Best procedure to move a Masternode to another server?
pin0de
36
29
18
I need to move my masternode to another server.
Can I leave the 1000 DASH on the previous key and just set up a new server, then edit the masternode.conf file on the local computer with the IP address of the new server? (So I would be leaving the pubkey, txhash etc the same and add the pubkey to the dash.conf on the new server.)
Or is it mandatory to generate a new key, move the 1000 DASH to the new key when changing IP addresses and setting up a new Masternode?
Could somebody explain the best procedure and list the steps in the order that makes the most sense?
Thanks!
Balych
365
211
I think yes, but first wait until old masternode entry dropped from network (check it with masternodelist full your_address in console).
splawik21
Apr 8, 2014
1,926
1,287
Yes you can.
1 stop the deamon and kill the vps
2 wait 70 min +/- (check if the node is not on the network as suggested above on your new vps) and issue the start command of the node with changed masternode.conf
tungfa
8,902
6,731
can i get a guide for this please :rolleyes:
