A How-To..., with the -QT Wallet - PART THREE
Discussion in 'Mining' started by MangledBlue, Jul 7, 2014.
  1. MangledBlue
    MangledBlue Well-known Member
    Jun 28, 2014
    1,246
    678
    3) -HOW TO SOLO-MINE
    Most people will tell you that Solo-Mining is point-less.
    To a point, I agree.....
    I think of it from time to time, how much of a lost art it really is.
    Pushed to the side and never talked about really.
    But if everybody would turn ON their -Qt Wallet to Solo-Mine,
    our Network would maintain a minimal Hash-rate, constantly.
    - Be sure that you have created the above <darkcoin.conf> file
    - OPEN your DarkCoin -Qt Wallet before mining
    -Qt Wallet will not start mining until you run a, Command-line
    - Transactions will appear in the Overview window.
    -- When you find a Block Solo-Mining, it will appear as an incoming transaction.
    -- You'll see a really cool Mining Icon (X)
    3.1) (CPU) (local) -Qt Wallet
    If you want the quick and easy answer to CPU Solo-Mining,
    CLICK: Help
    CLICK: Debug Window
    CLICK: Console
    Input the following command-line: setgenerate true -1
    -And now your Solo-Mining-
    3.1.1) More details........
    To START mining: setgenerate true -1
    To STOP mining: setgenerate false
    Proof of/if mining: getgenerate
    (TRUE = ON FALSE = OFF)
    Shows a lot of mining info: getmininginfo
    3.2) (GPU) (local) -Qt Wallet
    You'll need to alter your favorite mining software...
    - Command-line and/or your GUI Miner to represent Solo-Mining
    Instead of listing a Pool when GPU Mining,
    -Replace the Pool with: localhost or 127.0.0.1 or 0.0.0.0
    -Port: 9999
    -Username:<match your .conf file rcpuser>
    -PSW:<match your .conf file rcppassword>
    --Then leave all other settings that work for you, as they are.
    - YOU SHOULD BE SOLO-MIING WITH YOUR GPUs NOW -
    NOTE: You can solo-mine with both CPU and GPU at the same time.
    3.3) (CPU) and (GPU) (remote) -Qt Wallet
    - Command-line and/or your GUI Miner to represent, Remote Solo-Mining
    Instead of listing a Pool when Remote Mining,
    -Replace the Pool with:<the IP address of your remote DRK -QT Wallet> <what.ever.yours.is> 192.168.0.127 10.0.0.127
    -Port: 9999
    - YOU SHOULD BE REMOTE SOLO-MIING WITH YOUR CPU and/or GPUs NOW -
    NOTE: To find the IP address of a local machine:
    - OPEN/RUN: CMD.exe
    - At the command promt TYPE: <ipconfig /all>
    - You will find you local machine IP here.
    3.4) CONTROLLING THE CPU
    3.4.1) CPU Afinity 1.0
    Type this Command-Line to Mine all CPU cores: setgenerate true -1
    If you want to use a specific number of CPU cores,
    Or, if you experience lag - use this Command-Line or a variance....
    instead of -1, remove the (-) symbol and type number of core(s): setgenerate true 4
    (if you have an 8 core CPU, this will generally use 0-3, or 50% of CPU cores)
    NOTE: Helps for lag issues
    3.4.2) CPU Afinity 2.0
    You can also use the Task-Manager to set CPU Afinity
    OPEN: Task-Manager
    CLICK: Processes (tab)
    LOCATE: darkcoin-qt.exe*32
    RIGHT-CLICK: darkcoin-qt.exe*32
    - Small Menu pops up.
    CLICK: Set Afinity
    CLICK: Check-mark the CPU core(s) you wish to use
    CLICK: OK
    DarkCoin -Qt Wallet will only use the CPU core(s) you have assigned
    3.4.3) CPU Afinity 3.0
    With CPU Afinity, you use a combination of both forms.
    100%
    Console Command-Line to use all CPU cores: setgenerate true -1
    Leave the Task-Manager as it is.
