Advice on blockchain wallet for Android
tungfa
8,899
6,744
Coinbase is an exchange and not a wallet !!
i like exodus if multicurrency
and dash android for Dash
Reactions: JacobWr
JacobWr
It's cool that Exodus is free, though doesn't it lack some features - from your experience? I've read that it has no two-factor authentication, which may cause security troubles..
AgnewPickens
Chief Sock Advisor
Mar 11, 2017
506
211
You don't need 2FA if you hold the seed or private keys, like you do with Exodus, you need 2FA for
exchange wallets or any other web service, since those are the ones most prone to remote hacks.
Reactions: tungfa
JacobWr
Oh, okay. Thank you for the clarification! Exodus looks like a nice option then.
Reactions: tungfa
JacobWr
hii, did you tried Exodus?
Yeah, just starting to use it. The interface is really smooth, quite easy to use it. Though I can't personally give the advice to use it as I haven't been using it for long enough. I just read a lot of overviews and watched plenty of videos with feedbacks. After that, you realize what features are important and which aren't + it becomes obvious what are the TOP wallets as top 5 is usually almost the same in any reviews, like in the ones that I've found. And then I just searched for some videos on Youtube where people would go more in detail on a specific wallet.
JacobWr
I like Edge. It is simple enough for brand new beginners to use
Right, I've heard a lot that this wallet is labelled as 'for beginners!':) Though it doesn't have so many features, but again - it's free, so.
Fly077
How I use coinsbank as a wallet
very convenient mobile applications for both android and ios
