2 MasterNodes for 1 wallet?
Discussion in 'Masternode Guides' started by Rajak, Mar 9, 2018.
  1. Rajak
    Rajak New Member
    Mar 7, 2018
    6
    Hello
    in masternode.conf (for dash qt) i made settings like this
    MN900 MN-ServerIP:9999 PrivateKey1 TransactionNumber1 0
    MN901 MN-ServerIP:9999 PrivateKey2 TransactionNumber2 0
    and dash.conf in remote server (MN server) looks like
    rpcuser=randomname
    rpcpassword=randompassword
    rpcallowip=127.0.0.1
    listen=1
    server=1
    daemon=1
    maxconnections=24
    masternode=1
    masternodeprivkey=PrivateKey1
    externalip=MN-ServerIP
    rpcuser=randomname
    listen=1
    server=1
    daemon=1
    maxconnections=24
    masternode=1
    masternodeprivkey=PrivateKey2
    but it doesnt worked. can someone help me?
  2. strophy
    strophy Administrator
    Feb 13, 2016
    661
    378
    What exactly didn't work? What was your expected behaviour and what actually happened? Did you see an error message?
    In general each masternode must have a unique IP address. Are you trying to run two masternodes on one IP address?
  3. Rajak
    Rajak New Member
    Mar 7, 2018
    6
    Yes i am trying to run 2 masternodes on one IP.. so it is problem?
    what if i will add on server another IP address and then will try to activate another masternode with that IP... i am insteresting if would have 2 IPs and 2 masternodes is this configuration correct for it?
  4. TaoOfSatoshi
    TaoOfSatoshi Grizzled Member
    Jul 15, 2014
    2,689
    2,600
    Yes, this is the correct configuration. Multiple MNs per IP is not supported.
  5. Rajak
    Rajak New Member
    Mar 7, 2018
    6
    Thank you i will try to add new IP to my remote serv and then try this configuration.
    externalip=MN-ServerIP1
    externalip=MN-ServerIP2
    it must be like that yes?
  6. Rajak
    Rajak New Member
    Mar 7, 2018
    6
    Hello again.
    I also added IpV4 address to my server,
    then i configured my Network settings as it says vultr
    /etc/network/interfaces
    auto lo
    iface lo inet loopback
    auto ens3
    iface ens3 inet static
    address mainIPaddress
    netmask XXXX
    gateway XXXXX
    dns-nameservers XXXXX
    post-up ip route add XXXX dev ens3
    auto ens3:1
    iface ens3:1 inet static
    address additionalIPaddress
    netmask XXXXX
    then i configured dash.conf file on server:
    rpcuser=randomname
    listen=1
    server=1
    daemon=1
    maxconnections=24
    masternode=1
    externalip=MainIP
    rpcuser=randomname
    listen=1
    server=1
    daemon=1
    maxconnections=24
    masternode=1
    externalip=AdditionaIP
    and masternode.conf for dash wallet
    MN900 MainIP:9999 PrivateKey1 TransactionNumber1 0
    MN901 AdditionaIP:9999 PrivateKey2 TransactionNumber2 0
    how to know that it worked?
    thank you
  7. qwizzie
    qwizzie Well-known Member
    Aug 6, 2014
    1,500
    715
    You can issue a ./dash-cli masternode list full | grep -e MainIP:9999 and a ./dash-cli masternode list full | grep -e AdditionaIP:9999
    if it returns both with "ENABLED" it works.
    Edit : dont forget to update Sentinel and issue a start from your cold wallet if you want to implement this.
    #7 qwizzie, Jul 22, 2018