    50% with 6 CPU cores
    Console Command-Line to use (3) CPU cores: setgenerate true 3
    Leave the Task-Manager as it is, or
    OPEN: Task-Manager and assign (3) of the (6) cores to be used by -Qt Wallet.
    I'm sure you can be very creative with CPU Afinity 3.0
    3.4.4) CPU - SET PRIORITY
    When setting the Priority of the CPU,
    -Remember to set all -Qt Wallets the same or,
    --The -Qt Wallet with the highest priority will dominate the CPU usage.
    -Only set CPU Priority: LOW to HIGH - never use realtime
    OPEN: Task-Manager
    CLICK: Set Priority
    -Remember to set all -Qt Wallets the same: LOW to HIGH - never use realtime
    NOTE: CPU Priority can also assist with lag issues
    BEWARE - Do not forget your Encryption PSW
    BEWARE - Do not delete your wallet.dat file
    ***AND BACK-UP wallet.dat FILE OFTEN***
    If this has helped you in any way...
    ...donations accepted but not required.
    STEP OUT OF THE LITE AND INTO THE DRK
    https://dashtalk.org/search/233808/...ate&c[title_only]=1&c[node]=3&c[user][0]=1612
    all 3 - click above
    [all need to be updated]
    #1 MangledBlue, Jul 7, 2014
    • Like Like x 6
  2. moli
    moli Grizzled Member
    Aug 5, 2014
    3,261
    1,837
    Very cool... How come you never showed this thread to anyone? Nobody else has ever seen this! :p
  3. stonehedge
    stonehedge Well-known Member
    Jul 31, 2014
    696
    333
    233
    I know right? I really believe we should get this put into the GUI at some point. If you've got the CPU for it, why not use it?
  4. tungfa
    tungfa Administrator
    Apr 9, 2014
    8,950
    6,730
    you should post that under "Guides"!
    I had no idea this worked !
  5. Miner237
    Miner237 Well-known Member
    May 28, 2014
    506
    223
    213
    Nice guide, I was solo mining throughout june 2014 and earned about 20 DRK. It was tough though when net hash rate is over 100 gig you need patience.... For weeks i had nothing....
  6. acidburn
    acidburn Active Member
    May 26, 2014
    467
    175
    I'm going to add 4 cores to my solo miner.
  7. MangledBlue
    Jun 28, 2014
    1,246
    678
    Thx for the feedback :)
    Means a lot.
    Anybody want to help me finish my Dummies Guide to MasterNodes? :-D
  8. moli
    Aug 5, 2014
    3,261
    1,837
    Could you put in the links for Part 1 and 2 at the top? Thanks :)
  9. MangledBlue
    Jun 28, 2014
    1,246
    678
    Once I get home from work I'll work on that
  10. daleaus
    daleaus New Member
    Sep 9, 2015
    20
    9
    I just get RPC call failed and it never connects with the same settings, I even tried setting up a differn't port in the config and minner... same thing
  11. thelazier
    thelazier Active Member
    Jan 5, 2015
    240
    184
    Dash Address:
    Since v12 wallet merged updated with bitcoin core, rpc/getwork is not available on wallet anymore. For solo miner, please use mining application which support rpc/getblocktemplate or create own mining pool or p2pool for support rpc/getwork to mining application.
    • Like Like x 3
  12. daleaus
    daleaus New Member
    Sep 9, 2015
    20
    9
    How do you use rpc/getblocktemplate to solo mine?
    • Like Like x 1
  13. Wolf0
    Wolf0 Member
    Oct 7, 2014
    71
    56
    You write in support in SGMiner.
    • Like Like x 1
  14. MangledBlue
    Jun 28, 2014
    1,246
    678
    Yes - I should up date this - sorry
    nobody realty knew about it for a long time....
