoind, etc.,...
You would also have to chmod and chown things as appropriate, modifying what I have in my instructions to refer to the new locations.
Also, when issuing commands for darkcoind, such as darkcoind -daemon, or darkcoind stop (or whatever), you would have to enter the full path, to be sure to refer to the correct instance. So...you would either need to execute...
/usr/bin/darkcoin-1/darkcoind -daemon
-or-
~/darkcoin-binary/darkcoind -daemon
...depending upon the method you chose.
And...having written that, I think the second method (keeping each version of the darkcoind binary in each user's home directory) would be more convenient, because you could use the SAME command to start, stop, etc.,... the daemon, simply appending ~/darkcoin-binary/ in front of all of your darkcoind command.
I am not sure if that all made sense to you. If not, I will be happy to clarify any points.
Reactions: karmicdark
vertoe
Three of Nine
Mar 28, 2014
2,573
1,652
Unimatrix Zero One
Just a quick note to all who use my guides: There has been an update from version 0.10.11.04 to version 0.10.11.05.
You will need to update in order to receive masternode payments. I have revised both the Darkcoin update guide and the Darkcoin/Masternode installation guide.
As always, be sure to give me feedback so I know whether everything is working for you.
No, you dont need to update .4 to .5 on masternodes. This bugfix is for pools only.
(All my nodes still running .4 and getting paid...)
ScioMind
73
I haven't gotten paid for about three days, until just after I updated. Maybe just a coincidence. In any event, I do like to stay current. Thanks for letting me know, though.
karmicdark
I have maybe a basic question here.. but I encrypted my wallet before generating the private key and now when I run:
darkcoind masternode genkey
I get this error:
error: {"code":-1,"message":"masternode list|count|current|votes|enforce> passphrase\n"}
I tried unlocking the wallet first and that didn't work. Does anyone know how to fix this? Thanks!
ScioMind
73
I
I get this error:
I assume you are talking about your local wallet. If you are trying to unlock your wallet and then generate the key but are finding it is not working, you might try sending EXACTLY 1000DRK to a NEW paper wallet address for which you have the private key. Then delete your local darkoin installation and start over. This time, however, you should just be able to import the private key from the paper wallet into your new local darkcoin installation.
I'm answering this on my phone right now, but when I get home and to my computer I will be happy to get into.details regarding any of this if you need it.
Kong
55
15
Hi, i am a linux noob and i followed your guide exactly step by step. Now i'm stuck at the line "sudo mv darkcoind?raw=true darkcoind" ... No such file or directory. What does that line mean?
3,639
3,537
just skip it :) that's a fix for github download I guess
Kong
55
15
always me... i have successfully started a masternode, but when i stop the local masternode wallet, the remote masternode goes inactive.... Please help.
ScioMind
73
That's correct. When downloading from github, the downloaded darkcoind file actually gets the name darkcoind?raw=true instead of just darkcoind.
The line "sudo mv darkcoind?raw=true darkcoind" is just meant to rename this file to simply "darkcoind."
One thing to do if you get the file not found error reported by Kong is to list the files by executing "ls" to make sure you have downloaded the file from github, and to check what it is named, and change the "mv" line accordingly.
ScioMind
73
That's odd. I am wondering if you actually wound up setting things up in such a way that the LOCAL machine wasn't acting as the external "cold" wallet for the REMOTE machine, but instead was actually the masternode itself. Are you sure that your local and remote config file are correct?
Kong
55
15
my masternode was online, then offline, and now it is online again, the local wallet is still offline... i am pretty sure that i put the right ip in the config file. my ip 108.61.196.161:9999 last seen 5mins ago, i am a little worried....
Kong
55
15
seems to work.. have to sleep...it is 7 hour in the morning here... will look tomorrow if it is still running. thanks for your help. If it is still running tomorrow, i will donate you a few coins.
ScioMind
73
Kong
I checked on your IP using https://elbzo.net/masternodes.html
It shows that you are using the older version of darkcoin...which also makes sense of the "file not found" error you had. This should not be a problem unless you are (or plan to be) running a pool.
So far so good. If you want to upgrade you could follow my guide here, although again, that is only needed if you are or are going to be running a pool. If you do decide to upgrade, it should take less than half an hour if done properly.
ScioMind
73
I checked your IP again and see that you have updated to the latest version! Fantastic! It seems you are up and ruining well. Any other issues on your end?
nmarley
Jun 28, 2014
369
427
In the install-darkcoin-daemon article,
wget <new version location> (Probably: wget <github-link>)
Now change the name from "darkcoind?raw=true" to simply "darkcoind"
You can probably get it in one command:
wget -O darkcoind <github-link>
*note: I can't even post the github link in here, as I'm not yet "trusted". Just put the raw github link to the binaries in where it says <github-link>
Reactions: ScioMind
ScioMind
73
When I wrote the guide I wondered if there was a command which would rename the file at the same time it downloaded it. After looking up the "-O" switch and testing it out it seems you are correct! Thanks a lot! I will edit the instructions to reflect this.
Wh1teKn1ght
32
5
great guide, just wondering, how important is it to set a really long random password in the .conf file? When i set a really long random password, I got an authentication error when trying to run the darkcoind -getinfo command...
ScioMind
73
I just like to be as safe and careful as possible...and at times that may lead to overkill. That said, I am not sure why you got the authentication error...but am I to assume that when you changed to a somewhat shorter password you had success?
Wh1teKn1ght
32
5
yep, with a shortened password seems to work...
Miner237
515
227
213
Thanks for putting this together, I have not used Linux in so many years. This helped me get a testnet master node running. Can anyone explain the dumpprivkey, this was not in many other guides I've read.
ScioMind
73
First a bit of background on public and private keys, since I don't know what level of knowledge you have about such things. When you use a darkcoin address (or bitcoin, or most any other crypto-coin) to give to people to send you money, that address is actually a "public" address. It corresponds to another "private" address which is NOT given out to others. If someone has the private address it is a fairly trivial matter to generate the corresponding public address used for receiving funds, but if someone has the public address it is impossible to generate the private address used for sending or spending funds. So...the private address may be thought of as sort of a "secret password" that can be used to access the funds sent to a darkcoin address.
Now, I will explain the "dumpprivkey" part of my tutorial. When using computers, things can go wrong. There are a LOT of ways data can be lost. Since we are essentially dealing with money here, it would be very unfortunate to lose 1000DRK. By having you generate and save the private key for your 0th address, I am helping to protect you in the unlikely event of some problem later on down the road. If something bad happens later and your computer is lost, stolen, broken, etc., you can use the private key to access your darkcoin. One way, for example, would be to create a new darkcoin wallet, and then "import" the private key into the new wallet. Assuming that no one actually spent the darkcoin (for example if the computer was hacked or stolen, and then the thief sent the darkcoin to another address) then your new wallet will now "contain" the DRK from your original wallet, in the same address as your original wallet. At that point, you could should then send those DRK on to a different darkcoin address that you own, NOT contained in the original wallet; this is because if someone DOES have access to your original wallet they could still spend them later...unless you spend them first!
I am not sure if all of this was clear. The bottom line is that the "dumpprvkey" step is not essential to the actual set-up of the masternode...but if you DON'T do this step you may be VERY unhappy about it in the future...so please DO take this step...it is your only insurance against the loss of the 1000DRK you're sending to your masternode, and any other DRK which your masternode will accrue over time.
Reactions: TsuyokuNaritai
