build error
gheros
9
git branch v0.12.3
cd depends
make HOST=x86_64-w64-mingw32
cd ..
./autogen.sh
CONFIG_SITE=$PWD/depends/x86_64-w64-mingw32/share/config.site ./configure --prefix=/
make j4
error
.libs/libdashconsensus_la-utilstrencodings.o:(.data.DW.ref.__gxx_personality_v0[DW.ref.__gxx_personality_v0]+0x0): undefined reference to `__gxx_personality_v0'
collect2: error: ld returned 1 exit status
Makefile:4103: recipe for target 'libdashconsensus.la' failed
make[2]: *** [libdashconsensus.la] Error 1
make[2]: *** 正在等待未完成的任务....
make[2]: Leaving directory '/home/data/dash/dash/src'
Makefile:10560: recipe for target 'all-recursive' failed
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/home/data/dash/dash/src'
Makefile:688: recipe for target 'all-recursive' failed
make: *** [all-recursive] Error 1
tungfa
8,899
6,744
git branch v0.12.3
cd depends
cd ..
./autogen.sh
make j4
error
try 14.0.2
gheros
9
branch v0.14.0.2
cd depends
cd ..
./autogen.sh
CONFIG_SITE=$PWD/depends/x86_64-w64-mingw32/share/config.site ./configure BDB_LIBS="-L${BDB_PREFIX}/lib -ldb_cxx-4.8" BDB_CFLAGS="-I${BDB_PREFIX}/include"
make j4
error
In file included from bls/bls.cpp:5:0:
bls/bls.h:14:27: fatal error: chiabls/bls.hpp: 没有那个文件或目录
compilation terminated.
Makefile:9594: recipe for target 'bls/libdashconsensus_la-bls.lo' failed
make[2]: *** [bls/libdashconsensus_la-bls.lo] Error 1
make[2]: Leaving directory '/home/moac-sh2/data/dash/dash/src'
Makefile:11266: recipe for target 'all-recursive' failed
make[1]: Leaving directory '/home/moac-sh2/data/dash/dash/src'
Makefile:686: recipe for target 'all-recursive' failed
gheros
9
try 14.0.2
branch v0.14.0.2
cd depends
cd ..
./autogen.sh
make j4
error
strophy
Feb 13, 2016
781
489
It looks like you are trying to cross-compile for Windows. Did you install the dependencies?
$ sudo apt-get install nsis wine-stable wine64 bc
$ sudo apt-get install g++-mingw-w64-x86-64
$ # Required to enable C++ threading libraries (e.g. std::thread)
$ sudo update-alternatives --set x86_64-w64-mingw32-g++ /usr/bin/x86_64-w64-mingw32-g++-posix
$ sudo update-alternatives --set x86_64-w64-mingw32-gcc /usr/bin/x86_64-w64-mingw32-gcc-posix
Documentation: https://github.com/dashpay/dash/blob/master/doc/build-cross.md#windows-64bit32bit-cross-compilation