    Might give me some thing to do one day soon :-D
    • Like Like x 1
  15. frederik
    frederik New Member
    Oct 20, 2015
    Gnah... Have been hacking in my shell for like 4 days now to get solo mining working. Just to find out it does not work at all. *hahaha*
    Will have a look at p2pool. :)
  16. MangledBlue
    Jun 28, 2014
    1,246
    678
    actually it does work
    dash-cli setgenerate true -1
    [all cpu cores]
    dash-cli setgenerate true 1
    [1 cpu core]
    dash-cli getmininginfo
    [to get mining status]
    dash-cli setgenerate false
    [stop mining]
    OR - use the CMD-line, in the wallet, by dropping the <dash-cli>
  17. frederik
    frederik New Member
    Oct 20, 2015
    My i5 just generates at like 178khash/s.
    I would like to use my nvidia gtx970. But ccminer can't connect to the local server.
    • Like Like x 1
  18. MangledBlue
    Jun 28, 2014
    1,246
    678
    been a minute since I used it but what are your settings?
  19. frederik
    frederik New Member
    Oct 20, 2015
    Dash Core version v0.12.0.55-c30a0aa (64-bit) on Xubuntu 15.04
    dash.conf
    server=1
    rpcuser=frederik
    rpcpassword=randompa55
    rpcallow=localhost as ip (sneaky url)
    rpcport=9998
    Curling localhost on that port tells me:
    {"result":null,"error":{"code":-32700,"message":"Parse error"},"id":null}
    ccminer jells
    [2015-10-20 16:37:17] Hypertext Transfer Protocol (sneaky URL) request failed: The requested URL returned error: 401
    [2015-10-20 16:37:17] json_rpc_call failed, retry after 30 seconds
  20. UdjinM6
    UdjinM6 Official Dash Dev
    Dash Core Team Moderator
    3,637
    3,536
    1. check your curl command
    2. 401 means "unauthorized" - check username/password
  21. frederik
    frederik New Member
    Oct 20, 2015
    Ups my fault.
    This is the response I get. :)
    [2015-10-20 17:25:36] Hypertext Transfer Protocol (sneaky URL) request failed: The requested URL returned error: 404 Not Found
    [2015-10-20 17:25:36] json_rpc_call failed, retry after 30 seconds
  22. MangledBlue
    Jun 28, 2014
    1,246
    678
    should be
    rpcallow=127.0.0.1 or 0.0.0.0 or localhost
    rpcport=9999
  23. frederik
    frederik New Member
    Oct 20, 2015
    rpcport at 9999?
    Unable to bind to 0.0.0.0:9999 on this computer. Dash Core is probably already running.
    Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
    tcp 0 0 127.0.0.1:9999 0.0.0.0:* LISTEN 1000 39558 9431/dash-qt
  24. UdjinM6
    3,637
    3,536
    nope, rpc port should be 9998, port 9999 is for p2p
    • Like Like x 1
  25. MangledBlue
    Jun 28, 2014
    1,246
    678
    my bad...
    edit: it has been a minute :-D
  26. frederik
    frederik New Member
    Oct 20, 2015
    But p2pool works like a charm. :)
    @github dashpay/p2pool-dash
    • Like Like x 1
  27. tungfa
    Apr 9, 2014
    8,950
    6,730
    MangledBlue
    is this solid and working ?
    ready to go onto the Wiki and such ??
    tx
    (i need an official ok, as i have no idea what all this mean :rolleyes:)
    Edit: where is 1 and 2 ?
  28. MangledBlue
    Jun 28, 2014
    1,246
    678
    no
    this is not ready for the wiki - ha!
    This was written - more than a year ago - LOL - Just before I got my own MN - last year [2014] June
    so old - lol
    needs a LOT of revisions/updates.......
    all 3 - click above
    • Like Like x 1
  29. tungfa
    Apr 9, 2014
    8,950
    6,730
  30. Larryg
    Larryg New Member
    Jul 10, 2016
    all 3 - click above
    [all need to be updated][/QUOTE]
    If this thread is still active... can anyone tell me how to determine:
    A) if I'm mining, and
    B) at what rate, and
    C) how to determine mining activity, and
    D) how will I know if I solved a block.
    I think the instruction of "setgenerate true -1" worked, because I can see my CPU maxed at 100% (BTW... can the throttle the percentage dedicated to mining?). But I an't seem to figure out how to measure or track mining progress if in fact I am mining.
    Thanks...
