Changing masternode payout address / tracability
s4ndking
Hi, i have a question regarding masternode payout addresses.
If i have a payout address (A) and then switch to a payout address (B): Can anyone see address (A) i have used before?
splawik21
Apr 8, 2014
1,942
1,303
Normal user in this certain moment can see only the payout address connected to a certain IP/collateral/voting/owner keys....
Advanced user can log everything what happens on the network and can dig back and check if the same collateral uses different IP or payout address.
I suggest using dashcore address to get the rewards and mix them before spending them if you really care about your privacy.
