Baikal Cube 300m - Can they be linked up together?
Discussion in 'Hardware Discussions (ASIC / GPU / CPU)' started by Flip, Apr 12, 2017.
  1. Flip
    Flip New Member
    Apr 12, 2017
    22
    Hi all. New to Dash Forums!
    Please could someone tell me if the Baikal Cubes (300m) can be linked up together?
    Wanted to get 3 of them.
    Thanks!
    Flip
  2. ccminer
    ccminer New Member
    Apr 12, 2017
    11
    Hi I'm new as well and I have the same question ehehe
  3. mrearthbound
    mrearthbound Member
    Feb 18, 2017
    248
    44
    I'm not really sure linking 3 of them together is going to do any difference, though. Just put them in a pool and you'll get corresponding rewards proportional to your hash rate
  4. ccminer
    ccminer New Member
    Apr 12, 2017
    11
    Each of them need a lan wire connection if I can connect them together I can use just one Internet wire for example
    • Informative Informative x 1
  5. Dee
    Dee New Member
    Nov 26, 2016
    You can definitely connect them together to one lets say, one 900Mhs (3x 300Mhs) Unit. They also have a quad cube version to purchase.
    Benefit would be:​
    Save on the necessary LAN wires and ports.​
    Save 2x Poweconsumption and excess heat of the controller board, although thats not much.​
    Easier access and management.​
    Drawback would be:​
    You can only point the whole hashing power to one pool at a time.
    They have changed the cables to interconnect the units. The Cube ones are 5pin, the Mini and Giant ones are 10-pin.
    When you buy a cube at a time, like I did, they do not ship a interconnect cable with it. So you would have to buy or organize them yourself from somewhere.
    I'm planning to connect 4 of them together. When I purchased the Cube, the quad version was not available...
    #5 Dee, May 1, 2017
    • Informative Informative x 2
  6. Gunna
    Gunna Member
    Apr 9, 2017
    59
    5
    i'd be interested on knowing where I can buy the interconnect cables as well. Support is not offering a solution
  7. Dee
    Dee New Member
    Nov 26, 2016
    Hi there,
    the only supplier of the Baikal CUBE interconnect cables I have found so far is one on Aliexpress. That shop wants 10 USD for one cable and that's way too much.
  8. LostInSpace
    LostInSpace Active Member
    Apr 13, 2017
    152
    104
    It is very simple to build those cables yourself, I build 2 10-pin cables for my giants and about 3 cables for cubes.
    All you need is the standard 4S1P connectors (usually used for balance chargers, 4 pins for the batteries, 1 pin for ground), you can order 10 of them for $0.99 from ebay:
    http://www.ebay.com/itm/10pcs-New-4...715968?hash=item3d2986f700:g:DAsAAOSw32lYosZs
    Then you can connect them together and voila, you got 5 cables to connect any Baikal Cube together for less than a dollar.
  9. LostInSpace
    Apr 13, 2017
    152
    104
    And this is how you connect them together, look at how Baikal Quads are linked together (see pin diagram with IN/OUT on page 3), it works the same way with the Baikal Giant blades (just with 10pin cables there). One device is the master and gets the commands via the USB cable from the PI, then you chain the second 5pin cable to the first slave first 5pin, from there you can use the second 5pin to the second slave, etc. up to 5 devices works stable according to Baikal.
    http://pan.baidu.com/s/1o7Ugpb8
    • Like Like x 1
